Is an Annual Supplier Evaluation an ISO 9001 requirement?
Selina L
I work in a small company ,and the product here is simple ( product for brazing and soldering ) .Till now ,we have no supplier annual evaluation ,and we defined in the quality procedure files to monitor the supplier performance by raw material quality .We defined the incoming material pass rate as IQC goal ,and ask the suppler for improvement when the goal is not meet .It that OK for ISO requirement ,we only monitor the supplier raw material quality performance ,and have no supplier annual evaluation .Thanks !
insect warfare
QA=Question Authority
Re: Whether the annual supplier evaluation is a must for ISO requirement?
Welcome to the Cove, Selina....:bigwave:
What you are doing is just fine according to ISO. The answer you are looking for can be found in paragraph 7.4.1, which states:
"The organization shall ensure that purchased product conforms to specified purchase requirements. The type and extent of control applied to the supplier and the purchased product shall be dependent upon the effect of the purchased product on subsequent product realization or the final product.
The organization shall evaluate and select suppliers based on their ability to supply product in accordance with the organization's requirements. Criteria for selection, evaluation, and re-evaluation shall be established. Records of the results of evaluations and any necessary actions arising from the evaluation shall be maintained (see 4.2.4)."
ISO does not require an annual evaluation, but rather it enables you to place a greater amount of control on more troublesome suppliers, and less control on those suppliers who have less of an impact either downstream or on finished goods. Having appropriate records of IQC data to demonstrate that you act in response with your suppliers' behaviors is just one way of meeting this requirement.
Brian :rolleyes:
Big Jim
May I add that the sentence before the one emphasized by insect warfare is also pertinent here.
"The type and extent of control applied to the supplier and the purchased product shall be dependent upon the effect of the purchased product on subsequent product realization or the final product."
Figure out what works for you, not what some other companies may need for their circumstance. What you have in mind sounds just fine for your current operations. Realize that more may be needed if circumstances change, and that the more needed can be for individual suppliers or individual purchased products.
Selina L
Hi Brian ,
Thanks very much for your quick reply ! And it is really help to me.But I still a little confused for the standard :
According to the ISO standard ,we need to established the criteria for re-evaluation the supplier .How to perform this in normal situation ? For our company we select the suplier by three means :1 . If the supplier have ISO certificate ,can be accept as AVL .2. If the suppler have no ISO certificate ,but the material have been approved by us .can be accept as AVL.3. If the supplier is appointed by the cusomer ,can be accept as AVL .
We have defined the criteria for selection and evaluation the suplier ,but no criteria for re-evaluation . Is that ok for ISO requirment ?
Thanks !
selina
insect warfare
:rolleyes:
Thanks !
selina
The criteria for re-evaluation should be similar to your criteria for evaluation, but it should also take into account how well that supplier is performing, relative to the present day. It should determine to what extent you would be willing to tolerate nonconforming situations for which your suppliers are responsible for. For example, if you have a supplier who has, up until recently, been performing above your expectations, but for the last couple of weeks you have had to increase your inspection AQL to filter out the good stuff they send you from the bad stuff, then you probably have a legitimate beef with them (which should be addressed through your corrective action process).
At this point, you are basically "re-evaluating" your supplier. Re-evaluation can be done at a pre-determined frequency as a preventive action (through the use of questionnaires and such), but it is equally (if not more) important to have reactive measures as well. Your re-evaluation criteria should definitely determine "at what point do we start tightening our grip on them" and "at what point have they crossed the line enough for us to say we will have to find an alternative source for these materials". It is a form of leverage that any successful organization will have controls for, otherwise they lose money and wind up becoming a doormat for their suppliers to walk all over.
If you do not have re-evaluation criteria, you will not be in conformance with ISO 9001....period.
Brian :rolleyes:
Tara Monson
Hi Brian ,
Thanks !
selina
Selina,
We simply state in our procedure that monitoring of our suppliers occurs on a monthly basis by looking at nonconforming product received and on-time delivery. It states if either of those numbers falls below a certain %, reevaluation will occur by the Quality Director.
For service providers, we simply send out a survey 1x/year to the department who utilizes each service provider and enter the feedback into the same log as the above information.
This data is then discussed at management reviews.
We just passed our stage 2 audit with no nonconformances and was told by our auditor that this was very strong.
Good luck! :)
Tara
Big Jim
Re: In an Annual Supplier Evaluation an ISO 9001 requirement?
To at least some extent, if you are monitoring supplier performance (supplier on-time delivery and/or supplier accuracy) with every shipment, you are continually re-evaluating your suppliers.
You get to define how and when you re-evaluate.
somashekar
Selina...
Have a look at the Similar Discussion Threads just down this page ~~~
K
kgott
Hi Brian ,
If you are happy with what they have done for you then they remain approved to continue to be a supplier for as long as you are happy with them. If a reason comes along that causes you to be dissatisfied with them then you can either discontinue using them or take some other action.
You may choose to say in your documentation that they remain approved subject to a range of flexible criteria such as ... xyz.
S What questions to ask in annual supplier evaluation? ISO 13485:2016 - Medical Device Quality Management Systems 3
R Format that can be used to get supplier SPC annual work plan - Seeking Supplier Quality Assurance and other Supplier Issues 2
I Do I need to sign off my annual audit calendar? Internal Auditing 2
S Annual Inspection Layout - Based on Customer print ? IATF 16949 - Automotive Quality Systems Standard 8
K Updated MSA with the Annual PPAP validations APQP and PPAP 8
P ISO Class 8 particle count (annual certification vs monitoring) ISO 13485:2016 - Medical Device Quality Management Systems 4
E Annual PPAP+ deviation request ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A Question on ISO 14001:2015 - Are annual audits required? ISO 14001:2015 Specific Discussions 11
JoCam Increase to bi-annual ISO 13485 audits ISO 13485:2016 - Medical Device Quality Management Systems 2
S Is Annual QMS Training Required? ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
M Informational Medicines and Healthcare Products Regulatory Agency Annual Report and Accounts 2018 to 2019 Medical Device and FDA Regulations and Standards News 0
M Informational TGA – Medical device annual reporting – Sponsor obligations Medical Device and FDA Regulations and Standards News 0
S Is an Annual Layout Inspection the same as an Annual Re-validation? Internal Auditing 1
M Informational FDA Invites You to the 2019 Regulatory Education for Industry (REdI) Annual Conference Medical Device and FDA Regulations and Standards News 0
S Post Market Surveillance and Annual Product Review in ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 2
qualprod Annual SWOT for 4.1? I plan to revise quality objectives and strategic route ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
qualprod ISO planning annual meeting? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
JoshuaFroud CDRH Annual Report - eSubmitter Other US Medical Device Regulations 0
B Does anyone charge for annual layouts? APQP and PPAP 8
V How to Add Annual Revalidation requirements to Control Plan? FMEA and Control Plans 5
K Is an annual "audit schedule" the same thing as an audit scope/ audit plan? Internal Auditing 8
M Annual Layout requirements for PPAP/Control Plan FMEA and Control Plans 6
W "On An Annual Basis" - Definition ISO 13485:2016 - Medical Device Quality Management Systems 12
D FDA Guidance Document for Preparing Annual Product Reviews US Food and Drug Administration (FDA) 2
Q FDA - Annual Report Submission Format and QMS updates Other US Medical Device Regulations 2
R Registrar Annual Management Fee Registrars and Notified Bodies 4
F ISO/TS 16949 internal audit scope and annual plan Internal Auditing 2
B Annual Internal Inspector Certification Training - Internal, External, Online and Distance Learning 4
D Annual Layouts in Control Plans FMEA and Control Plans 5
T Clause 7.4.1.2 - Evidence of annual assessments for all non-TS Suppliers IATF 16949 - Automotive Quality Systems Standard 16
K Bi-Annual ISO 9001 Surveillance Audit Help ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
R QMS changes before Annual External Audit Quality Manager and Management Related Issues 8
M Do QC inspectors need an annual eye exam according to API Q1 Oil and Gas Industry Standards and Regulations 22
J FDA Annual Product Review (APR) Requirements US Food and Drug Administration (FDA) 1
J Annual Reporting requirements to Health Canada Canada Medical Device Regulations 9
J PPAP (Production Part Approval Process) Requirements for Annual Revalidations APQP and PPAP 1
Y Training Plan/Schedule - Can anybody share a format or template for annual training Training - Internal, External, Online and Distance Learning 8
SATHYABALARAMAN ISO Systems Annual Report to Top Management example wanted IATF 16949 - Automotive Quality Systems Standard 10
V Annual Performance Appraisal - Person vs. Function/Business Career and Occupation Discussions 5
S Annual Stock Check - Where to add it into our Quality Manual? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
5 Missed Annual Business Goals and Objectives IATF 16949 - Automotive Quality Systems Standard 5
B TS16949 Annual PPAP Submission Requirements for Ford and Chrysler Parts IATF 16949 - Automotive Quality Systems Standard 2
K AS9100 Implementation, Registration and Annual Costs to maintain Registration? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
J Annual PPAPs - Keeping Up with Hundreds Of Customers And Hundreds Of Part Numbers APQP and PPAP 12
K Does Australia require any annual registration or license renewal for Medical Devices Other Medical Device Regulations World-Wide 1
K Annual License or Registration Requirement for Europe (MDD 93/42 EEC) EU Medical Device Regulations 1
A SOP for performing Annual Product Reviews for Medical Device and Pharma Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
D How to Update Annual Quality Objectives Annually? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
I Does TS 16949 clearly require an annual product re-validation? IATF 16949 - Automotive Quality Systems Standard 17
