Is a subcontractor required to be ISO 13485 certified?
AMSC9856
Our customer is a 13485 certified medical device manfaucturer who does the final assembly in-house. Are we required to be 13485 certified as a sub-assembly (manily PCBAs and cable assemblies) contract manfuacturer?
MIREGMGR
Regulatorily, no. You don't make medical devices.
But, you may want to have a quality system...ISO 9001 or ISO 13485...just to make your business run more effectively. And, your customer might decide that if you don't have a quality system, they can't or won't use you as a vendor.
DannyK
There are several PCB assembly companies who have attained certification to ISO 13485 since they want to supply to the medical devices industry.
There is no requirement to be ISO 13485 unless specified by the customer.
Medical device companies have to show control over their subcontractors and having ISO 13485 may help in justifying not having to perform an audit.
somashekar
If your customer is certified to ISO 13485 with CMDCAS and is placing products into Canada, then perhaps he will seek to have ISO 13485 certified suppliers who make and supply to him critical components that would have a bearing on his medical device quality, reliability and safety.
Al Rosen
ISO9001 should be sufficient for this.
arios
ISO 13485 is a voluntary standard.
However it would not be voluntary for manufacturers of Finished Devices who sell in certain markets like in Canada. It may also be required to demonstrate an adequate level of control on certain service suppliers like sterilization facilities
You can be ISO 13485 certified if your customer so requires or for other market reasons. In addition attaining ISO 13485 can help you out to comply better with the FDA QSR as they both overlap on several requirements, so you or your client may have a better readiness in case of an FDA inspection.
Bottom line, whether you produce a Finished device or only components for a Finished medical device it is IMHO a good bussiness and compliance strategy to pursue ISO 13485 certification, so go for it :agree1:
jscholen
I'll confirm what others have said if it is a customer requirement.
I would not agree in pursuing ISO 13485, unless you are pursuing finished device assembly business. ISO 9001 should be sufficient as a component supplier with a supplier agreement in place.
It really helps medical device companies if you speak the language and understand their requirements(which is a ISO 9001 requirement). You will get more business this way.
cubix rube
I'm in the same boat. I recently changed employers, and am working with a component supplier who is going after 13485 certification. My background is 95% automotive for the last 20+ years, so everything specific to 13485/medical is a bit new to me. Add to that, that we're not really a medical device manufacturer, and it's been very difficult, yet enlightening, to research the best way to develop my QMS without boxing myself into any ridiculous requirements that would add unnecessary costs to our process, with little or no value added. I'm working on an advisory notice procedure now, and considering that we only manufacture components that are designed by our customers, with materials specified by our customers, and only delivered to our customers for them to assemble into their devices, it seems the advisory notice would never apply, yet the standard requires that I develop a procedure, so here I go. WOOT!!
Q
QualitySage
As a medical device manufacturer, certified to ISO 13485, our notified body requires our use of critical subcontractors certified to ISO 13485. The real work was defining subcontractor levels, then classifying all suppliers based on risk (not for example, by commodity). I used the risks identified on hazards analyses and design FMEAs and chose a threshold that made sense for us.
To get back to the original question, my comment here was just to add that your customer (the device manufacturer) may be required by their notified body to use ISO 13485 certified suppliers. If you are not certified and do not intent to pursue certification (maybe actual certification doesn't make business sense), you could ask your customer about the rationale. Perhaps they have rated your product to be higher risk than necessary and you don't really need to be certified, but they just prefer it. Maybe the customer could audit your compliance to ISO 13485 requirements. Our particular notified body auditor informed me that they would need to audit any of our critical suppliers that were not ISO 13485 certified (at our expense).
Hope this is helpful in providing a little more insight to why a subcontractor could be asked for ISO 13485 certification.
D Subcontractor Development - What is Minimum Required? Clause 4.6.2.1 QS-9000 - American Automotive Manufacturers Standard 13
U Adding another Subcontractor EU Medical Device Regulations 3
C Consequences of terminating a subcontractor re continuity of supply CE Marking (Conformité Européene) / CB Scheme 0
F How to submit a PPAP when a subcontractor is the sole manufacturer IATF 16949 - Automotive Quality Systems Standard 2
T Difference between a subcontractor and a supplier ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
P Sterilization Subcontractor of OEM ISO 13485:2016 - Medical Device Quality Management Systems 6
J What are a Taiwanese Medical device subcontractor's legal responsibilities with Taiwan regulations? Other Medical Device Regulations World-Wide 3
S Responsibilities between government owner and private subcontractor of a power plant seeking ISO 9001 certification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
P Subcontractor site in EC certificate EU Medical Device Regulations 2
M TS16949 Control regulation with business partner(Subcontractor) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
P Sterilization Subcontractor - Quality Control ISO 13485:2016 - Medical Device Quality Management Systems 3
O NADCAP AC 7108 - Subcontractor Laboratory Certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
J Product not in the Registration Scope of a Critical Subcontractor/Supplier CE Marking (Conformité Européene) / CB Scheme 11
F Tips, Guidelines and Checklist to conduct Audit of Supplier & Subcontractor Document Control Systems, Procedures, Forms and Templates 5
T Subcontractor Model to Shelter Model - How to include in ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S Aviation Parts Design Subcontractor Assessments - Example forms, etc. wanted AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S Developing Documentation and Defining Processes as Subcontractor IATF 16949 - Automotive Quality Systems Standard 6
D Subcontractor Requirements when a Customer Chooses the Subcontractor ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
R Subcontractor Agreement for Engineering Services Quality Manager and Management Related Issues 3
N Auditing a Software Code Subcontractor (Supplier) ISO 13485:2016 - Medical Device Quality Management Systems 4
M What determines a Critical Subcontractor? Other ISO and International Standards and European Regulations 5
T Packaging Subcontractor Certification - Class I and Class II Medical Devices Supplier Quality Assurance and other Supplier Issues 2
S Medical Device Subcontractor Significant Change EU Medical Device Regulations 9
T Control of Medical Device Software Subcontractor ISO 13485:2016 - Medical Device Quality Management Systems 1
I Taiwan Medical Device Product Approval Process using a Subcontractor Other Medical Device Related Standards 10
T Opportunity to become senior 'Subcontractor Quality Management' Engineer Career and Occupation Discussions 13
Z Subcontractor Assessment - Change control process Quality Manager and Management Related Issues 2
A EN/AS 9100 - Subcontractor audit and auditor requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
L Label placed on medical device by subcontractor based outside USA ISO 13485:2016 - Medical Device Quality Management Systems 4
M Justifying Subcontractor (with no QMS) Service - Class 1 Medical Instruments ISO 13485:2016 - Medical Device Quality Management Systems 10
T Process Instructions via BOM for Subcontractor? (PCB Population) Manufacturing and Related Processes 2
T Medical Devices Manufacturing Cleanroom Protocol and Subcontractor ISO 13485:2016 - Medical Device Quality Management Systems 4
R TS Certification Scope - Semiconductor subcontractor providing assembly and testing IATF 16949 - Automotive Quality Systems Standard 14
G Risk Analysis for a Subcontractor ISO 13485:2016 - Medical Device Quality Management Systems 1
L Subcontractor in terms of CAN/CAS 13485:2003 CMDCAS vs. DIN EN ISO 13485:2003 ISO 13485:2016 - Medical Device Quality Management Systems 5
C Semiconductor Subcontractor Quality System Supplier Quality Assurance and other Supplier Issues 6
M TS16949 section 7.0 Product Realization - Subcontractor with no Design responsibility Design and Development of Products and Processes 3
B Supplier Development - Cited for 'no evidence of subcontractor development' Supplier Quality Assurance and other Supplier Issues 7
Q Outsourcing & the Control Plan (Ours and the Subcontractor's) - Links, etc. APQP and PPAP 10
T Seeking: Subcontractor Satisfaction questionnaire - Construction Industry Document Control Systems, Procedures, Forms and Templates 4
D Supplier/Subcontractor Survey Questionnaire Supplier Quality Assurance and other Supplier Issues 6
R Subcontractor Development - 4.6.2.1 QS-9000 - American Automotive Manufacturers Standard 5
A Subcontractor (Supplier) SPC Supplier Quality Assurance and other Supplier Issues 4
S New Subcontractor Plant Registration QS-9000 - American Automotive Manufacturers Standard 3
A Who is compliant to the new subcontractor development guidelines? QS-9000 - American Automotive Manufacturers Standard 16
D Requirements for Supplier and Subcontractor Certification - July 2002 - Sanctions Supplier Quality Assurance and other Supplier Issues 3
Q Supplier and Subcontractor Supplier Quality Assurance and other Supplier Issues 8
Q Level of PPAP submission for Subcontractor APQP and PPAP 3
A QS-9000 Clause 4.6.2.1 and Interpretation C9 - Subcontractor Development QS-9000 - American Automotive Manufacturers Standard 41
A ISO 9001 at Subcontractor end ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
