Is ANOVA Gage R&R the best method? Reproducibility issues (no inspector effect)?
Rob Nix
I need help! (yeah, yeah, I've needed it for a long time; right :vfunny: )
Anyway, a potential new customer has provided us with their specifications during contract review, and as part of their acceptance plan are requiring the following:
An ANOVA style Gage R&R (re: AIAG MSA) must be conducted on 20 parts, 5 repetitions each (randomized). There doesn't appear to be any reproducibility issues (no inspector effect). I am just wondering if this is the best approach or if another method would work better. Any thoughts from the panel of experts??? :confused:
NOTE: They also require we use Minitab (which we do not have) but allow for us to submit/recommend a different software and/or method.
Al Dyer
If the customer is looking for an ANOVA R&R with the use of specific software I would tend to believe one of 3 things:
1: The gage man has stock in Minitab,
2: The gage people are not sure what they are looking for,
3: Their customer has the same requirement.
Surely not an expert on ANOVA myself, I would invite Atul to take a look at your situation.
Al...:biglaugh:
Atul Khandekar
Apart from the 3 Al mentioned, I can't think of any reason for mandating 20 parts in an R&R study. ( More the merrier?). Also I would like to know the rationale for 5 repetitions. One reason could be reduce the margin of error by averaging more values. But this would probably mean that the measurement process is too complex and that repeatability may be in doubt. Why not do a standard 10x3x3 ANOVA? ANOVA is prefered over Range-Average because it would bring out interactions, if any. This may also provide evidence that reproducibility is not an issue.
Also, as Rob has said, if the reproducibility is really not an issue, I think a simple P/T ratio or the Raffaldi method (that has been discussed here before) should be sufficient. (You can download the GRR freeware from my website for this.)
Rob Nix
Atul,
Thanks for the validation of my thoughts on this. :agree: Earlier today, I sent the proposals engineer a paragraph to add to the proposal that suggests using a standard 10X3 or P/T ratio, to be reported on using MS Excel (not Minitab). I might also add, your software.
p.s. Thanks for the freeware. :bigwave:
sbickley
Can you direct me to the freeware referenced in this thread? This would benefit me as well.
Thx
G
Graeme
Thx
If you click on Atul's name in his post you will open his public profile. The web site link is in there.
GCP
Govind
If I may add to Atul's reply;
I prefer ANOVA method for its ability to determine the effects and its significance.
Here is an example of MiniTab ANOVA method Gauge R & R results:
Two-Way ANOVA Table With Interaction
Source DF SS MS F P
Part 9 2.05871 0.228745 39.7178 0.000
Operator 2 0.04800 0.024000 4.1672 0.033
Part *
Operator 18 0.10367 0.005759 4.4588 0.000
Repeatability 30 0.03875 0.001292
Total 59 2.24913
F- Determines if the effects of Operator, Part, or Operator*Part significantly impact the measurement.
P-value associated with F. P Part, for example, is the probability of seeing an F statistic as large or larger than the calculated one, assuming that all parts share the same mean. So as F gets larger, P gets smaller. A small P implies that the assumption of all parts sharing the same mean is probably not true.
This information is valuable for decision making.
Regards,
Govind.
Note: Forum experts, please suggest ideas to align the table value? Looks ok during editing, but misaligned after posting :mg:
sbickley
Govind,
Can you also provide a legend for your other headings such as DF, SS and MS?
Thanks,
Scott
cyding
G R&R
Hi, I have just registered to this web page few weeks ago. I find it very useful.
At this moment, I do not how to raise a new thread. Anyway, the topic is still G R&R.
I am wondering, how should we choose the samples for G R&R study. Can we pick randomly from the production or specially made some samples that fall within and slightly out of specification samples for G R&R study?
From my experience, the randomly pick samples will tend to have high G R&R value. Therefore, we tend to choose samples that will have wide range (for example : lower side of the spec, middle of the spec & higher side of the spec). Generally, we want to create high part-to-part variation to get better G R&R value.
Is it wrong, we conduct G R&R in this manner?
Thank you.
B How to perform a MSA - GRR (Gage R&R) A&R/ANOVA Vs GUM/VDA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R P-value and interpretation of ANOVA Gage R & R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
L What is the the difference between the Gage R&R Nested Anova and ISO/REMCO N263? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S Anova Gage R&R Calculations for 4 Operators Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
G GR&R (Gage R&R) Anova versus Xbar Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
J Variation (using ANOVA method) Required for Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
I Minitab ANOVA Gage R&R Error (vs. EXCEL ANOVA GRR Calculation) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
Rameshwar25 GRR (Gage R&R) Nested Anova Method Example Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 40
L Good Excel .xls sheet for Gage R&R that calculates both Anova and Range Excel .xls Spreadsheet Templates and Tools 9
Rameshwar25 Gage R&R Anova - With Interaction or without Interaction? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B Study Variation and Discrimination Ratio in Gage R&R ANOVA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
E Gage R&R or Anova two way? Using Minitab Using Minitab Software 1
R Gage R&R Anova Method - Study Variance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
S p-Value(s) for Anova (Crossed) GRR (Gage R&R) Studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
C Excel spreadsheet containing Gage R&R with Anova Method wanted Excel .xls Spreadsheet Templates and Tools 22
R Interpreting Gage R&R (2 Way ANOVA) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
E Successful Gage R&R Anova or X/R? Need example Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
S Gage R&R Methods - ANOVA, AIAG, 6sigma Xbar/R, GM - Which to Use Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
C Sample Size of GR&R (Gage R&R) on Nested Anova Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
P Gage R&R Anova Report Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
C GR&R (Gage R&R) Anova spreadsheet is telling us that a gage is not working Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
R Gage R&R - Anova Method - Standard Deviations vs. Variances Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
T Variables Gage R&R - Minitab v14 - F statistic Calculation - ANOVA - Methods validity Using Minitab Software 2
B ANOVA Gage R&R % Tolerance and Preference Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
F Minitab 19 Anova or X bar # of distinct catagories Using Minitab Software 1
E Input to ANOVA 1-WAY - How can I perform this analysis in minitab? Using Minitab Software 2
J Which Anova dropdown to use for R&R in Minitab? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B WEDM Taguchi and Anova Analysis - L16 array with 5 parameters at 4 levels Manufacturing and Related Processes 5
F How to make an ANOVA of a design with repeats (not replicates) in Minitab? Using Minitab Software 18
H Taguchi mixed model DoE [L16 (4^3 2^6): factors interaction and ANOVA calculation Using Minitab Software 3
S Taguchi Design with ANOVA - 3 factors each with 3 levels Quality Assurance and Compliance Software Tools and Solutions 13
E GR&R ANOVA 3rd Factor for Fixture Nests Using Minitab Software 3
N ANOVA vs 2 sample t-test Statistical Analysis Tools, Techniques and SPC 6
F Help me understand the ANOVA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
F Post Hoc test for two way ANOVA Using Minitab Software 9
E ANOVA for Taguchi method - Four factors and three levels and nine runs (Minitab) Using Minitab Software 6
M ANOVA for S/N ratio gives different results Statistical Analysis Tools, Techniques and SPC 5
T Minitab Two-way Anova example (EXH_AOV.MTB) Quality Assurance and Compliance Software Tools and Solutions 1
S ANOVA/Regression - Analyzing a Dataset which contains over 4500 Points Using Minitab Software 3
P Taguchi Anova Error with Minitab Using Minitab Software 9
J Why doesn't ANOVA Method take the specification into account when determining GR&R % Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
F Fully nested ANOVA: A missing p-values (Minitab) Using Minitab Software 11
S Regression Analysis / ANOVA using Excel Excel .xls Spreadsheet Templates and Tools 2
C GR&R MSA-4 ANOVA Excel Template Verification Check wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S ANOVA and Test Method Validation for a Drug Delivery Device Statistical Analysis Tools, Techniques and SPC 4
L How is the interaction physically happening while performing ANOVA GR&R? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
E Using ANOVA during the PQ Validation Run to evaluate Statistical Differences Statistical Analysis Tools, Techniques and SPC 4
M Understanding of Regression and ANOVA in Minitab Statistical Analysis Tools, Techniques and SPC 8
