Is a stable process also normal at the same time?
Jafri
What I understand is that a stable process is one whose Xbar-R control chart is within spec. In other words, no special cause present.
But can we automatically assume from such a stable process that its output will follow normal distribution as well?
Is stability and normality one and the same?
AMIT BALLAL
Xbar-R chart should be compared with control limits, not specification limits. I hope, you wanted to say control limits.
If we use a variable control chart and if there is no special cause, there is a possibility of the process to follow normal distribution. But we cannot be 100% sure that it distributes normally, since we don't always use all rules i.e. to be applied to control charts. Hence normality and stability can be same and cannot. Hence better to check normality of your process (data).
You are saying the process is stable and whether it can be said that output will follow normal distribution as well?
In Xbar-R chart / any variable control chart, we take samples (which is again output of the process) and based on these we are studying behavior of the process. So, we are always speaking about normality of the process by studying output of the process (products).
Again, normality in case of SPC helps us to predict about the population using indices such as Cp/Cpk Or Pp/Ppk. Unless the process is normally distributed, we cannot properly predict about the population.
A process that is in statistical control DOES NOT necessarily have a Normal distribution. Nor is a Normally distributed process necessarily ‘in statistical control’. This is just a Zombie theory. It has been disproven and explained countless times since the 1930s when Shewhart first described the method of statistical control.
And yes we can make predictions about processes that are not Normally distributed...
Statistical control is based on the homogeneity of the process - as rationally subgrouped - and not on it’s distributional shape. A process in statistical control has random variation within predictable limits and exhibits no discernible patterns (beyond those that are controlled for by rational sub grouping).
PLEASE read the works of Donald Wheeler if you are interested in statistical process control. His articles are available for free on the Quality Digest web site. They are short and easy to read. He stays true to Shewhart who ‘invented’ SPC and to Deming and others who understood and promoted Shewhart’s work.
A great start is Wheeler’s article entitled “Probability Models do not generate your data”
Probability Models Don’t Generate Your Data | Quality Digest
Jafri
Thanks for these references.
Mike S.
Happy to be Alive
I think earlier posts pretty clearly stated a stable process is not necessarily normally distributed.
Furthermore, neither stability or normality have anything to do with being within specification.
A Brief Explanation - Control, Capable and Stable Process Capability, Accuracy and Stability - Processes, Machines, etc. 2
A Cnpk (Non-Parametric Capability Analysis) to assess whether the Process is Stable Capability, Accuracy and Stability - Processes, Machines, etc. 7
S Is a Stable Process (within Control Limits) required for Calculating Pp, Ppk? Capability, Accuracy and Stability - Processes, Machines, etc. 6
C Process Control Chart - Capable, but not stable question Capability, Accuracy and Stability - Processes, Machines, etc. 5
H Process that is Not Stable vs. Not Statistically Capable - Differences Capability, Accuracy and Stability - Processes, Machines, etc. 9
D Stable process but the average baseline is unacceptable Statistical Analysis Tools, Techniques and SPC 8
H Keeping a Stable Process for a company, any suggestions? Should I being doing more? Quality Tools, Improvement and Analysis 5
Marc Definition Statistical Control - A stable process free of special causes Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
L Standard Deviation - Process Output is Stable and Normally Distributed Statistical Analysis Tools, Techniques and SPC 6
D Cp and Cpk - Cpk is an index that should be applied to a stable process Capability, Accuracy and Stability - Processes, Machines, etc. 16
G Stable, Predictable, Control - High Volume Mfg Statistical Analysis Tools, Techniques and SPC 9
A Auditing stable organisation with long certification history, minimal documentation. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
M Control Charts - Points TOUCHING Limits = Stable? Statistical Analysis Tools, Techniques and SPC 12
M Control Chart - Stable BUT with Special Cause? Statistical Analysis Tools, Techniques and SPC 1
S Cmk is defined as a Capability Index for a Stable Machine Capability, Accuracy and Stability - Processes, Machines, etc. 8
F Rules of process outsourcing in China China Medical Device Regulations 0
B Process / Procedure - Radiographic (X-Ray) Non-Film Document Control Systems, Procedures, Forms and Templates 0
P Certification process for registered device China Medical Device Regulations 11
J NCR- Failure of contract review process - NADCAP audit AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
Melissa Process Validation of Rotary Heat Sealer Speeds Design and Development of Products and Processes 4
C Validation of process for releasing the UDI EU Medical Device Regulations 4
Melissa Risk Management Process, How far do I need to go? ISO 14971 - Medical Device Risk Management 10
C Validation of process for production and servicing 5.7.1.5 API Spec Q1, 9th Edition Oil and Gas Industry Standards and Regulations 3
Z IA Construction Procurement Process Internal Auditing 3
H Risk Management Plan in agile process ISO 14971 - Medical Device Risk Management 11
DuncanGibbons Process flow & PFMEA for production planning and simulation activities? Process Maps, Process Mapping and Turtle Diagrams 7
N Help with understanding Process Controls Manufacturing and Related Processes 7
M VDA 6.3 – Workshop for Certified Process Auditor VDA Standards - Germany's Automotive Standards 1
C Process Consistency Manufacturing and Related Processes 5
I PFD (Process Flow Diagram) approach. Setup details as part of PFD? APQP and PPAP 5
K Business Process Flowchart Process Maps, Process Mapping and Turtle Diagrams 2
L Looking for Control Plan and FMEA Stamping process FMEA and Control Plans 2
J License renewal process in Iran Other Medical Device Regulations World-Wide 0
J Definition Outsourced process - Clear definition - 13485 Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 5
S IS0 13485 process flows ISO 13485:2016 - Medical Device Quality Management Systems 2
H Verification Process for the existing MDS Product IEC 62304 - Medical Device Software Life Cycle Processes 5
C Revalidation of Process Equipment for Equipment Transfered to New Facility. ISO 13485:2016 - Medical Device Quality Management Systems 5
Q Process map Evaluation and Analysis Method Process Maps, Process Mapping and Turtle Diagrams 5
S In process inspection Manufacturing and Related Processes 2
S Brexit 100% inspection during in process inspection Manufacturing and Related Processes 11
A Complaint review as part of the complaint handling process? ISO 13485:2016 - Medical Device Quality Management Systems 3
mustomutlu Process Validation Final Report Other Medical Device and Orthopedic Related Topics 2
Q Process Matrix_Audit Matrix Quality Management System (QMS) Manuals 4
Q Process description for outsourced processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q Process matrix examples of ISO 9001 & 14001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A When someone refuses to follow a process.... Misc. Quality Assurance and Business Systems Related Topics 27
