Is Defib Protection mandatory for wearable ECG?
K
krystle
Hi everyone :bigwave:,
we're having some trouble identifying the right wording to explain to our lab that the defib protection for our device is not necessary. the lab is doing testing for us for IEC 60601-1, -1-2, -1-11, -2-25 and -2-47. The lab asked us to comment on how the essential requirement 201.8.5.5.1 of the 60601-2-25 was guaranteed or to provide rationale for it being not applicable.
We have a product with a disposable sensor and a small wearable ECG monitor that clips onto the sensor (no lead wires). Our NB auditor did not comment on whether defib protection is necessary or not when he saw the symbols we used and the lab's report. We've come up with a few arguments to give back to the lab but i wanted to see if anyone here has any experience and can help us out.
Thanks a lot!
Krystle
subbash
We are also working on a wearable ECG product. We have included the Defibrillator circuit.
I am not an expert but, I believe the requirement of the circuit depends the type of applications that the Wearable device is intended for.
I am also eager to hear the expert opinions of others in this group.
G
gyiszu
Which one of the scopes of the particular standards are applicable to your device? (I have not seen an ECG to which both 2-25 and 2-47 is applicable as they have totally different intended use.)
If one particular standard applies than you have to fulfill all the essential performance requirements defined, if you cannot than your device is not an ECG (in terms of 60601-2-25, 60601-2-27, 60601-2-47) just a device capable of collecting data about electrical activity of the heart.
How many leads do you have in the sensor? If you cannot fulfill 201.12.4.102.2 Minumum required configuration of 60601-2-25 it is definetly not applicable.
You can still use an approach that you define requirements by sub-clause 4.5 60601-1 so you accuracy can be measured at least...
Sorry I hope I did not confused you.
BR,
gyiszu
subbash
Dear gyiszu,
We are still in the schematic phase. We still need to go through the applicable standards for our wearable ECG product. The current configuration is for a single lead ECG.
Please do let me know if you have any update regarding the standard applicable.
Thanks and Regards,
Subbash
As has been mentioned earlier the 3 possibly applicable standards are for quite different applications. It would probably help you if you identified which (if any) of the 'Particular' standards to apply early in your project.
You can view previews of the standards from the IEC web-store. This shows you the first few pages; usually enough to decide on applicability without having to buy the standard, for considerable sums.
From the 60601-2-47 preview:
Within the scope of this standard are systems of the following types:
a) systems that provide continuous recording and continuous analysis of the ECG allowing full re-analysis giving essentially similar results. The systems may first record and store the ECG and analyse it later on a separate unit, or record and analyse the ECG simultaneously.
The type of storage media used is irrelevant with regard to this standard;
b) systems that provide continuous analysis and only partial or limited recording not allowing a full re-analysis of the ECG.
The safety aspects of this standard apply to all types of systems falling in one of the above mentioned categories.
If the AMBULATORY ELECTROCARDIOGRAPHIC SYSTEM offers automatic ECG analysis, minimal performance requirements for measurement and analysis functions apply.
MEDICAL ELECTRICAL EQUIPMENT covered by IEC 60601-2-25 and IEC 60601-2-27 are excluded from the scope of this standard.
So that is quite prescriptive. Elsewhere they refer to this sort of device as a 'Holter recorder' if that helps to recognise what type of device it is meant for.
From what I can see from the Contents page of the preview -2-47 does not require defibrillator proof parts.
K
krystle
Hi all, thank you for your comments.
Our device is both a monitor for the generation of a diagnostic ECG file and a holter device. We confirmed months ago with our NB and testing lab that both 60601-2-25 and -2-47 are applicable.
in the meantime we heard back from our auditor who told us that we can claim defibrillation protection is not applicable because our device is not diagnostic in real-time so it cannot be used in emergency cases or in ambulances where a defibrillator would be applied. We're adding in the user manual that device needs to be taken off when a defib is to be used and that it cannot be used during emergency but only for day-to day monitoring.
Hope this helps someone else out there!
thanks to all once again :)
Kry
G
gyiszu
Dear subbash,
If -2-25 is applicable than defibrillation proof requirements also apply, because you use the information of the ECG to determine that another definitely charge is needed.
But as I said with one lead you will fail on-2-25 because you will not meet with minimum lead requirements. And I suppose that with one lead you will have severe difficulties to pass the DC offset test....
BR,
Gyiszu
Peter Selvey
Forgetting the standards, careful consideration about defibrillation seems to make sense if the ECG is intended for use on a patient with suspected heart problems, since it is more likely that they will need to be defibrillated.
However, it is unlikely the device itself is is useful for detecting if the defib was successful - it may not have an actual real time display or if provided might be on a smart phone which is not exactly useful in an emergency situation. Rather, the person performing the defibrillation is most likely to use the defib's own ECG monitor to tell if the defibrillation was successful. These days AED devices do this automatically.
What is important is to make sure the wearable device does not get in the way of the defibrillation or cause any trouble. This could be:
- due to position of the electrodes (gets in the way of good defib pad placement),
- shunting of energy which decreases the success rate of normal defibrillation
- burns at the electrodes
- exploding device
- damage create noise that stops the defib monitor from picking up a clean ECG trace
Given the possible issues, it may be that a prominent label "remove before defibrillation" is needed if the device is not designed to handle defib pulses.
cdewitt
Also, putting a statement in the user manual is not useful since someone needing defib probably will not have the manual on them at the time and whoever is administering the defib probably would not take time to read it anyway.
Hello Kry,
I was wondering about your ability to avoid the defib tests for 2-25 and 2-47. The two main issues are whether the device continues to function after the defib pulse is applied, which I firmly believe in your product's case is irrelevant. But the other issue is related to interference of the device during defib, as Peter puts it, making sure it does not get in the way or cause a problem. We found that we could justify one of our products being 'disabled' by the defib, but we could not justify it absorbing too many Joules from the defib pulse.
Secondly, I'm wondering who your auditor is as we have a tie-up in Malta and may want to use them.
Thanks,
Kevin
R Defib-proof applied parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
A IEC 60601-2-2 - Defib-proof test amendment to base standard IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
H Defib Protected Applied Parts: 4mm clearance/creepage? IEC 60601 - Medical Electrical Equipment Safety Standards Series 14
V Setup for testing against ISO14708 clause 16 (protection of the patient from herms caused by heat) Other Medical Device Related Standards 0
J Surge Protectors and other power protection Manufacturing and Related Processes 7
M Data Protection and Privacy Policy - looking for a template/example EU Medical Device Regulations 1
S Battery powered device - electrical protection requirement IEC 60601 - Medical Electrical Equipment Safety Standards Series 18
B IEC 60601 - Creepage Distance - Relay that acts as a means of physical mechanical protection Process Maps, Process Mapping and Turtle Diagrams 0
F General Data Protection Regulation (GDRP) CE Marking (Conformité Européene) / CB Scheme 6
B Operator protection - When to apply table 7, Dielectric strength test voltage IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
D Defibrillation protection for patient connection except for electrodes IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
M Applicability of Means of Protection, working voltage in an Automated External Defibrillator IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
L IEC 60601-1-11 IP22 Compliance - Ingress protection testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
MrTetris GDPR - General Data Protection Regulation - Only applicable to EU data? Other ISO and International Standards and European Regulations 6
M Informational USFDA Final Rule – Human Subject Protection; Acceptance of Data From Clinical Investigations for Medical Devices Medical Device and FDA Regulations and Standards News 0
S Are Defibrillator Protection and Pacemaker pulse detection features mandatory as per IEC 60601-2-25 or 2-27...? IEC 60601 - Medical Electrical Equipment Safety Standards Series 11
S Defibrillator protection test IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
V Software as control or protection will lead to different Software Safety Class? IEC 60601 - Medical Electrical Equipment Safety Standards Series 18
L GDPR scope - "Personal data" definition - General Data Protection Regulation EU Medical Device Regulations 5
S GDPR (General Data Protection Regulation) - My company is ISMS certified IEC 27001 - Information Security Management Systems (ISMS) 3
D IEC 60601 Defibrillation protection test - Metal foil IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
W EU GDPR General Data Protection Regulation - What we need to update for our QMS EU Medical Device Regulations 14
T GDPR - General Data Protection Regulation (EU and UK 2018) Other ISO and International Standards and European Regulations 7
M IEC 60601-1 and Active Current Protection Requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
K Thoughts on the impact of the General Data Protection Regulation? Medical Information Technology, Medical Software and Health Informatics 5
R Internal Audit of Information Security and Data Protection Internal Auditing 6
B Primary lithium battery protection and vented gas IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
P Question on Table 6 "Test voltages for solid insulation forming a MEANS OF PROTECTION IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
K ESD Protection in the Assembly Bay ISO 13485:2016 - Medical Device Quality Management Systems 9
R Determination of IP (International Protection Marking) Rating IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
U USB Connector Operator Protection (MOPP) IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
A IEC 60601-1 cl.15.4.2.1 - Tubular Heating Element (Protection against Overheating) IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
F How to provide 2 MOPP (Means of Patient Protection) - Heating Rod IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
F MOP (Means Of Protection) - Creepage and Clearance questions IEC 60601 - Medical Electrical Equipment Safety Standards Series 19
F Evaluation of MOP (Means of Protection) IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
L Intellectual Property Protection - Storage, Access, Distribution, etc ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B Use of Y1 capacitors for MOPP (means of patient protection) IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
R Security Standard referred to as TAPA (Transported Asset Protection Association) Other ISO and International Standards and European Regulations 1
J Data Protection - Documents on Desktops ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S 510(K) Ownership and Protection from Use by Others 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S How to implement protection for multi-winding transformer? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
W Medical Device Single fault test-protection against fire IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
P IEC 60601-1-11 - Medical Electrical Equipment IP (Ingress Protection) Requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
R Protection of Records from Unauthorized Access or Alteration Records and Data - Quality, Legal and Other Evidence 4
L ESD Protection and Danger for Operators Manufacturing and Related Processes 3
E Data Protection Compliance Plan example wanted Misc. Quality Assurance and Business Systems Related Topics 6
M Can I continue using IEC60601-1 Ed2 PSU for MOOP (Means Of Operator Protection) IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
M What is "protection" as in section 7.5.5 "Preservation of product" ? IATF 16949 - Automotive Quality Systems Standard 7
K Employee ESD Protection Methodologies - Need input. Training - Internal, External, Online and Distance Learning 8
G Placing a dollar value on our QMS (we are looking at IP protection) Quality Manager and Management Related Issues 3
