Is Calibration Required for Non-Adjustable Commercial Inspection Devices?
I would like to ask if you feel commercial devices, such as tape measures, weld fillet gages and machinist scales require calibration and you reasoning as to wht or why not.
Welcome to the Cove. This subject has been discussed extensively here over the years. What's being asked, essentially, is whether devices that can't be adjusted need to be calibrated. A definition of "calibration" is in order. In its simplest form, calibration is comparison to an accepted standard, and doesn't imply adjustment. I don't have a copy of the 2015 version of ISO 9001, but in previous versions the calibration requirement began "When required to ensure valid results..." and that should be the guide. If a set of radius gages purchased from a reputable source is periodically checked for wear and damage, formal calibration shouldn't be required. The same applies to linear scales and to some extent, tape measures.
Someone will doubtlessly come along here and disagree, but that's the way I always treated these things.
Tagin
In 9001:2015:
7.1.5.2 Measurement traceability
When measurement traceability is a requirement, or is considered by the organization to be an essential part of providing confidence in the validity of measurement results, measuring equipment shall be:
Mike S.
Happy to be Alive
Ummmm....I would say "it depends".
What requirement(s) do you have to live to with respect to M&TE and calibration?
For example, let's say your customer requires all M&TE to be calibrated or verified against standards traceable to NIST. If you are using that tape measure or scale to approve or reject product, IMO it better be calibrated or verified as required.
If a customer has a requirement that all persons measuring parts must wear a pink tutu, then they had better be wearing a pink tutu when measuring parts. Clearly, customer requirements must be honored if agreed to. The question is, I think, about practical necessity and not whether there is an extrinsic requirement.
Sidney Vianna
Post Responsibly
For b2b relationships, yes.
On the other hand, in most of business-to-consumer contexts, obviously, customer have no mandates/requirements related to this. If your product is a chicken coop, chances are the people making the coop will not use verified measuring devices because the risks of a dimension being off by 1⁄4 or ½ inch is tolerable.
Mike S.
Happy to be Alive
In most of business-to-consumer contexts, obviously, customer have no mandates/requirements related to this. If your product is a chicken coop, chances are the people making the coop will not use verified measuring devices because the risks of a dimension being off by 1/4 or 1/2 inch is tolerable.
Well, quite true, but I didn't see where the OP spoke of a business-to-consumer context.
We don't know whether they make chicken coops or aerospace parts, which is why I said "it depends". Many times the customer requirements are not obvious, but buried a bit in tons of PO text or separate quality codes, so I thought I'd add that caveat.
Thee Bouyyy
Multiple Personalities
It all depends upon how you have written in your procedures. For example, we have written like this, "Steel Rulers and Tape Measures are not used for precise measurements and hence do not require Calibration. These are replaced, if damaged or become illegible"
Think about this way.
J Scrap Material Scale Calibration Required? IATF 16949 - Automotive Quality Systems Standard 21
I IQOQ or just initial calibration required? General Measurement Device and Calibration Topics 3
G Is repeatability required for equipment calibration? General Measurement Device and Calibration Topics 10
S Is Optical Parallel Set required calibration? ISO 17025 related Discussions 1
A Calibration required by OEM General Measurement Device and Calibration Topics 2
M Are model# and Serial # required on a calibration cert? General Measurement Device and Calibration Topics 4
H In-house device calibration record - Actual values obtained required? General Measurement Device and Calibration Topics 9
B Changing out Thermocouple - Is new calibration required? General Measurement Device and Calibration Topics 1
C ISO17025 for In-House Calibration Labs: Is it required? ISO 17025 related Discussions 30
Manix Calibration of Scales to Traceable Standards (Clause 7.6) - Required or Not Calibration Frequency (Interval) 6
A Is NIST traceability required if a Refractometer calibration is done in-house? Calibration Frequency (Interval) 6
S Is calibration of a weigh scale required? Calibration Frequency (Interval) 8
L Is calibration required for weighing scales used for shipping purposes ? Misc. Quality Assurance and Business Systems Related Topics 10
D Functional Test Fixtures - Calibration Required? Quality Manager and Management Related Issues 8
L Are Outside Calibration Companies required to NADCAP Certified? General Measurement Device and Calibration Topics 6
Q Engineering purchased a new Caliper - 7.6 - Initial Calibration Required? General Measurement Device and Calibration Topics 6
H When is Calibration not required? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
K Survey Meter Calibration - Accredited Laboratory required? General Measurement Device and Calibration Topics 5
S Required Complete calibration SOP, calibration Plan and master list template! IATF 16949 - Automotive Quality Systems Standard 3
B CMM Stylus Calibration - Required to record the As Found condition AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
M ISO 17025 - Recommended or Required and other Calibration questions ISO 17025 related Discussions 5
J Equipment required for a Dimensional Calibration Laboratory Document Control Systems, Procedures, Forms and Templates 1
A ISO 17020 Audit Findings - Calibration from Accredited Laboratory required Other ISO and International Standards and European Regulations 8
W Is an Oven I/O/Q Validation Required or is Calibration Sufficient? Qualification and Validation (including 21 CFR Part 11) 7
B Can I Claim That Periodic Calibration is Not Required? ISO 13485:2016 - Medical Device Quality Management Systems 6
R HP8481A Power Sensor Calibration - What standards are normally required? General Measurement Device and Calibration Topics 5
D TS 16949 In-House Calibration Requirements - Certification Required? IATF 16949 - Automotive Quality Systems Standard 26
L Is a Supplier Audit required for an ISO certified calibration company? Process Audits and Layered Process Audits 12
M Gage pin calibration - Actual calibration readings required on the calibration cert General Measurement Device and Calibration Topics 3
A "Calibration Not Required" label requirements ISO 13485:2016 - Medical Device Quality Management Systems 36
P Are we required to register to REACH? Small CMM service and calibration company RoHS, REACH, ELV, IMDS and Restricted Substances 3
E Recalculation of MU for Test Equipment after every Calibration required? Measurement Uncertainty (MU) 11
V Gage Calibration Stickers in harsh environments - Are Calibration Stickers Required General Measurement Device and Calibration Topics 14
A Is Calibration Required for Equipment/Devices Used for Measuring Support Services General Measurement Device and Calibration Topics 6
F What are the specifications required in the preparation of a calibration laboratory? General Measurement Device and Calibration Topics 4
S Calibration required? We buy part of our machined parts - Supplier gage calibration? General Measurement Device and Calibration Topics 6
C What type of Calibration is Required for TS16949? IATF 16949 - Automotive Quality Systems Standard 5
C Thermohygrometer Calibration - Number of Required Calibration Points General Measurement Device and Calibration Topics 13
A Are ISO 9001 certified companies required to use ISO17025 facilities for calibration? ISO 17025 related Discussions 13
S Is official MSA training required person performing calibration? IATF 16949 - Automotive Quality Systems Standard 6
B Weight class required for scale calibration General Measurement Device and Calibration Topics 2
D ISO/IEC 17025 required for a calibration lab to be ISO certified? ISO 17025 related Discussions 6
D Interesting Discussion Using "Not A Calibrated Device" or "No Calibration Required" stickers General Measurement Device and Calibration Topics 63
A Calibration Discrimination - Acceptance criteria is not having the accuracy required? General Measurement Device and Calibration Topics 2
K Should QS/TS certified internal test/calibration labs be required to be ISO17025 ISO 17025 related Discussions 16
K Dimensional Lab (CMM Room) vs. Physical Test/Calibration Lab - Same required temp/hum General Measurement Device and Calibration Topics 2
I Calibration Stickers on instruments are NOT required! General Measurement Device and Calibration Topics 28
Marc Required Calibration Certificate Contents General Measurement Device and Calibration Topics 2
D Level of accuracy required for the calibration of glass mercury thermometers General Measurement Device and Calibration Topics 6
