Is conducting of all MSA studies required, even if not required by the customer?
antonjav
#21
Re: Is conducting of all MSA studies required, even if not required by customer?
Hi Amit, for sure it is unlikey that you would be able to get an exemption in fulfilling the requirements of 7.6.1. TS 16949 does not specify any maximum frequency for doing MSA nor does it suggest one. This is because the standard only states the "What is required" portion and not the methodology for achieving the requirement.
In several engineering organizations, the maximum frequency is at times determined by the amount of variation present at the time of the MSA study. This means that if you do MSA once a year but then you find out that the GRR (or linearity and bias) results yield unfavorable results, like kappa values are close to zero or that the components of variation are larger than the part-to-part variation, then you are constrained to adjust your MSA frequency to 6 months instead.
As to which MSA study would be compulsory, again TS 16949 would not prescribe. It all depends on the measurement type that you would do an MSA on, including its intended use. For example, if you would do a MSA on a caliper, it is expected that you would do GRR, linearity, and bias studies. However, if the caliper would not measure the different sizes except for a fixed value, then you may exclude linearity in the study. You would of course include bias and GRR.
Hope that this helps.
AMIT BALLAL
#22
Thanks for help & suggestions.
I would like to ask one more question:
Should I conduct Stability studies ? And if yes, for which measurement techniques ?
Thanks in advance,
Amit
antonjav
#23
Thanks in advance,
Amit
Again, the TS standard will not require whether you shall perform a stability study or not. It would be your engineering or QA group responsible for MSA who would decide on whether stability shall be performed or not.
Of course, during audit, your organization should be able to justify why no stability study is done when it seems that one is warranted. If you can't justify a no stability study, then you might as well consider doing one - provided further that the concerned measuring or test equipment is referenced in you control plan.
Hope this helps Amit. Thanks.
antonjav
#24
... on the business side, if you are so constrained with current resources and that doing a stability study would make your staff nosebleed, then you could take some risk and not do stability study at this time. The worse thing that could happen is that a minor nonconformity report (or observation only if there's no big lapses in other TS requirements) would be issued to the organization responsible; you are given time to respond and close out.
Lastly, there are other process controls in place that would capture adventurous quality excursions, yes?
Thanks.
B Best Methods for conducting Shadowgraph MSA Studies Quality Manager and Management Related Issues 2
S Conducting an MSA study for ICT(HP3070) and Functional Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
O Conducting MSA on Multiple Measurement Mystems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J Need help calculating actual Ppk - Result of % GR&R=11.8% when conducting MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
automoto Excel (xlsx) spreadsheet for conducting Type 1 MSA Analysis. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 23
P Conducting a MSA - Measurement of plaster by use of a scoop - I need Help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
M Lean: Conducting Capacity Study, calculating Cycle times on laser cutting machines Lean in Manufacturing and Service Industries 2
atitheya Need of conducting medical trials in European Union EU Medical Device Regulations 2
M Informational IMDRF draft document – Requirements for Regulatory Authority Recognition of Conformity Assessment Bodies Conducting Medical Device Regulatory Reviews Medical Device and FDA Regulations and Standards News 0
Pmarszal ISO 19011:2018 - Risk Based Approach for planning, conducting and reporting of internal audits Internal Auditing 8
T Results from conducting a Capability Studies Statistical Analysis Tools, Techniques and SPC 4
P Suggestions on conducting Internal Audit of a new site Internal Auditing 15
dubrizo Internal Audit Value - What is the point of conducting internal audits to a checklist Internal Auditing 40
Q AS9100 Repairs - Approval from a non-aerospace customer prior to conducting a repair AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
M Conducting a Project for Safety Improvement Misc. Quality Assurance and Business Systems Related Topics 4
M Sample size when conducting capability analysis with OK and NOK parts Statistical Analysis Tools, Techniques and SPC 3
N Who is responsible for conducting Root Cause investigation? Problem Solving, Root Cause Fault and Failure Analysis 8
H What information do I need to collect when conducting 2nd party audit? General Auditing Discussions 6
drgnrider Suggestions for conducting a Spill Clean-up Exercise Miscellaneous Environmental Standards and EMS Related Discussions 8
C What kind of information you provide when conducting QMS Orientation? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
G Conducting a Bias Study for a CMM with no Traceable Master or Reference value Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
M Conducting Limited Internal Audits of QMS Elements - Simple question I hope ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
K Conducting ISO 9001:2008 and ISO 14001:2004 New Supplier Audit Supplier Quality Assurance and other Supplier Issues 5
D Anyone use an iPad for conducting Audits? Internal Auditing 18
T Conducting the "are all points within the control limits" test when there is no LCL? Statistical Analysis Tools, Techniques and SPC 2
L Conducting Gap Analysis for ISO 27001 IEC 27001 - Information Security Management Systems (ISMS) 4
A Conducting a DOE in Minitab - Improving Surface Finish of an Impeller Using Minitab Software 10
K Advisable Period of Records to be Checked in Conducting an Audit Food Safety - ISO 22000, HACCP (21 CFR 120) 2
B Conducting a study on Hexagon Nuts "turned" on a multi-spindle automatic lathe Statistical Analysis Tools, Techniques and SPC 9
W Conducting Audit and Audit Report in accordance to 21 CFR 820 and ISO 13485 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 13
Q Design of Experiments Using Subgroup Data - Conducting a 2^3 factorial DoE Quality Tools, Improvement and Analysis 6
M Send a Supplier an Audit Plan prior to conducting an audit at their premises? General Auditing Discussions 8
P Suggestions on conducting an Internal Audit on 7.5.1.6 Production Scheduling IATF 16949 - Automotive Quality Systems Standard 2
D Forms and Templates used for Conducting Internal Audits (API Q1/TS 29001) Oil and Gas Industry Standards and Regulations 5
S Time Study Std/Books that define minimum requirements for conducting time study? Capability, Accuracy and Stability - Processes, Machines, etc. 9
Y Conducting a Mock Recall on a Medical Device Product ISO 13485:2016 - Medical Device Quality Management Systems 6
H Gathering the Data before Conducting GR&R (Gage R&R) Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Colin Conducting audits without procedures Internal Auditing 8
J Conducting Gage R&R - 300 plug gauges - Different diameters - One for each plug gage? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
F Conducting an ISO 9001, Clause 5.xx audit General Auditing Discussions 12
T Conducting an Energy Usage Audit - Seeking template or form Miscellaneous Environmental Standards and EMS Related Discussions 3
A Goods-In Process Audit - Any pointers or hints for conducting a 'good' audit? Process Audits and Layered Process Audits 3
Marc Conducting Internal Audits vs. Third Party (Registrar) Audits Internal Auditing 11
J ISO 9001 'Compliant' Company - Conducting a supplier audit on a major supplier Supplier Quality Assurance and other Supplier Issues 17
L Conducting general overview training on ISO 14001 Training - Internal, External, Online and Distance Learning 1
Nihls MSA Study Type 2 (special conditions ) IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
Nihls When the MSA results show no operator influence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S MSA for attribute relation gage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Nihls MSA Study Type 1 (CMM) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
