Is anyone else having problems uploading Proprietary Names into the DRLM?
ScottK
Not out of the crisis
I've been trying to update proprietary names into the DRLM but am always getting "Error: Invalid Listing Number" for every one.
I've contacted the FDA and they were no help, and it will take another couple of weeks to geta response to my response.
We have two facilities registered, but one is newly registered.. listed as active and awaiting registration number... could that be holding me up?
Y
yana prus
I was facing today exactly the same problem while trying to register devices of one of my clients. Then I reviewed again the instructions for the new establishment registration (without the establishment number), and just followed the instructions and it worked and I managed to add the proprietary product names!!
I've copied the instructions again - http://www.fda.gov/MedicalDevices/D...urDevice/RegistrationandListing/ucm053185.htm
Initial Registration
Make payment and obtain the Payment Identification Number (PIN) and the Payment Confirmation Number (PCN) at the Device Facility User Fee website.
Go to FURLS at https://www.access.fda.gov/oaa/.
If you have never previously registered a device establishment, you will need to first create a FURLS account for the owner/operator (See Types of FURLS Accounts below). Note: If you already have an account for this owner/operator, you must log on to FURLS using that user ID and password.
Once you have set up your FURLS account ID and password, select the DRLM button (Device Registration and Listing Module).
Select the link "Register a Medical Device Facility" from the DRLM main menu.
If you do not have any existing registrations, you will see a page that asks you to identify any existing owner/operator number or registration number for your establishment. Leave the boxes empty and select "No existing registration or OO number."
If you have existing registrations, you will be asked to confirm that the establishment being registered does not already appear in the list that is displayed. If the establishment is already registered, do not create a duplicate record. If the establishment does not appear in the list displayed, select "Register a New Facility."
The Owner/Operator and Official Correspondent information that you entered when you created or updated your FURLS account will be displayed. To make changes to either the Owner Operator or the Official Correspondent information, you will need to exit the DRLM section of FURLS and return to Account Management. If the information is correct, select "Continue Registration."
Enter the required information for your facility and select "Continue Registration."
You will be prompted to enter information about the devices that you manufacture, process, distribute or import. Manufacturers, processors and distributors must list all devices produced or processed at each facility. Initial importers (facilities that take first title to a device imported into the United States) must list all manufacturers of the devices they are importing.
For all facilities EXCEPT initial importers:
Create Listings for devices produced or processed at this facility.
For each listing, identify whether your product requires premarket notification/approval or is exempt.
Note: If a device requires premarket notification clearance or approval it can ONLY be listed AFTER the premarket submission [510(k), PMA, PDP, HDE] is cleared or approved. If this is your only device listing, please do not register your establishment until after your premarket submission is cleared or approved.
If your premarket submission is cleared or approved, you will need to do the following to list your device:
Enter the premarket submission number
Enter the proprietary name(s)
Identify the activities that you perform on or to the device
If your device is exempt from premarket notification/approval, you will need to do the following:
Obtain the product code. You may click here to find your product code.
Leave the premarket submission number blank
Enter the product code in the filter box and click on "Filter"
Select the radio button next to the product code and click "Continue"
For Initial Importers (facilities that take first title to a device imported into the United States):
On the "Identify Manufacturers" page, click on the "Search & Add Products" button.
Identify the manufacturer by using either its device listing number, establishment registration number, or establishment name and address.
On the next page, under the registration information that matches the manufacturer of your devices, select the devices that you are importing and click on the "Add Selected Products" button.
Certify that all the information is correct and click on the submit button.
When prompted, enter both the PIN and PCN numbers that you received from the Office of Financial Management for your payment of the establishment registration fee. This information must be entered in order for FDA to accept your registration. If you are not prompted for the PIN/PCN numbers, please send an email to [email protected]. Without entering these numbers, your registration is incomplete.
You will receive a confirmation screen. Once you receive the confirmation screen, FDA will consider you registered.
If you have any changes to your listings, return to the main menu and select Change, Cancel or Reactivate Listings to update your listing information
ScottK
I tried this route and didn't get anywhere.
I already have a listing number that I'm using though.
We make all the same product. We don't need a listing number for every propriety name, right? we use the same listing number for multiple proprietary names.
MIREGMGR
You have one listing number per listing, and one listing per product or per group of products that have the same classification code and substantially the same design-nature and intended use.
You may have any number of proprietary names per listing. (Actually there might be an upper limit due to the database, but it's probably large enough to not be an issue.)
MIREGMGR
Are you bulk-uploading, using a template that you downloaded a couple of weeks ago?
Their template didn't match the database for a while. That's been fixed, as of a week or longer ago. Our uploads have worked in the past week.
ascherp
Yesterday I uploaded proprietary names for six different companies, including one for which I had just created the registration and listings. I used the bulk upload feature to upload the proprietary names for each company's listings all at once.
It worked fine in all cases except for one company, for which I repeated the process at different times throughout the day, hoping it would fix itself. I always got the same message as you did: Invalid listing number. Very frustrating!
We're consultants, so I do this frequently for many medical device establishments. Since December I've only had one other company with the same problem. So it isn't a general problem, but somehow linked to the individual FURLS account.
Have you tried using the ListingProprietaryNames.xls sheet to upload your proprietary names for each listing individually? Maybe that will work, since you'd already be within the individual "Change listing" feature and the system wouldn't have to deal with your "invalid" listing numbers. You would have to create a separate spreadsheet for each listing, but if you have many proprietary names that would still be better than uploading each one individually!
Regarding the max number of proprietary names, the most I have uploaded so far using a single spreadsheet were approximately 21,000 for 160 listings.
ScottK
That's what I thought. All of our current products are under the same listing and classification code
ScottK
Last time I downloaded their template was over a month ago... going to look for the fixed one....
ScottK
It's been resolved:
I was following the path for "Add Proprietary Names or Importers to Listing" and should have been following the path for "Change, Deactive, or Reactivate Listing".
The former really reads like what I was trying to do but that path is for adding proprietary names and multiple listings according to the FDA support guy.
D Medica show in Dusseldorf - Has anyone else gone? Other Medical Device and Orthopedic Related Topics 3
S Has anyone else noticed... Coffee Break and Water Cooler Discussions 17
GStough Anyone Else Curious About the Loremo? World News 8
D Off Duty Balance - Does anyone else enjoy hiking to clear the brain...? Coffee Break and Water Cooler Discussions 9
H Anyone Else Taking the CQE Exam on Saturday 2 December 2006? Professional Certifications and Degrees 13
ScottK Does anyone else here Read and/or Collect Comic Books? Coffee Break and Water Cooler Discussions 20
B Star Wars Books - Anyone Else read/reading them? Coffee Break and Water Cooler Discussions 5
H Is anyone else attending the workshop to update the CQE exam? Professional Certifications and Degrees 6
B Anyone Else bored with/during their continuing ISO 9001 audits? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
W Reliability Centered Maintenance - Anyone else doing RCM? Reliability Analysis - Predictions, Testing and Standards 4
D SMP - Skills Management Process - Does anyone else have experience with SMP? Training - Internal, External, Online and Distance Learning 4
P PPAP for packaging? Does anyone else require this? APQP and PPAP 1
R VisualSPC: Anyone else using this software? Resistance from experienced operators Statistical Analysis Tools, Techniques and SPC 14
B Is anyone using Impact Software? Is there something else similar? Quality Assurance and Compliance Software Tools and Solutions 1
A Can anyone share a Distribution Agreement template under MDR 2017/745? EU Medical Device Regulations 0
GreatNate Anyone using the Intellect QMS software? Quality Assurance and Compliance Software Tools and Solutions 1
P Anyone have an Idea on UAE Medical device registeration- Class B with FDA only Other Medical Device Regulations World-Wide 0
N Does anyone have experience of GB/T 34986-2017? China Medical Device Regulations 1
Z Does anyone have experience with EN ISO 17664 ? IEC 62366 - Medical Device Usability Engineering 9
F Does anyone have an ESD quality/cooler talk to share? Training - Internal, External, Online and Distance Learning 4
A Does anyone have a checklist of API Spec 650 13th Edition? Oil and Gas Industry Standards and Regulations 0
P Does anyone have a API Q1 Documentation Package? Quality Management System (QMS) Manuals 1
J Does anyone have an excel IATF 16949 Internal Audit checklist I could use? IATF 16949 - Automotive Quality Systems Standard 7
Watchcat Anyone had an MDR technical file review/audit yet? EU Medical Device Regulations 13
S Anyone Familiar with "SPC for Excel" add-in? Lean in Manufacturing and Service Industries 4
M Has anyone has been through an MDR audit? (3/2020) EU Medical Device Regulations 1
M Has anyone heard of Run at Risk? Manufacturing and Related Processes 15
B ASA Aviation Supply Association - Has anyone heard of ASA? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
D Has anyone had sudden challenges from Korea-MFDS? Other Medical Device Regulations World-Wide 1
MDD_QNA QR Code Standard ISO/IEC 15417:2007 - Does anyone use it? Other Medical Device Related Standards 3
F Hi friends, can anyone show me an example of a procedure for ISO 13485 6.4.1 Work Environment? ISO 13485:2016 - Medical Device Quality Management Systems 2
W Does anyone have an API Q2 checklist for internal auditing? Oil and Gas Industry Standards and Regulations 1
Ronen E Can anyone please explain this? (510k submission requirement) Other US Medical Device Regulations 14
GreatNate Metrotom - Does anyone have any exposure to the Zeiss Metrotom 800 or 1500? Manufacturing and Related Processes 0
D FDA Biomarker Qualification Program - Has anyone prepared an application? Medical Device and FDA Regulations and Standards News 0
T Is anyone working with N299.1 (Supply/service to nuclear power plants)? Various Other Specifications, Standards, and related Requirements 0
GreatNate QMS in SharePoint - Is anyone doing this? Manufacturing and Related Processes 10
M Honda Audits - Does anyone have any experience with the QAV audit? General Auditing Discussions 3
G Anyone working with or planning to do business in the CBD (cannabidiol) industry? US Food and Drug Administration (FDA) 1
L Has anyone heard of the 2 pan system? Manufacturing and Related Processes 6
Q Does anyone have experience implementing a QMS without ISO certification? Quality Manager and Management Related Issues 2
J Does anyone here use ISOXpress/IMSXpress QMS software? Software Quality Assurance 11
K Does anyone have a copy of a GM 5 Phase Problem solving form Problem Solving, Root Cause Fault and Failure Analysis 1
M Has anyone here assessed the latest Abbreviated 510(K) guidance document? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M Does anyone has a good verification and validation plan template? ISO 13485:2016 - Medical Device Quality Management Systems 3
D Has anyone undergone a BARDA (HHS) audit as part of their grant process? Other Medical Device Regulations World-Wide 0
QIE Anyone have experience with BPA Quality (QMS system based on Office365/Sharepoint) Quality Assurance and Compliance Software Tools and Solutions 1
