Is any dissatisfaction over a Medical Device considered as a complaint?
SGquality
We have a customer satisfaction survey that in addition to feedback also resulted in certain dissatisfaction over the product - would this be considered a customer complaint? How do companies handle these situations - via Customer Complaint process or CAPA process or any other? Thank you!
Sidney Vianna
Post Responsibly
What is the CONTEXT? What type of products? As mentioned numerous times here, in the FDA Medical Device regulated sector, ANY negative feedback, must be treated as a complaint and processed accordingly.
Without CONTEXT and ENVELOPE CONDITIONS, one can only guess....
I work with a direct-to-consumer and retail Class II medical device manufacturer that gets literally several hundred "customer inquiries" a month. We cull them based upon a very, very simple concept of a "Complaint" by customer service reps. That definition of a "Complaint" is similar to the one shown above, but with more details added to product-specific situations. When it doubt, they get tagged. These culled out Complaints then get further analyzed for reportability by dedicated quality staff and investigated as necessary.
I disagree with Sidney that ANY "negative feedback" is a Complaint. For example, someone that straight-up buys the wrong product for their use ("my spoon doesn't make a good fork!"), or the wrong size--those aren't Complaints. The key is that the feedback must allege "deficiencies [...] of a device." Of course, when in doubt just call it a Complaint and handle according to your Complaint process, it's not a big deal.
Regarding CAPAs, your Complaint process should have very clear guidelines for when a Complaint must be escalated to a CAPA and I'd also recommend adding some guidelines for when it's recommended, such as:
  • The Complaint has a similar cause to any other Complaints within the last year​
  • There is no easy/specific correction.​
  • The device failure was severe/catastrophic.​
  • The cause is a design-level issue.​
  • The cause is a manufacturing issue.​
This is essentially verbatim from the slideshow Sydney posted from above, the entirety of it can be found here:
Search for "cdrh-industry-basics-workshop-nonconforming-product-and-complaint-files-november-7th-2017"
Hope this helps,
Josh
Cthames
Not all negative feedback constitutes a complaint. If a customer says that your product is too expensive, that would not be a complaint. If the customer says they don't like the color of the product, but the product's color as never specified in the order agreement, that is not a complaint.
The picture you posted with 820.3's definition of a complaint is the resource I would point to if someone is trying to determine whether or not negative feedback constitutes a complaint.
In the modern era with so many streams of information, to me the definition of a Complaint is much less interesting (i.e., it's very clear-cut) than how you monitor the various streams through which Complaints can be communicated. I think this cuts to the core of the OP's original question.
At the end of the day, you should be routing Amazon reviews, Facebook responses to your marketing posts, etc. through your Complaint handling process, if the content meets the definition of a Complaint. This also means your social media/CX/brand management folks need to have documented training on what constitutes a Complaint and there needs to be a documented process for routing those types of communications to relevant quality personnel within the organization for analysis and investigation.
The main problem here is, e.g., with Amazon they own the customer so you cannot really engage in normal investigative practices. Make sure you copy and paste and/or screenshot the complaint itself because, e.g., with Facebook posts they very quickly get lost in a massive sea of other posts which makes finding the original content impossible even just a few weeks later when doing a more detailed investigation/evaluation of the Complaint.
Cthames
To clarify on my last post, I make a distinction between evaluating negative feedback as to whether or not it is a complaint, and handling it as a complaint. All negative feedback should be evaluated as to whether or not it is a complaint. Only negative feedback which meets 820.3's definition of a complaint is required to be handled and processed as a complaint.
C Senior Management and Customer Dissatisfaction ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Customer Satisfaction vs. Dissatisfaction ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
B Customer Satisfaction and Dissatisfaction Measurement QS-9000 - American Automotive Manufacturers Standard 29
M Can you import medical device not FDA approved into the USA under an IND application? US Food and Drug Administration (FDA) 2
M Custom made class 1 Medical devices EU Medical Device Regulations 3
A Algorithm As a Medical Device IEC 62304 - Medical Device Software Life Cycle Processes 3
A Medical Device Software POC Medical Device and FDA Regulations and Standards News 6
V Can we use hyperlinks in the Medical documentations? US Food and Drug Administration (FDA) 2
K Brazil (INMETRO) for Medical Electrical and IVD Equipment? Other Medical Device Regulations World-Wide 0
G Need Help with Run @ Rate for Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 0
Y Brazilian lab requirement for medical device manufacture Other Medical Device Regulations World-Wide 1
S ISO 14644 Cleanrooms: Industry-Specific Requirements for Medical Devices Other Medical Device Related Standards 0
W Medical Device - fixture qualification and MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
H Medical Device Labelling ISO 13485:2016 - Medical Device Quality Management Systems 11
D One Software as Medical Device product or two? EU Medical Device Regulations 3
R How to find the proper the fieids of IVD distributers and develop the medical device markets in Thailand? Manufacturing and Related Processes 0
K Regulatory Aspect of Embedding 4G/5G communication technologies into medical device IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
I Post-market surveillance and Post-market performance follow-up for in vitro diagnostic medical devices EU Medical Device Regulations 0
M FDA Medical device reporting (Manufacturer in US; contract manufacturer OuS) US Food and Drug Administration (FDA) 0
JoCam Accessories for medical devices EU Medical Device Regulations 5
G Medical Device Auditor (CMDA) certification exam by ASQ - looking for input Career and Occupation Discussions 3
M Prescription Form - Medical Devices US Food and Drug Administration (FDA) 1
XRAY_3121 Drop Shipping Legend Medical Devices Other Medical Device Related Standards 0
B Documenting Medical Device Complaints after End of Life? Medical Device and FDA Regulations and Standards News 0
M Medical Device License as Distributor Canada Medical Device Regulations 8
M Preparing a document for Raw Material of Medical Device EU Medical Device Regulations 1
R Medical device regulations in African countries Other Medical Device Regulations World-Wide 0
Jessesun The application of ozone sterilization in medical treatment US Food and Drug Administration (FDA) 0
A Production line for medical devices Other Medical Device Related Standards 1
S Design & Development records for Medical Devices Packaging and Labelling ISO 13485:2016 - Medical Device Quality Management Systems 8
K MHLW MO169 2021 Japan Ministerial Ordinance on Standards for Manufacturing Control and Quality Control for Medical Devices and In-Vitro Diagnostics Japan Medical Device Regulations 2
U Medical Devices Labeling Medical Device and FDA Regulations and Standards News 0
K Guidance on X-Ray Medical Devices for Animal Use - FDA US Food and Drug Administration (FDA) 0
Z Swiss Authorized representative & non-medical device regulations Other Medical Device Regulations World-Wide 0
T FDA UDI Question - Class II Medical Device Other US Medical Device Regulations 2
blackholequasar ISO 13485 certification prior to Medical Device Manufacturing... worth it? ISO 13485:2016 - Medical Device Quality Management Systems 4
dgrainger Informational Good news: Commission proposes a progressive roll-out of the new In Vitro Diagnostic Medical Devices Regulation EU Medical Device Regulations 3
P Brexit Germany - Import Medical Device For Clinical Study EU Medical Device Regulations 0
M Medical Device Marketing Material - Control of Social Media 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
Ed Panek Make sure you hire competent QA RA Folks before making a "Medical Device." Coffee Break and Water Cooler Discussions 1
dgrainger Informational MDCG 2021-24 - Guidance on classification of medical devices EU Medical Device Regulations 0
B Acquired Medical Device Product Line - Documentation Requirements for Device Master Record ISO 13485:2016 - Medical Device Quality Management Systems 7
S State Licensing requirements for Medical Devices sold in the US directly to hospitals and tissue banks 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
MedicalDevicesCanada How to find a medical device contract manufacturer, MDSAP certified? Canada Medical Device Regulations 6
B ISO 11197, Venting of Medical Supply Units - cl. 201.11.2.2.101 Other Medical Device Related Standards 2
Q Best country to import medical devices into Europe Other Medical Device and Orthopedic Related Topics 0
dgrainger Informational MHRA's Software and AI as a Medical Device Change Programme UK Medical Device Regulations 0
dgrainger Informational Consultation on the future regulation of medical devices in the United Kingdom UK Medical Device Regulations 3
S Medical Device - Technical Documentation structure EU Medical Device Regulations 1
JoCam On-product labels for Medical Devices EU Medical Device Regulations 3
