Is a Nonconformance Report required for every Customer Complaint?
tylerr
Hello members,
I have been researching the topic of customer complaints and the corrective action process. Concerning ISO9001, is it necessary that every customer complaint become a nonconformance? Can we, instead, use a system for determining trends and wait until one is found before a nonconformance report is issued? Basically, we don’t want a nonconformance report for every single customer complaint.
Some background:
We are a distribution company and render a service rather than produce products. This being the case, customer complaints is a system of measurement used to ensure that “product” (ISO) requirements are being fulfilled. At this point, there is a code system for customer complaint categories used by customer service. We would like to use this to track trends rather than completing a report for every complaint (the volume of customer would make this very time consuming).
Because of the coded complaints handling system, we would be able to address major complaints through the NC/CA process. Hopefully, this would allow lesser complaints, which should only require a correction, to be handled by a reship or credit/refund. Once a trend is realized about these lesser complaints, we can escalate them as a whole to a nonconformance and issue a corrective action.
:thanx:,
Tyler R
K
keres
Re: Nonconformance for every customer complaint?
In punctual - by definition Nonconformance is when requirements are not met. Customer complaint is actualy when customer requirements are not met.
So...
somashekar
Hello members,
Some background:
:thanx:,
Tyler R
Hi Tyler.
The customer complaint makes reference in two places
1. 7.2.3
To meet this requirement of effective arrangements for communicating with customers about customer complaints, you have to log every complaint first.
2. 8.5.2
You have to have a documented procedure to say how you review each of such complaints that you log., determine the cause., evaluate the need to take action such that they do not recur.,
It is here that you apply your analysis and discretion about each such complaint, do they need independent action or you see a trend from which you can arrive at a common action such that any such will not recur. During this phase you will also assess if only a correction will suffice. Would you be sure that it will not recur? make a data based and fact based judgement.
Take the leverage of the documented procedure to address how you will go about addressing the a) to f) of the 8.5.2 for customer complaint.
Take message from 7.2.3 into consideration here since for each customer his complaint has great relevance to him however small in nature it be to you.
So address every customer complaint >>> Yes
Nonconformance for every customer complaint >>> Perhaps, 8.5.2 a) b) c) d)
CA for each complaint >>> May be, May be not 8.5.2 c)
Records >>> Each complaint 7.2.3 c) and 8.5.2. e)
Did it answer you ~~~
2
20130523
Without referencing all of the standards, I would say, must you address customer complaints? Yes. Do you need a detailed system of corrective action for each? No. As long as your system proves to be effective. For me, I require that my service reps check a box if the customer wants follow-up; they must ask. If the box is checked, I follow-up in some fashion with 100% of those. If they are not, they do not get follow-up, unless I see a strange trend, then I will follow-up with whom I feel I need to.
Works for me, but maybe not everyone!
Kales Veggie
People: The Vital Few
Hello members,
Some background:
:thanx:,
Tyler R
My simple answer is Yes, but then you have to take the appropriate corrective action (by looking at risk and impact and cost)
I would record all complaints and use it as a trending tool to see if things are getting better.
Sidney Vianna
Post Responsibly
the answer is no, simply because not every customer complaint/dissatisfaction are valid.
If you want an effective and robust customer complaint handling system, you should look in the guidance offered in ISO 10002. It is a very good guidance standard to assist organizations in setting up a complaint handling system. If you do a search on ISO 10002 here at The Cove, you will find several threads.
tylerr
Somashekar,
Thank you for the reply. You certainly helped me link my dilemma to the standards. I beleive the comlpaints handling process we currently have in place will: record and evaluate each customer complaint; help determine trends which allow for NC/CA identificaiton; allow the flexibilty of treating each complaint as a NC or waiting until a trend is determined.
I may have been vague in my first post but it seems like the current system is acceptable for incorporation into the NC/CA process. The only issue is that every complaint will not receive a Nonconformance Report (form). This issue seems OK becuase, although a form will not be used, each complaint will be logged and evaluated to determine a correction or corrective action (in which case it would definaitely get a Nonconformance Report).
Ambir,
Thanks for the suggestion. This seems similiar to what will be happening in our system. The idea is that each complaint is logged and evaluated (using a coding system). Some will receive more attention than other (in the form of followup or NC/CA) but others will simply receive a correction (no NC/CA) and be fed into the databse to determine if there is a trend that would require the NC/CA process.
Sidney,
Your point is exactly what got me thinking about this process. Although every customer complaint should be logged and handled with care, they are not all valid. (Although they are valid when talking about customer perception but that is another topic). Also, thank you for poining me to that sub section of the forum. I had been lurking around there and found some things that helped me.
Everyone who replied,
Thanks to you too. I appreciate the comments and insight.
Thank you,
Tyler R
Randy
Nope:nope:
A customer can complain:...
...to try and get something free
...to try to keep from paying
...to just make you look bad
...to just be &itchy
V
vanputten
I think it depends on what one means by customer complaint. I like Randy's answer. I can't imagine an organization doing a documented corrective action for every "customer compaint."
JaneB
Nope:nope:
Yes, indeed they can.
Common sense and good judgment need to be applied; someone in an appropriate position needs to look at each issue and decide if it's valid and warrants action, or not. But you don't have to straitjacket yourself into raising a complaint form/CA/whatever for every single one!
E When to generate a nonconformance report ISO 13485:2016 - Medical Device Quality Management Systems 6
PhilM Nonconformance report, Customer complaint investigations and RMAs ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
R Visually impacting graphics for Nonconformance status metrics for Management Report Nonconformance and Corrective Action 5
E Incident Report or Nonconformance Report for Equipment Failure? Quality Manager and Management Related Issues 5
Q ECR (Engineering Change Request) or NCR (Nonconformance Report) in Fabrication? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
S Is an 8D Report and a NCR (Nonconformance Report) the same? Nonconformance and Corrective Action 10
Sidney Vianna AS9101 Process Effectiveness Assessment Report/Nonconformance Record Review Modules AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
N NCR (Nonconformance Report) Combined with Corrective Action Report? Nonconformance and Corrective Action 1
D Nonconformance or Misinterpretation - When an operator does a Nonconformance Report Nonconformance and Corrective Action 31
B Format for Discrepant Material Report (DMR) - Nonconformance Report (NCR) Document Control Systems, Procedures, Forms and Templates 1
R Reference Numbers or Titles for a Nonconformance Report? Nonconformance and Corrective Action 6
R Internal Audit Report Nonconformance Follow Ups Internal Auditing 5
C NCR (Nonconformance Report) Root Cause - Cause Code AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
D Nonconformance Report SOP - Example wanted Nonconformance and Corrective Action 6
L Non Conformity (Nonconformance) Report & Preventive Action Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
D AS9101D Clause 4.2.2.5 NCR (Nonconformance Report) Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 23
M How to write a Nonconformance Report ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
S Audit Summary Report - Nonconformance Aging Analysis Nonconformance and Corrective Action 10
K NCR (Nonconformance Report) - Basic questions - When should an NCR be filled out? Nonconformance and Corrective Action 5
P Measuring Severity of Construction Nonconformance Report Nonconformance and Corrective Action 3
D Any difference between nonconformance report and record? Nonconformance and Corrective Action 2
G NCR (nonconformance report) tracking and database help Nonconformance and Corrective Action 6
V Nonconformance report form format ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
G Receiving Discrepancy Report vs Nonconformance Report Nonconformance and Corrective Action 4
W NCR (Nonconformance Report System) Home Made Database or Software Recommendation Quality Assurance and Compliance Software Tools and Solutions 7
E NCR (Nonconformance Report) for device defects - Hot rolled coils Nonconformance and Corrective Action 1
T NCR (Nonconformance Report) vs. MRB (Material Review Board) Nonconformance and Corrective Action 27
J Is the NCR (Nonconformance Report) Confidential? Nonconformance and Corrective Action 27
F Nonconformance Report example template or form Document Control Systems, Procedures, Forms and Templates 11
J Seeking: Nonconformance report form Document Control Systems, Procedures, Forms and Templates 3
W List of NCR (NonConformance Report) Defect Cause & Corrective Action Codes Nonconformance and Corrective Action 18
H NCR (Nonconformance Report) - External customer - Seeking Advice Nonconformance and Corrective Action 9
R Nonconforming Product - Report for each product we find with a nonconformance? IATF 16949 - Automotive Quality Systems Standard 5
A Issuing Countermeasure Report - Does every nonconformance identified require an NCR? Nonconformance and Corrective Action 2
N Nadcap AC7101/2 Rev. E Section 3.2 - Nonconformance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
T Internal Nonconformance procedure thoughts (AS9100) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
C NCR (Nonconformance System) Software Nonconformance and Corrective Action 7
L How to deal with an ISO 13485 Supplier Audit nonconformance ISO 13485:2016 - Medical Device Quality Management Systems 17
K Counterfeit parts prevention - Audit Nonconformance - AS9100 8.2.2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 25
qualprod When to write up a nonconformance and require a NCR - We produce labels ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
M Medical Device Directive - Seeking common nonconformance write up scenarios CE Marking (Conformité Européene) / CB Scheme 2
CPhelan Nonconformance opened as incorrect expiration date placed on received product. Escalate to CAPA? Nonconformance and Corrective Action 4
qualprod Ineffective follow up of people performance - Audit Nonconformance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Q AS9120 7.5.3.2 Control of Documented Information - Audit Nonconformance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 20
qualprod Criteria to raise a Nonconformance based on KPI values ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 39
L AS9100 D- Handling Nonconformance Documentation for an organization that outsources most of the work. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
G Timing allowed by IATF to close a Remote Site Minor Nonconformance IATF 16949 - Automotive Quality Systems Standard 2
J ISO 13485 Audit Nonconformance written against 6.3 Infrastructure ISO 13485:2016 - Medical Device Quality Management Systems 25
PastorBee13 IATF 16949 Audit Nonconformance Responses per 5.1.1.2 - Format IATF 16949 - Automotive Quality Systems Standard 11
