Is an accident an 'incident' or a 'nonconformance?
samsung
One of the events recently triggered a debate during our last 'Safety Committee' meeting and the point of discussion was 'should we consider an accident as an 'incident' or a non-conformance ?
Will appreciate your response.
Regards,
Randy
It's a special kind of nonconformance unless incidents (accidents) are the norm and planned for. You still have to do everthing for an incident that you would for a nonconformance and a wee bit more. Employees must be involved in the investigation and the results of the investigation must be communicated back to relevant employees. Everything is detailed in 4.5.3, just do as it says and quit debating over nits.
samsung
Yes, it's a very good point which, as a matter of fact, was the point of argument and since accidents were never planned, one group wasn't in favour of considering them as NC's. The argument was "if it's a non-conformance, what's the requirement that wasn't fulfilled."
Since we have separate documented procedures for dealing with OHS incidents as well as for other OHS nonconformances and infact what triggered the debate was the overlapping of the two when someone reported the accidents as NC's to which the workers didn't agree. One of them argued that doing so would grossly depreciate their significance and might thus lead to detraction of management's attention especially during the annual budget planning. This seems to be a valid argument particularly in view of the fact that the term 'NC' often fails to attract the level of attention 'accidents' deserve to be paid.
I'm eager to know how others get along the way.
An accident is commonly used to describe an incident which has resulted in an injury.
An incident is any unplanned event resulting in or having the potential for injury, ill health, damage or loss
Accidents are not planned ? I thought bad quality products arent planned either but we give NC to non conforming products, right ;) In the same tone, all accidents, incidents and near misses are non conformances. In addiition, you have to report all ijuries to a statutory agnecy, so its a major non conformance requiring RCA, CA and PA.
From a safety perspective, non conformance is defined as any deviation from work standards, practices, procedures, regulations, management system performance etc. that could either directly or indirectly lead to injury or illness, property damage, damage to the workplace environment, or a combination of these.
samsung
Yes, to a point, I agree to your above statement but such a deviation, although a Nonconforming situation, may not necessarily result into an accident. On the other hand, a recorded accident, might not have resulted from any of the perceived deviations and hence, technically, it shouldn't be an NC irrespective of the fact that the event has resulted into significant injuries (accident). Ofcourse any of the situations must be thoroughly investigated to uncover the underlying deficiencies but the question remains is in what form such 'deviations' be accounted for and reported to provide a realistic view of the occurrence ?
If you go with the definition of ISO, a Non Conformance is non-fulfillment of a requirement. In that context, for example, if a person handling the forklift in the warehouse doesnot follow the work instruction of stacking properly, accidents could not happen. In this case, this is a non fullfillment of requirement.
Accidents do not happen automatically - it is said that for one major accident to happen, there are 300 no injury incidents, there is are 29 minor injuries and 1 major accident (study by Heinrich, 1950). Pl note that all the incidents and minor is a resultant of the drift in the practices that are often overlooked.
samsung
Nevertheless the accidents happen accidentally despite numerous controls and often the root causes are the ones that weren't either perceived beforehand or were beyond the control of the affected person and as such, it's very much difficult to establish the complete set of requirements against which the system could be evaluated.
Whether or not such events could be contentiously justified as nonconformances (per standard definition), the question is whether it is appropriate to equate accidents with other OHS nonconformances. If yes, how should I resolve the problem I'm currently confronted with ?
Duke Okes
I would classify an accident as an incident, and which most likely was the result of a nonconformance (e.g., either process wasn't followed or it wasn't sufficiently robust).
samsung
It means an 'incident' (accident) is an event supposedly (or otherwise) triggered by a non-conforming state but, in itself, is not a nonconformance. So the relation between the two is that of 'cause' and 'effect'.
Randy is also correct in his explanation. Accidents can be categorized as NC's if these are planned and the fact is no body does so.
Thanks,
Randy
OK guys, don't waste time debating this, that, I think, could be or any of that other dribble related stuff.....Look at the OHSAS Standard itself for the answer. Remember, once it is stated that it will be the method to manage OHS related risk and seek overall improvement in OHS performance it is:
1) Non-Negotiable
2) All inclusive...No exclusions
1st let's look at what an INCIDENT is as defined by OHSAS 18001:2007
3.9 incident
work-related event(s) in which an injury or ill health (3.8) (regardless of severity) or fatality occurred, or could have occurred
NOTE 1 An accident is an incident which has given rise to injury, ill health or fatality.
NOTE 2 An incident where no injury, ill health, or fatality occurs may also be referred to as a “near-miss”, “near-hit”, “close call” or “dangerous occurrence”.
NOTE 3 An emergency situation (see 4.4.7) is a particular type of
incident.
2nd lets look at what we have committed to in the OHS Policy
4.2 OH&S Policy
...b)...a commitment to prevention of injury and ill health...
Having an accident/incident/injury in the workplace is in fact a failure to meet a specified requirment and committment in the policy and is a nonconformity ....failure to fulfill a requirement...
Now when it comes to INCIDENT INVESTIGATION in 4.5.3.1 we see among other things...
a) determine underlying OH&S deficiencies and other factors that might be causing or contributing to the occurrence of incidents;
b) identify the need for corrective action;
Except for an act of nature or God, depending upon how the organization likes to express this, incidents (accidents) occur by one of two reasons...
1) an unsafe condition (most of which are created by #2 below)
2) an unsafe act
Both #1 & #2 are situations that must be corrected if conformance to policy committment of "...prevent..." has any hope of being achieved.
Remember guys...in the systems approach to management conformance to elements of the system requirments are necessary to help meet conformance to other elements (Input-Activity-Output)
J Circadian Software Accident/Incident Analysis Business Continuity & Resiliency Planning (BCRP) 2
C Accident And Incident Investigation and Report procedure example wanted Miscellaneous Environmental Standards and EMS Related Discussions 6
D Accident reporting categories Occupational Health & Safety Management Standards 1
A 3 scenarios of accident and I want to apply OHSAS18001 Occupational Health & Safety Management Standards 2
B Combining a CAR, an NCR, and an Accident Report ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
T Is "World Class" Quality possible by Accident? Coffee Break and Water Cooler Discussions 18
B KPI = 0 - Accidents (Actual accident is 150 case/year) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
P Impact to Japan's medical device export after the nuclear power accident Other Medical Device and Orthopedic Related Topics 3
somashekar First Aid Use Records vs. Accident Records Occupational Health & Safety Management Standards 30
6 Vehicle Accident Investigation Program - Integrated compliance audit Occupational Health & Safety Management Standards 9
D A true example of CAPA - Accident that show its cause and the corrective action Nonconformance and Corrective Action 8
Stijloor Dutch Accident Photo - Not For The Faint Of Heart Funny Stuff - Jokes and Humour 13
Howard Atkins If I eavesdrop by accident during an Audit should I react? General Auditing Discussions 13
Zafortner EU Manufacturing Incident Report (MIR) version 7.3 ISO 13485:2016 - Medical Device Quality Management Systems 9
R Not every INCIDENT report will lead to a corrective action EU Medical Device Regulations 7
M Vigilance - incident found in an article EU Medical Device Regulations 4
F Risk for Quality Assurance Department in a Hospital - Hospital Incident Reporting ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Informational EU – Manufacturer incident report (MIR) for serious incident- template 2020 (Directives and new regulations) version 7.2 and related documents Medical Device and FDA Regulations and Standards News 2
M Informational TGA – Medical device incident reporting (MDIR) guide Medical Device and FDA Regulations and Standards News 0
I How to handle pending FSN when incident happens? EU Medical Device Regulations 1
M Informational Manufacturer Incident Report (MIR) for Serious Incidents (MDR/IVDR) and Incidents (MDD/IMDD/IVDD) Medical Device and FDA Regulations and Standards News 5
JoCam Incident Reporting MHRA (Medical & healthcare regulatory agency) EU Medical Device Regulations 3
E Incident Report or Nonconformance Report for Equipment Failure? Quality Manager and Management Related Issues 5
L OHSAS 18001 Participation and Consultation - Incident investigation under 4.4.3.2 Occupational Health & Safety Management Standards 15
A Customer Complaint - Incident Reporting Hardcopy Signoff Customer Complaints 8
V Is non-conformance (incident) required for any observation in equipment qualification Nonconformance and Corrective Action 5
V How long can a development stage incident be open? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 4
S Incident Investigation Procedure for Critique Document Control Systems, Procedures, Forms and Templates 3
M What Indicator should we use to follow Incident Containment Nonconformance and Corrective Action 2
T Information System Security (infosec) Incident Form - Looking for samples IEC 27001 - Information Security Management Systems (ISMS) 4
V Should there be a incident/deviation for breakdown or missed calibration date? Nonconformance and Corrective Action 10
Richard Regalado ISO 27035:2011 Infosec Incident Management - Hot Off the Grill! IEC 27001 - Information Security Management Systems (ISMS) 0
P Incident Reporting or a Complaint? IEC 27001 - Information Security Management Systems (ISMS) 9
K Incident Investigation vs. Root Cause Analysis ? What?s the difference? Customer Complaints 16
Marc Stuxnet: The Curious Incident of the Second Certificate After Work and Weekend Discussion Topics 3
S Qantas Airbus incident - What really happened? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
P Transparency / Reciprocity - Medical device incident reported in the EU 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
L Looking for Incident/Change/Problem Management Audit Checklist Document Control Systems, Procedures, Forms and Templates 3
A Looking for an FDA MDR/Incident Report Decision Tree ISO 13485:2016 - Medical Device Quality Management Systems 6
C Safety issue help - Request a Corrective Action (CA) for Safety Incident? Preventive Action and Continuous Improvement 9
M ISO 14001 Incident Reporting Procedure ISO 14001:2015 Specific Discussions 6
M Questions concerning QMS and/or company specific nonconformance Customer Complaints 2
N Nadcap AC7101/2 Rev. E Section 3.2 - Nonconformance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
T Internal Nonconformance procedure thoughts (AS9100) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
C NCR (Nonconformance System) Software Nonconformance and Corrective Action 7
L How to deal with an ISO 13485 Supplier Audit nonconformance ISO 13485:2016 - Medical Device Quality Management Systems 17
E When to generate a nonconformance report ISO 13485:2016 - Medical Device Quality Management Systems 6
K Counterfeit parts prevention - Audit Nonconformance - AS9100 8.2.2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 25
qualprod When to write up a nonconformance and require a NCR - We produce labels ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
