Is an 8D Report and a NCR (Nonconformance Report) the same?
David DeLong
I agree with Jim on this one. A nonconformance states the deficiency and afterwards there would be a disposition rendered. An 8 D is the short and long term corrective action to eliminate the "defect" in future runs. There usually is a section for preventive action on similar processes.
cferrer
Would the disposition be the "immediate action" part, i.e. correction/containtment (D3)? Or better asked, would the disposition (rework/repair, scrap, UAI, RTS) be one of the possible components of the "immediate action"? Or does the disposition workflow run completely parallel and separate to the 8D methodology?
qualprod
Normally, first is the disposition, you have to fix the problem, sometimes is sufficient and turn the page, (if it is a Minor problem) if not, next Is the 8d or fishbone or whatever.
Sometimes both actions run in parallel.
John Predmore
There are 8 activities in an 8-D. The D refers to 8 Disciplines, or aspects of a problem-solving effort. There are different forms and formats used by different companies, so you might find slight differences when you search the Internet. In general, the 8 activities could be assigned to different persons, could be started at different times or could be completed out of order. But there is an logical sequence order which makes sense, so when making a list of activities, undertake them in logical order.
In common practice, the "immediate action" is to prevent the immediate problem from spreading, escaping (getting out of your factory into the hands of more customers) or getting worse. I call that Containment. Typically, the immediate action does not "solve" the root problem from recurring. Often, there is more investigation and more definitive corrective action to prevent or reduce the problem happening again.
I agree "Disposition" of suspect parts must be done and could be part of the Containment activity (3rd D). But the act of Disposition contributes nothing to reduce the root problem, does little to protect the customer in the long-term. Disposition might actually be used to hide the problem from management, which is not helpful to problem-solving IMHO. Disposition is a much lower priority than Containment and if problem-solver resources are limited, Disposition is done later.
cferrer
Thank you guys, this helps a lot. I guess my confusion started after reading this article:
Building a Solid CAPA Framework Part 2
.. which equates dispostion with correction.
A bit of background: I am trying to map out a comprehensive complaints management process that includes RMAs, NCs/CAPA, post-delivery escapes, etc.. Thus, I am having trouble reconciling the differences between all these types of quality events and the paths or workflows they require within the company. So, trying to channel them all under the roof of the 8D-methodology is not turning out to be any easier.
It might just be too ambitions to try to combine these processes.
optomist1
A Sea of Statistics
generally, at least in the automotive sphere...the 8D is a powerful tool used to establish root cause...and various levels of corrective actions. Many, many times the 8D is ignored...some choose to use other tools. In either case it lends much needed structure and organization to what can at times (in the drive to move production forward...)be a splintered, fragmented process. Re: the other forms/tools above should really complement and support the 8D RC/CA process...my two Euros worth
Let's take it step by step.
First there is detection. I find a couple of nonconforming parts.
I "NCR" them (people love to verb nouns) which is really just a means of identifying and notifying people that these parts are bad. the parts are 'segregated' physically or electronically or by some means from the 'good' parts.
Then comes correction. Someone comes and dispositions the bad parts. this is also referred to as 'correction'. In other words I either rework or repair* the parts to make them 'good' again. or I determine that they are acceptable as is**. Or I scrap them/return them to the supplier to remove them from the system.
Next comes containment. Containment is as John P said - screen future parts to ensure any 'bad' parts don't escape and screen to ensure that there are no parts that did escape downstream to finished goods or the customer and are there any necessary actions for parts that did escape tot eh Customer to improve their experience (recall & replace, free goods, special instructions, proactive notification, etc.)
Next comes 8D/corrective action to prevent recurrence. Now depending on the severity of the detected problem the 8D may start at containment. sometimes 8D starts after containment when it is found to be severe and extensive. And of course some occurrences of a defect are too few in number and/or severity to not require an 8D/corrective action to prevent recurrence...
*repair in some industries has a special meaning. this may generate another review and approval loop.
**Use as is can also generate special review and approval loops
I think containment has to come before correction--it's usually the first thing done upon notification or discovery. You can't do correction until you've located all of the suspect material.
Q ECR (Engineering Change Request) or NCR (Nonconformance Report) in Fabrication? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
N NCR (Nonconformance Report) Combined with Corrective Action Report? Nonconformance and Corrective Action 1
B Format for Discrepant Material Report (DMR) - Nonconformance Report (NCR) Document Control Systems, Procedures, Forms and Templates 1
C NCR (Nonconformance Report) Root Cause - Cause Code AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
D AS9101D Clause 4.2.2.5 NCR (Nonconformance Report) Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 23
K NCR (Nonconformance Report) - Basic questions - When should an NCR be filled out? Nonconformance and Corrective Action 5
G NCR (nonconformance report) tracking and database help Nonconformance and Corrective Action 6
W NCR (Nonconformance Report System) Home Made Database or Software Recommendation Quality Assurance and Compliance Software Tools and Solutions 7
E NCR (Nonconformance Report) for device defects - Hot rolled coils Nonconformance and Corrective Action 1
T NCR (Nonconformance Report) vs. MRB (Material Review Board) Nonconformance and Corrective Action 27
J Is the NCR (Nonconformance Report) Confidential? Nonconformance and Corrective Action 27
W List of NCR (NonConformance Report) Defect Cause & Corrective Action Codes Nonconformance and Corrective Action 18
H NCR (Nonconformance Report) - External customer - Seeking Advice Nonconformance and Corrective Action 9
A Issuing Countermeasure Report - Does every nonconformance identified require an NCR? Nonconformance and Corrective Action 2
W Surveillance report along side an NCR program Nonconformance and Corrective Action 2
A ISO/TS 16949 - Sharing Certification Audit Report (NCR's) with the Customer IATF 16949 - Automotive Quality Systems Standard 8
B Combining a CAR, an NCR, and an Accident Report ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
J What is the time limit for an auditor to respond to NCR's and submit audit report? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
shimonv Clinical evaluation report for class I device EU Medical Device Regulations 2
E Test report to certify compliance with IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 1
R Not every INCIDENT report will lead to a corrective action EU Medical Device Regulations 6
M Sponsor name presented in the test report EU Medical Device Regulations 4
P MedWatch Report from a hospital due to a quality issue US Food and Drug Administration (FDA) 5
E Any sample of a full software life cycle IEC 62304 report ( any class )? IEC 62304 - Medical Device Software Life Cycle Processes 1
B Struggling with using the 5.6 version Ford Capacity Analysis Report APQP and PPAP 5
M Documents to be included in 1.3 Material check in PPA report APQP and PPAP 4
S Regular updates of clinical evaluation report EU Medical Device Regulations 6
Sidney Vianna IATF 16949 News Update on the IATF CARA Project (“Common Audit Report Application”) - 12/2020 IATF 16949 - Automotive Quality Systems Standard 1
R Advice needed: Shall I report my not complying company to NB / competent Authority (Europe) EU Medical Device Regulations 6
P IQ, OQ, PQ protocol, and report templates for Distributed Control Systems in Pharmaceutical Manufacturing Systems. Qualification and Validation (including 21 CFR Part 11) 0
E Our company is planning to file MDD not MDR next month. Do we require to show chemical characterization report ? CE Marking (Conformité Européene) / CB Scheme 2
S Australia TGA Clinical Evaluation Report (CER) Other Medical Device Regulations World-Wide 0
B Biological evaluation plan and report Other Medical Device Related Standards 5
C 21 CFR 803 malfunction detected during packaging - report? Other US Medical Device Regulations 1
S Management Review (9.3) - Management Review Minutes/Report ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
M UDI procedure/ report 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
dgrainger Informational MDCG 2020:13 - Clinical evaluation assessment report template EU Medical Device Regulations 0
M Sample of Nonconformity report for ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Q Choosing Nonconformities to Report ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
M OEM asking for NC report after certification audit. IATF 16949 - Automotive Quality Systems Standard 3
D Test summary report example for design validation wanted - ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 1
D Safety Assurance Case Report Format ISO 14971 - Medical Device Risk Management 4
M Risk managment report of Surgical Mask Example ISO 14971 - Medical Device Risk Management 14
J Sub-supplier change from manual to automated process - same specs - Report to FDA? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
M Supplier Audit Report - Template for second party audit wanted Lean in Manufacturing and Service Industries 1
A Bench test report translation to English for 510(k) submission Other US Medical Device Regulations 2
G PMS Report - requirements EU Medical Device Regulations 2
F How to fill out an Appearance Approval Report (AAR) APQP and PPAP 0
dinakim_zv CB report or ILAC-MRA report ISO 17025 related Discussions 11
