Is conducting of all MSA studies required, even if not required by the customer?
tienie
#11
Re: Is conducting of all MSA studies required, even if not required by customer?
Hai
I'm interested in Amine.arafa reply on conducting MSA (linearity, bias, stability) based on calibration certificate. could you please explain more on this? if possible could you give any one example on this?
Now we only practising GR&R as Amit does.
Thank you in advanced
Tienie
bobdoering
Stop X-bar/R Madness!!
#12
Usually the "other techniques' are reserved for physical phenomena - which have significant repeatability issues - such as tensile testing, compression testing, etc.
bobdoering
#13
1) Is it required to conduct MSA studies for measurement technique such as 'Micrometer' for every unit, as appraisers are different?
For Gage R&R (since MSA is actually ALL of the gage testing, NOT just gage R&R):
No - pick the appraiser with the best skill, the appraiser with the least skill (e.g. new appraiser) and another appraiser of typical skills. If you pass that, it shows that the gage is the correct gage for your job, no matter what skill level operator uses it. Done.
2) Is it required to conduct MSA studies for every Inspection fixture / template (Used for inspecting different products)?
First, remember there is a special technique for attribute gages. Your templates are typically attribute, and will need that technique (and more parts)
Second, if the fixtures are significantly different, they should be included to determine if they even work correctly. You really have no evidence otherwise that they do.
bobdoering
#14
If you are sending your equipment out for calibration, the time-function portion of MSA (calibration, linearity, bias, stability) that indicates your gage still reads correctly should be accomplished by that.
On the other hand, gage R&R is done by internal operators, and it answers the question "is this the right gage for the job?" If you have not done it for the age, you can not answer the question accurately.
That is never a good idea.
Amine.arafa
#15
Hai
Tienie
Hi Tienie
For more details, BIAS is a calculation based on multiple measurements for one "true value" wich is the technique used by calibration labs to determine an average difference (BIAS) in a single measurement point, LINEARITY gives you the behavior of your instrument over the entire measurement range (As for example, the BIAS of a Voltmeter for 1V, 10V and 100V), and the STABILITY gives you the BIAS over time (You can obtain it by comparing BIAS in different certificates for the same measurement tool)
Hope this helped
Best regards
Amine
bobdoering
#16
For more details, BIAS is a calculation based on multiple measurements for one "true value" which is the technique used by calibration labs to determine an average difference (BIAS) in a single measurement point,
The "true value" for most countries is a standard traceable back to that country's national standards (e.g. NIST for the US)
A big, but not only reason this is done is because a gages used over a small portion of its measurement range may show wear in that range first.
Needs to also track any changes made - if any - from adjustments during calibration over time.
mwohlg
#17
Miner had a series of blog posts here on the Cove, that did a very good job of explaining the differences between Bias, Linearity, etc. I just found them earlier today but can't find them again now. Maybe someone who knows what they're doing can post a link to those?
#18
Miner's MSA Blog is here.
antonjav
#19
Hi Amit, just to clarify, you do not have to perform GRR, linearity, bias, and stability for each measuring device. The requirement is to perform statistical study for each measurement device type provided that the same is referenced in the control plan. Hence, this means that if you have 10 calibrated calipers, you could just get one and then determine if GRR, linearity, bias, and stability (unfortunately all of it for this one) would be appropriate to determine the amount of variation present -- provided that this caliper is identified or referenced in the control plan.
Of course, if you do GRR, you could easily identify the kappa values (or p values if linearity) and see if the measuring devices are fit for use or if some adjustment has to be made to enahnce accuracy or precision. Hope that this helps.
Marc
#20
Note that sometimes a company has a number of measurement device types, but in specific gauge types they may not be from the same manufacturer, and there may be age differences between the individual devices. Just a few thoughts to consider.
B Best Methods for conducting Shadowgraph MSA Studies Quality Manager and Management Related Issues 2
S Conducting an MSA study for ICT(HP3070) and Functional Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
O Conducting MSA on Multiple Measurement Mystems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J Need help calculating actual Ppk - Result of % GR&R=11.8% when conducting MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
automoto Excel (xlsx) spreadsheet for conducting Type 1 MSA Analysis. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 23
P Conducting a MSA - Measurement of plaster by use of a scoop - I need Help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
M Lean: Conducting Capacity Study, calculating Cycle times on laser cutting machines Lean in Manufacturing and Service Industries 2
atitheya Need of conducting medical trials in European Union EU Medical Device Regulations 2
M Informational IMDRF draft document – Requirements for Regulatory Authority Recognition of Conformity Assessment Bodies Conducting Medical Device Regulatory Reviews Medical Device and FDA Regulations and Standards News 0
Pmarszal ISO 19011:2018 - Risk Based Approach for planning, conducting and reporting of internal audits Internal Auditing 8
T Results from conducting a Capability Studies Statistical Analysis Tools, Techniques and SPC 4
P Suggestions on conducting Internal Audit of a new site Internal Auditing 15
dubrizo Internal Audit Value - What is the point of conducting internal audits to a checklist Internal Auditing 40
Q AS9100 Repairs - Approval from a non-aerospace customer prior to conducting a repair AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
M Conducting a Project for Safety Improvement Misc. Quality Assurance and Business Systems Related Topics 4
M Sample size when conducting capability analysis with OK and NOK parts Statistical Analysis Tools, Techniques and SPC 3
N Who is responsible for conducting Root Cause investigation? Problem Solving, Root Cause Fault and Failure Analysis 8
H What information do I need to collect when conducting 2nd party audit? General Auditing Discussions 6
drgnrider Suggestions for conducting a Spill Clean-up Exercise Miscellaneous Environmental Standards and EMS Related Discussions 8
C What kind of information you provide when conducting QMS Orientation? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
G Conducting a Bias Study for a CMM with no Traceable Master or Reference value Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
M Conducting Limited Internal Audits of QMS Elements - Simple question I hope ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
K Conducting ISO 9001:2008 and ISO 14001:2004 New Supplier Audit Supplier Quality Assurance and other Supplier Issues 5
D Anyone use an iPad for conducting Audits? Internal Auditing 18
T Conducting the "are all points within the control limits" test when there is no LCL? Statistical Analysis Tools, Techniques and SPC 2
L Conducting Gap Analysis for ISO 27001 IEC 27001 - Information Security Management Systems (ISMS) 4
A Conducting a DOE in Minitab - Improving Surface Finish of an Impeller Using Minitab Software 10
K Advisable Period of Records to be Checked in Conducting an Audit Food Safety - ISO 22000, HACCP (21 CFR 120) 2
B Conducting a study on Hexagon Nuts "turned" on a multi-spindle automatic lathe Statistical Analysis Tools, Techniques and SPC 9
W Conducting Audit and Audit Report in accordance to 21 CFR 820 and ISO 13485 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 13
Q Design of Experiments Using Subgroup Data - Conducting a 2^3 factorial DoE Quality Tools, Improvement and Analysis 6
M Send a Supplier an Audit Plan prior to conducting an audit at their premises? General Auditing Discussions 8
P Suggestions on conducting an Internal Audit on 7.5.1.6 Production Scheduling IATF 16949 - Automotive Quality Systems Standard 2
D Forms and Templates used for Conducting Internal Audits (API Q1/TS 29001) Oil and Gas Industry Standards and Regulations 5
S Time Study Std/Books that define minimum requirements for conducting time study? Capability, Accuracy and Stability - Processes, Machines, etc. 9
Y Conducting a Mock Recall on a Medical Device Product ISO 13485:2016 - Medical Device Quality Management Systems 6
H Gathering the Data before Conducting GR&R (Gage R&R) Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Colin Conducting audits without procedures Internal Auditing 8
J Conducting Gage R&R - 300 plug gauges - Different diameters - One for each plug gage? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
F Conducting an ISO 9001, Clause 5.xx audit General Auditing Discussions 12
T Conducting an Energy Usage Audit - Seeking template or form Miscellaneous Environmental Standards and EMS Related Discussions 3
A Goods-In Process Audit - Any pointers or hints for conducting a 'good' audit? Process Audits and Layered Process Audits 3
Marc Conducting Internal Audits vs. Third Party (Registrar) Audits Internal Auditing 11
J ISO 9001 'Compliant' Company - Conducting a supplier audit on a major supplier Supplier Quality Assurance and other Supplier Issues 17
L Conducting general overview training on ISO 14001 Training - Internal, External, Online and Distance Learning 1
Nihls MSA Study Type 2 (special conditions ) IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
Nihls When the MSA results show no operator influence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S MSA for attribute relation gage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Nihls MSA Study Type 1 (CMM) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
