Is a stamp necessary to control a paper document?
Sidney Vianna
Post Responsibly
#11
Old habits die hard....
Especially if they serve as job protection.
This issue of document control is one of those I always used in Executive Management Overviews about ISO 9001. The importance of senior management being involved, engaged and participating in the ISO 9001 implementation phases.
Some of us know that ISO 9001 implementation will affect (sometimes significantly) how business processes are structured and how critical it is for business process (re)engineering to be kept in check for efficiency purposes. Document control in ISO-ese is translated as information dissemination in business lingo.
I have seen (more than once) misguided document control process owners intentionally creating monstrous, resource-intensive doc. control process, just in order to justify their overly inflated department and budget. Stamping (in each page!:mg:), color-paper, doc-cops, etc... are a few examples of mind-numbing, non value added process checks, put in place because someone believes that that is all required by ISO 9001. Since top management does not know any better, they too believe that they must have that incredible bureaucracy, in order to be ISO 9001 certified.
A clear example of how costly ignorance can be. And the subsequent misperception that ISO 9001 made us so bureaucratic, slower and added costs to our operation.
SteelMaiden
#12
Or....sometimes management doesn't listen to their own and wants something implemented because the "heard someone say that documents need to be stamped". There are a whole lot of reasons why obsolete and inefficient methods refuse to die.
dswit
#13
Very good responses! There's a lot of misperception out there and this is a great forum to dispel much of it!
At the previous company I spoke of before, we increased productivity by ~48% and turn around time increased by ~60%, actually reducing risk as we eliminated some of the human error elements.
I hate wasting time and money!
JQuality
#15
It's all about understanding the actual document control requirements rather than the perceived requirements.
When I changed jobs my new company had a very slow document control process. With a few minor changes, we were able to take a top heavy bureaucratic system that took upwards of 8 weeks for a document to navigate the maze of self-imposed requirements to a turnaround of as little as two hours.
It took quite a bit of convincing to even get anyone to consider changing the process because "that's the way we have always done it" was the mantra.
W
wwcanoer
#16
Ok, so no stamps. But then how do you differentiate between the current controlled copy, uncontrolled copies and obsolete copies... both in paper and electronic form?
Also, what identifying text do you place on you electronic copies?
Discussion:
I am developing my process. So far it seems cumbersome.
1. Print the document for wet ink signature with no text to identify status.
2. Scan signed doc and add "Uncontrolled Copy When Printed" watermark to the electronic copy on the file server.
3. To distribute an electronic controlled copy, use the same file as (2) (but there is nothing on it that states "controlled copy.")
4. To distribute a paper controlled copy I was going to stamp it as "controlled copy", otherwise how does someone know that it is a copy that is being controlled (tracked)?
5. To distribute a paper uncontrolled copy, can simply print from the file server.
6. To distribute an uncontrolled electronic copy, then doc control needs to provide an electronic copy with "Uncontrolled Copy" watermark.
For (2), I had though about "Controlled copy only when viewed on the server (eDMS)" but then I need to change the watermark when emailing a controlled copy.
What do you do?
Jeff Frost
#17
Discussion:
What do you do?
Why not make your job as easy as possible. All document on server are controlled copies with approvals on file in document control. Watermark document in about the center with the word copy in large type and place in the footer as statement that all copies are uncontrolled along with an automatic date and time fields. If you must release controlled printed copies of these documents use security paper and remove the watermark and footer notes. Security paper can be ordered from Staples or Office Max and when a copy is made form this type of paper the actual printed image will contain the word "copy" all over the page.
W
wwcanoer
#18
Jeff,
How do you implement the "automatic date" in a simple file server?
I plan to use pdf for all controlled docs online (to ensure everyone can read the docs). When using NitroPDF I could not find a method to have an automatic date field. (There is a option for placing the current date but when I open the file again in NitoPDF or Acrobat reader, the date does not update.) Plus, if someone downloads the file and prints it a few days later... not much of a control.
Thanks for your suggestions but I don't see your plan as any diferent. Still needs diferent watermark for the online and distributed controlled copies.
Why do you place a "copy" watermark on the server file? (Everything is a copy.)
~Brian
Jeff Frost
#19
I don't use pdf files because of compatibility issues with Microsoft programs. On the server is a password protected word documented that allows printing by user if needed. The use of the watermark is to identify that it was printed from the server and the date and time stamp is a feature of the footer setting in word.
W Is it required to stamp obsolete hard copy DHR's "obsolete"? ISO 13485:2016 - Medical Device Quality Management Systems 6
E Do all Controlled Document copies require a Stamp? Document Control Systems, Procedures, Forms and Templates 3
W Red Ballooning Stamp for Adobe Acrobat Files Quality Manager and Management Related Issues 1
M Genuine Signatures vs. Rubber Stamp (Approval) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
T Ballooning/Bubbling PDF drawings - My Dynamic Stamp AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 29
S Controlled Copy Stamp on "Paper Originals" Document Control Systems, Procedures, Forms and Templates 10
B Stamping Documents as "Controlled Copy" - Clause 4.2.3 Document Control Stamp Document Control Systems, Procedures, Forms and Templates 17
S Interesting Discussion Controlled Copy Stamp - Document Control Document Control Systems, Procedures, Forms and Templates 70
ScottK Customer requiring that we "rubber stamp" our C of C's for them... Records and Data - Quality, Legal and Other Evidence 10
B "Controlled" stamp for Controlled Documents - Any alternatives? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
K Stamp Requirements for Paperless Traveler AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
P Inspector Inspection Stamp Requirements and Control Program Document Control Systems, Procedures, Forms and Templates 9
Z Date Stamp on Documents from Production - Medical Devices 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
K PED (Pressure Equipment Directive) Certification - We hold an ASME 'S' stamp CE Marking (Conformité Européene) / CB Scheme 11
A Testing for Toys: What is required for an Art Stamp? Various Other Specifications, Standards, and related Requirements 3
R Operation sign-offs and test stamps for KanBan cards - Inspection stamp ink smears Lean in Manufacturing and Service Industries 2
W Controlled Document vs. Uncontrolled Copy - Stamp requirements Document Control Systems, Procedures, Forms and Templates 11
G Nuclear - ASME Section III N-Stamp - Requirements over and above AS9100 and ISO 9001 Various Other Specifications, Standards, and related Requirements 12
D Lucrative Rubber Stamp - I was once very impressed with ISO9000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
D Is it possible to control Customer Drawings (Prints) by a "Received" Date Stamp? QS-9000 - American Automotive Manufacturers Standard 16
Q Is Establishment Registration Necessary? Other US Medical Device Regulations 1
T IEC 60601-1-8:2020 Is it necessary to change the alarm melody? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
I When is necessary to have RoHS declaration on non-electrical parts? REACH and RoHS Conversations 1
M Is it Necessary to Use Health Canada Form when Reporting? Canada Medical Device Regulations 1
K ISO 13485 clause 8.5.2 'Any necessary CA shall be taken without undue delay' ISO 13485:2016 - Medical Device Quality Management Systems 11
Z Is IQ necessary for laser marking validation? EU Medical Device Regulations 3
E How do you determine if hipot is necessary for a cable product? Manufacturing and Related Processes 8
T HF testing / Summative evaluation for MDDS class I necessary? Human Factors and Ergonomics in Engineering 2
V 3 PQ lots mentioned as requirement in PPAP. Is this necessary? APQP and PPAP 2
G Best Practices for IT auditing - Is a session-id necessary for a complete audit trail? IEC 27001 - Information Security Management Systems (ISMS) 0
B Is it necessary to conduct product audit of entire product which is manufactured in the company as per IATF IATF 16949 - Automotive Quality Systems Standard 4
R Clinical Trial to sell in the EU - Necessary or Not? ISO 13485:2016 - Medical Device Quality Management Systems 5
K GDPR - Is it really necessary for the DPO(s) to be knowledgeable to Data Privacy Law? IEC 27001 - Information Security Management Systems (ISMS) 3
D How to ensure independence and authority necessary to perform QM tasks ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
bobdoering "nds" or Number of Discriminate Samples - the Necessary Tool to Work With "ndc"! Imported Legacy Blogs 0
S Is an index necessary for DMR or DHF? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
H Change of a medical device sterilization dose - New 510(k) necessary? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
B Time necessary for all Risk Management activities ISO 14971 - Medical Device Risk Management 2
M Risk Identification and Risk Assessment for any Process - Is it necessary? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
P Necessary Compliance Documentation for RoHS and REACH REACH and RoHS Conversations 5
C Change Order necessary to document FMEA Updates? FMEA and Control Plans 1
J Is a Laboratory Scope Necessary if... IATF 16949 - Automotive Quality Systems Standard 15
S Is a GR&R necessary for Weighing Scale? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
B Procedures necessary for things such as the floor cleaner or weigh scale ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
V Certified Internal auditor is necessary? ISO 9001 requirement? Quality Management System (QMS) Manuals 4
T Is it necessary to Audit our CARs and SCARs? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M Biocompatibility - why are animal studies necessary? Other Medical Device and Orthopedic Related Topics 11
N Is Notified Body approval necessary for small changes to IVD IFU? CE Marking (Conformité Européene) / CB Scheme 7
G Plant Relocation - Is it necessary to perform FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
