Is calibration of digital panel important in any semicon company?
calib
Is calibration of digital panel important in any semicon company? You see these panel meters are used in IR sensor, does it requires a calibration or not? Need help co'z I'm starting to draft a procedure(I was ordered to)on these meters and I don't know if this is only a waste of time
G
Graeme
The fundamental questions you have to ask - and answer - are these:
  • Is the meter used to measure a parameter that is important to the quality of the product?
  • Does it matter if the meter reading is wrong?
If what is being measured is important to assure the quality of the product, then the meter must be calibrated. If it matters if the reading is wrong then the meter must be calibrated.
Notice that I have not said anything about the TYPE of meter. That is because the type of meter (digital or analog, electronic or mechanical) does not matter when determining the need for calibration. (These factors ARE important, though, when determining the required accuracy and precision.) It also does not matter what your process is. You have to ask the same questions.
The only thing that would be a waste of time would be if you answer both of the questions "No" -- because then you have to ask "why am I making this measurement at all?"
Graeme C. Payne
ASQ Certified Quality Engineer
Jerry Eldred
As much of my background is in semiconductor related calibrations, please give me some more detail and I will try to give you a good answer.
M Calibration of Digital Panel Meters General Measurement Device and Calibration Topics 4
C Should resolution be included in uncertainty budget for digital caliper or micrometer calibration? Measurement Uncertainty (MU) 5
G Calibration of Rotronic probe but not digital readout? General Measurement Device and Calibration Topics 3
D Calibration of Digital thermometer with surface probe General Measurement Device and Calibration Topics 1
A Digital Timer Calibration Requirements General Measurement Device and Calibration Topics 3
D AMS 2750E - Digital Instrument Calibration Accuracy Requirements General Measurement Device and Calibration Topics 1
A Automated calibration of Digital Multimeter without communication port Calibration and Metrology Software and Hardware 2
D Hand-held Digital Tension Meter Calibration General Measurement Device and Calibration Topics 1
J Digital Scale Re-Calibration Interval Frequency General Measurement Device and Calibration Topics 10
W Digital Multi-Meter Calibration Procedure for various Meter Brands and Functions General Measurement Device and Calibration Topics 7
A Fluke Digital MultiMeter Calibration Traceability and Certificate General Measurement Device and Calibration Topics 11
N Thermocouple Calibration - Digital Display vs. Converting the Millivolt into ?C General Measurement Device and Calibration Topics 8
N Digital Temperature Indicator Calibration (Thermocouple) - Using a reference junction General Measurement Device and Calibration Topics 1
T In-House Calibration - Digital Micrometer found Out of Calibration General Measurement Device and Calibration Topics 10
V Calibration of a Digital Vernier - Need to check/calibrate/validate all 3 functions? General Measurement Device and Calibration Topics 9
B Tolerance for Digital Indicator Calibration - Machinists Indicators General Measurement Device and Calibration Topics 1
T Calibration of a digital usb temprature probe. General Measurement Device and Calibration Topics 3
O Calibration Supplier needed for Digital Temperature/Pressure Controllers General Measurement Device and Calibration Topics 6
O Calibration tolerances needed - Calipers, digital indicators, feeler gages, etc General Measurement Device and Calibration Topics 4
S Safeguarding Calibration on Digital Equipment General Measurement Device and Calibration Topics 25
F Digital Multimeter - Verification vs. Calibration MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
J Digital Caliper Calibration vs. Verification - Full Scale vs. Used Range General Measurement Device and Calibration Topics 8
M Calibration of Timers to NIST - How are digital and analog timers calibrated? General Measurement Device and Calibration Topics 15
P IATF16949 External Lab Calibration -CIPM MRA IATF 16949 - Automotive Quality Systems Standard 1
CaliperJim Acclimation time prior to calibration General Measurement Device and Calibration Topics 8
S How to report a measurement and relate it to calibration certificate General Measurement Device and Calibration Topics 1
R Do I need to get calibration certificate from ISO 17025 for IATF Audit IATF 16949 - Automotive Quality Systems Standard 8
S Netsuite Preventive Maintenance and Calibration Manufacturing and Related Processes 0
D Roughness specimen calibration Calibration and Metrology Software and Hardware 5
dhuot1990 General Calibration SOP Manufacturing and Related Processes 3
B Gage calibration Gonogo (calcul of cgk) General Measurement Device and Calibration Topics 0
Vader22 As-Found FAILED calibration ISO 14001:2015 Specific Discussions 16
M Gravimetric blender for resin in automotive industry - periodical calibration via external lab with certification Reliability Analysis - Predictions, Testing and Standards 0
N Calibration Method for Scales and Flowmeters Reliability Analysis - Predictions, Testing and Standards 7
T Calibration Tracking ISO 13485:2016 - Medical Device Quality Management Systems 4
Q Considering addition of mass calibration to ISO17025 scope ISO 17025 related Discussions 6
Z Resolution in calibration General Measurement Device and Calibration Topics 1
J Run Down Adapters Calibration Processes General Measurement Device and Calibration Topics 4
S Looking for accredited calibration lab - Onsite up to 650A and 1 kV. General Measurement Device and Calibration Topics 3
CaliperJim Screw Thread Micrometer Anvil Calibration General Measurement Device and Calibration Topics 7
Strange Juan HP 85054B Standard Mechanical Calibration Kit Calibration Procedure General Measurement Device and Calibration Topics 1
H Air Pressure Gage Calibration General Measurement Device and Calibration Topics 6
T Calibration on AVL AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C Determining an as received OOT condition during calibration does not affect measurements taken prior to calibration. General Measurement Device and Calibration Topics 16
Sam.F Do heat treatment ovens need calibration? General Measurement Device and Calibration Topics 22
J Selecting reference standards for calibration General Measurement Device and Calibration Topics 3
C IATF 16949:2016 Major NC pertaining to 7.1.5.2.1 Calibration/verification records IATF 16949 - Automotive Quality Systems Standard 15
E Calibration Records during AS9100 Audit AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
John Predmore Calibration Determination decision Calibration Frequency (Interval) 15
J ISO 17025 Calibration Other Medical Device Related Standards 2
