Is an index necessary for DMR or DHF?
snoopy2017
Is an index necessary for DMR or DHF? In one of the companies, their SOP requires a DMR index but that has not been done. I don't think this is a requirement by regulations. Please clarify.
Sam Lazzara
I have not yet come across a medical device regulation or standard the requires an index for Device Master Records, Design History Files, Medical Device Files, Risk Management Files, Usability Engineering Files, or any type of file for that matter.
What is unfortunate is that since many companies maintain such indexes, auditors are accustomed to seeing them, and therefore they ask for them. That, of course, does not mean there is any such requirement.
Just another case where we need to direct our attention to "reading the words" in the regulations/standards, and avoiding over-interpretation.
And just because you have a controlled "index" does not mean the associated file is complete, appropriate, etc. It just means you have an index.
yodon
I agree with all that except with respect to the DMR. I'm not sure how you would effectively establish a DMR without a snapshot ('index'). I guess you could dump a lot of info into the DHR but that seems rather inefficient.
Maybe I'm not thinking outside my box. I'd be interested in hearing approaches without a DMR index.
Sam Lazzara
Yodon, here is my method for ensuring that I have a complete DMR without needing to have a formally document-controlled index. I admit that my approach is unusual, but it works for me.
My document control SOP only allows controlled documents to go to "Full Release" - Rev A in my case, if all supporting lower level documents are also at Rev A or higher. Therefore, if my finished device specification (aka design output specification) is at Rev A+, then based on following that SOP, all lower level documents must be at Rev A+.
Typical audit scenario would be as follows.
AUDITOR: Show me your DMR index.
ME: I can show you our DMR but we do not require an index to be maintained.
AUDITOR: Ok, show me your DMR then.
ME: Ok, the DMR for what finished device? (REF/Catalog Number)
AUDITOR: REF 1234
ME: Ok, here is the top-level DMR document for DMR REF 1234.
AUDITOR: The DMR is just that document?
ME: No, the DMR is a compilation of documents containing the procedures and specifications for a finished device. If you want to see the entire DMR for REF 1234, you need to keep asking me for documents. You will notice in the top-level DMR document I just gave you, there are references to other lower-level parts and associated documents. You can review each of those documents, and those documents, in turn, may reference even lower-level documents.
AUDITOR: Ok then, let's keep going. Show me all of the documents referenced in the top-level DMR document.
ME: Ok. And as I show you each of those documents, you can request lower level referenced documents if you wish.
AUDITOR: Great! And by the way, this is pretty strange since most companies maintain a DMR Index, but I see now that there is no specific requirement to do so.
ME: It is a pain in the arse to maintain a "living" DMR Index document.
Sam Lazzara
The top-level DMR document is your finished device design output specification. It should include all packaging and labeling requirements, and directly provide or reference the device bill of materials. It can be a word-processing document with embedded drawings, or a CAD drawing with detailed notes or references to other specification documents.
Something I did not mention earlier - I do believe in having a design review deliverable called a DMR Status Report that provides the status for the DMR documents (and lists all of them and their current revision status at the time of the report). This is a "snapshot" deliverable, and is not regularly updated. It is a required deliverable for any design reviews that allow human use of the devices. My reasoning is that at those design reviews, we need to have evidence the DMR documents are at "full release" (Rev A or higher, for example) and build human-use devices utilizing that DMR. Once the DMR is at full release, the document control SOP ensures it stays that way.
yodon
Thanks, Sam. That's quite similar to what I do and I can see that it would support being able to demonstrate the devices were built per the DMR.
S Audit Finding - Design History File (DHF) Index: few (3 to 4) reports not identified ISO 13485:2016 - Medical Device Quality Management Systems 3
PQ Systems Cpk: Indispensible Index or Misleading Measure Using SQCpack Software 0
C KAPPA index Reference Value for Visual inspection IATF 16949 - Automotive Quality Systems Standard 1
C Document Index Document Control Systems, Procedures, Forms and Templates 5
B ISO 8536-4 Contamination Index ISO 13485:2016 - Medical Device Quality Management Systems 0
E Is there an Automotive Customer Complaint Index? IATF 16949 - Automotive Quality Systems Standard 3
I As a part of validation, should i include the acceptance criteria of CPk index >1.33? Qualification and Validation (including 21 CFR Part 11) 4
S DMR (Device Master Record) Management and Index questions Other US Medical Device Regulations 18
U Document Revisions Required in DMR Index? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
G Where to get a NIST Traceable Master Glass Refractive Index Sample General Measurement Device and Calibration Topics 5
D ?Pa? Capability Index - Has anyone ever heard of this? Capability, Accuracy and Stability - Processes, Machines, etc. 5
C Quality Manual Index in Endless Loop Quality Management System (QMS) Manuals 7
A Coke Reactivity Index (CRI) Testing Code Interpretation: ASTM D5341-99 (2004) Various Other Specifications, Standards, and related Requirements 2
optomist1 Converting Defect Rate To Capability index Capability, Accuracy and Stability - Processes, Machines, etc. 11
J ISO13485 File-Index getting too large Document Control Systems, Procedures, Forms and Templates 2
M Customer Conversion and Retention / Satisfaction Measurement Index Benchmarking 4
S Need Help Calculating and Implementing Cs - Wright's Index Statistical Analysis Tools, Techniques and SPC 11
D DMR (Device Master Record) Index as a Controlled Document 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
W Acceptable Risk Index - What is acceptable? ISO 14971 - Medical Device Risk Management 1
S Auto-Correlated Data and Capability Index Quality Tools, Improvement and Analysis 5
M Creating an Index for our Documents - Imaging Millions of Paper Records Document Control Systems, Procedures, Forms and Templates 13
Ajit Basrur Corruption Perception Index (CPI) 2010 Coffee Break and Water Cooler Discussions 2
N How to Number (Identify) and Index Forms Document Control Systems, Procedures, Forms and Templates 1
C Supplier Performance Index (Spi) - Supplier Rating Supplier Quality Assurance and other Supplier Issues 10
I Calculating the CSI (Customer Satisfaction Index) Misc. Quality Assurance and Business Systems Related Topics 17
V Feasibility Index and Prioritization Index - Concepts and Terms FMEA and Control Plans 2
F R-sq index in Linearity study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
C Validate the idea of a Composite Performance Index Quality Tools, Improvement and Analysis 4
S Validity of Craig Hane's Global Local Index for X-bar R Chart Assessment Capability, Accuracy and Stability - Processes, Machines, etc. 3
G How to Measure MFI (Melt Flow Index) of Materials up to 1500 MFI? Reliability Analysis - Predictions, Testing and Standards 6
S Cpkm capability index: Make sense when the target is the lower tolerance limit? Statistical Analysis Tools, Techniques and SPC 9
J Heat treatment inspection and Process capability index Cpk Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
R Capability Index for Furnaces - CQI-9 Assessment Capability, Accuracy and Stability - Processes, Machines, etc. 1
R How to measure Machine Capability index Cpm Statistical Analysis Tools, Techniques and SPC 1
R Company and Department Key Performance Index (KPI) IATF 16949 - Automotive Quality Systems Standard 16
Marc Google URL Index Hits 1 Trillion World News 6
S Index Years in Regression Models Statistical Analysis Tools, Techniques and SPC 3
D Employee satisfaction Index Statistical Analysis Tools, Techniques and SPC 5
K Question on Cp index - Calculating and Interpreting Cp and Cpl. Statistical Analysis Tools, Techniques and SPC 6
G What does a Process Capability Index of greater than 1 suggest? Capability, Accuracy and Stability - Processes, Machines, etc. 3
S Staff Augmentation Vendor (Supplier) - Performance Evaluation (rating & index) Supplier Quality Assurance and other Supplier Issues 9
P Plastic Identification/Test - Melt Flow Index to Determine Correct Material? Manufacturing and Related Processes 16
R Including Internal Metrics in the Calculation of Customer Satisfaction Index (CSI). IATF 16949 - Automotive Quality Systems Standard 4
S What Capability Index should I use? SMT Application Capability, Accuracy and Stability - Processes, Machines, etc. 13
A Customer Satisfaction - How to calculate CSI (Customer Satisfaction Index) Misc. Quality Assurance and Business Systems Related Topics 42
K Using the Predictive Index for Job Candidates Career and Occupation Discussions 14
C Composite Process Capability Index - Cpk is not additive Capability, Accuracy and Stability - Processes, Machines, etc. 3
QChas The Source of "C=0 Sampling Plans Index Values (Associated AQLS)" AQL - Acceptable Quality Level 3
V Machine short term capability study with Cmk index in automotive industry Capability, Accuracy and Stability - Processes, Machines, etc. 3
V Quality Control Index - We thought that Cpk or Ppk would be good choices Capability, Accuracy and Stability - Processes, Machines, etc. 6
