Is Agilent?s automated network analyzer verification ISO/IEC-17025 compliant?
G
George Weiss
Is Agilent’s automated network analyzer verification ISO/IEC-17025 compliant?
Theoretically: I am placed in the position of testing a Agilent network analyzer, an example being the 8753D. I complete the manufacturer’s Z540.1 test data sheet, in the manufacturer’s manual, and then run the automated Calibration/Verification with calibration/verification kits, and print the resulting data. In the end I am left with having to report "same as mftr’s uncertainties". All of the testing on the data sheet and Calibration/verification is considered PASS<=100% of specification. I see this as a complete Z540.1 with data calibration, but can I am place the accredited label on it. How could I improve this process without gutting the entire process?
I can not see how to go accredited on any part of the calibration without creating a complete data sheet, and transferring all data with guard-bands, and uncertainties calculated.
OR is this an example where I would:
1. slap a MU, measured uncertainties range(s) sheet to the back of the test report, which would give general MU's for tests performed. I hear this might be an acceptable practice. It is done in some other cases.
2. Individually, test by test, verify each test to within, say k2 MU coverage, for compliant, and report undetermined, or non-compliant for other cases.
G
George Weiss
Re: Is Agilent’s automated network analyzer verification ISO/IEC-17025 compliant?
I agree that Agilent could calibrate this item in a clear accedited condition with report and information. I could then, after having it performed once use this information to develop my own process. I have been in the situation where the shortest course is following anothers foot-steps. Short of having this, I was asking, in my original question, if a band-aid approach, which would get me there, would be possible. I am reading, and listening to other aproaches which sometimes seem far form the expected full effort of an accredited instrument test, and it's report.
I have observed:
1. partial testing, and have seen it claimed as, "this is how we do it"
2. MU, measurement uncertainties statement in a general range form, and attached seperated from the recorded as-found/as-left data, on another page, or area.
NEW QUESTION: It might be a more concise to ask:
Can an accreditied datasheet be acceptable without guardbanding? as in Z540.1
or does this totally destroy the whole concept. This is to mean: Can a datasheet with a test result of [-100%spec]<- acceptable test range ->[+100%spec] be an accredited report in any situation?
Agilent, is a best practice player, and likely would say never, and maybe this is the full answer, but maybe some room for less than perfect exsists? and should it?
dv8shane
George,
First in my opinion you can not assume the "same as mftr’s uncertainties", the transfer uncertainties on your cal kit are most likely different from the manufacturer. Second I have had several discussions with Agilent Metrology and they state Z-540-1 compliant not accredited on their certificates. A good example is the 8902A measuring receiver. They also use the separate measurement uncertainty report.
If you wish to do it accredited it will be difficult to issue a conformance statement without first making sure you have accredited cal on all your standards used then doing the proper budgets, then guard banding as necessary. If your TUR is too low, you could consider listing the unit as operational with a statement to the effect of as per actual measured values and stated uncertainties. Hope this helps
G
George Weiss
very good comments, thanks!
I TS16949 - MSA for Agilent Parametric Tester IATF 16949 - Automotive Quality Systems Standard 1
I TS16949 - MSA for Agilent Parametric Tester Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
R Agilent 8902A FM/PM/AM Accuracy Measurement Uncertainty (MU) 1
R Problems Making Measurements - Agilent 8902A Measuring Receiver Calibration and Metrology Software and Hardware 4
J Agilent Power Sensor Calibration - Need a Calibration Procedure General Measurement Device and Calibration Topics 13
Z GRR for multiple automated metrology tools Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
validationspec How to Validate the Automated Processes (CNC Lathe and Milling)? ISO 13485:2016 - Medical Device Quality Management Systems 5
G Automated Workflow Tools ISO 13485:2016 - Medical Device Quality Management Systems 4
gramps What do you think about automated QA testing For software app industry? Misc. Quality Assurance and Business Systems Related Topics 5
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
J Sub-supplier change from manual to automated process - same specs - Report to FDA? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
P Images of Product for Automated Process - How long to keep? US Food and Drug Administration (FDA) 2
M Applicability of Means of Protection, working voltage in an Automated External Defibrillator IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
T Tests IEC 60601-1 - Grounding Resistance, Leakage Current and Dielectric Rigidity in an automated way IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Ron Rompen GR&R on Automated Inspection Cell Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 15
S What are you looking for in an automated quality management system? Quality Assurance and Compliance Software Tools and Solutions 8
F Automated Platform (IVD) Classification/Registration (New to RA) EU Medical Device Regulations 3
M Is Automated Internal Auditing Possible? Internal Auditing 13
A Automated Measurement Machine MSA - Small Parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
T Automated and Manual Measurement System Comparison (Correlation) Quality Tools, Improvement and Analysis 3
Crimpshrine13 MSA for a part Automated and part Manual Inspection Machine IATF 16949 - Automotive Quality Systems Standard 7
B How to do an MSA on an Automated Torque / Angle System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A Automated calibration of Digital Multimeter without communication port Calibration and Metrology Software and Hardware 2
S Bench Marking Automated Data Collection Benchmarking 4
C How to perform Gauge R & R on Automated Test & Measurement Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
P Looking for recommendations for an automated vision measuring system Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
M Automated Revision Updates - Notifications of new revisions for ISO's to subscribers Document Control Systems, Procedures, Forms and Templates 2
T Tools Six Sigma for my Automated Machine Six Sigma 8
C Gage R&R on In-Process Automated Inspection Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
Q 21 CFR 820.30 - Automated with Computer Software - Applicable? US Food and Drug Administration (FDA) 5
S How to calibrate AOI (Automated Optical Inspection) for IOPQ Qualification and Validation (including 21 CFR Part 11) 3
P GR&R on automated test system which produces hundreds of results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C Multiple Variation Gage R&R for Automated Testers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
J Classes for Hydraulic Calibration - Dead Weight Tester or Automated Controller General Measurement Device and Calibration Topics 1
Q Automated Test Software and System Validation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
L Automated Calculators like EXCEL sheets for different processes Quality Assurance and Compliance Software Tools and Solutions 2
L Dry Lube Application (Ever lube 620) - Manual Application vs. Automated Spray Process Manufacturing and Related Processes 1
E MSA (Measurement System Analysis) Study on an Automated Process Quality Tools, Improvement and Analysis 4
Hami812 Gage R&R on Automated Tool that supports Pass/Fail and some Parametric Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G Automated Production Line Quandary... FMEA and Control Plans 1
R Use of Automated Liquid Handling Robot for a PCR based Assay CE Marking (Conformité Européene) / CB Scheme 2
D Automated Vision Systems - Cost, Value and Payback of Implementation Statistical Analysis Tools, Techniques and SPC 2
I Gage R&R for Automated Measurement Equipment Systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
A Classification of Automated Gait Training Device for Rehabilitation EU Medical Device Regulations 5
R GAMP (Good Automated Manufacturing Practice) simplified please. Quality Manager and Management Related Issues 3
T Gage Repeatability for an Automated Leak Tester Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
sagai Automated System's Signature on Electronic Record - PART11 Qualification and Validation (including 21 CFR Part 11) 4
C Multiple Fixture Automated Vision System GR&R (Gage R&R) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
