Is "Did Not Follow Procedures" Sufficient for RCA?
GStough
When doing Root Cause Analysis, and this cause is identified as the 'root cause', is this ever reason enough? Or does it beg more delving for an even deeper root cause? I'm seeing this identified as the 'root cause' for some corrective actions and it concerns me that people aren't following procedures as they should. If this is happening across several business functions, it would indicate a systemic problem, would it not?
It just makes me want to ask one more 'why?' when I see "did not follow procedures" as a root cause on a corrective action request. :mad:
Thoughts?
rjtii51
I see this more often than not for smaller organizations that really do not understand the root cause corrective action process. Typically in root cause you will define the problem statement and while utilizing the 5-Why approach this "response" is typically noted as one of the first Why's. The problem is the supplier/customer is not digging deep enough in the root cause investigation to understand what processes or controls they have in place to prevent an operator from being able to not follow the procedure.
I also have a tough time accepting this as a response, and typically try to work with the supplier/customer to see what other options are available to prevent this issue from re-occurring. I also find it as the "lazy" response out. So typically you will see this response when a supplier/customer does not want to exhaust the effort to find the root cause and can say their operator did not follow the procedure. Most often they will follow that up with explaining how they discussed it with the operator or disciplined the operator and they feel that is the corrective action. Mehhh...
Ninja
Looking for Reality
Thoughts?
FWIW, I am not an auditor...I'm an auditee.
If that were my root cause, I would expect you to ask another "why" or three.
Sometimes 5-Whys are a few too few.
Most Times, the fifth "Why" is filled out first...then the other four are made up to make the form look nice. Sorta defeats the purpose of 5-why, but then most of us auditees question the purpose of 5-why anyway.
My two cents...ask a few more why's.
"I didn't do my job" is not an acceptable root cause...it is the initial problem.
Thoughts?
No! You need to discover why they didn't follow the procedure. Maybe the procedure was written by someone who never did the job and reads like "War and Peace"...:mg:
There's generally a "reasonable" explanation for why they didn't - awareness, for example. The "Kodak" moment when someone explains why it was important to do "X"...:notme:
Thoughts?
I think it's a question of scale more than anything else. An isolated incident might not need corrective action, and the fact that the same issue has occurred in more than one business function isn't necessarily an indication of a systemic breakdown.
Think about it this way: Suppose, for the category "Following Procedures," There are a few hundred opportunities every day. This isn't a stretch for even some small companies. When procedures aren't followed, generally two things can happen:
  1. Nothing
  2. Something bad
While we need to be concerned about both, it's the second one that causes the most concern, and rightfully so. Nonetheless, given the number of opportunities, the "Something bad" could be insignificant and unfixable.
If you suspect that procedures not being followed is a significant concern, you'll gain little by bouncing the CA responses and asking for a bunch of "whys." Use your internal audit process, especially in those cases where someone has used not following procedures as an answer. See what you can do to help. Maybe procedures are too rigid, maybe there are attitude problems, maybe training is an issue. There could be lots of different causes, but the best thing you can do, imo, is audit and find out what's really going on, and then find out how you can help to fix whatever might be broken.
Mikishots
Thoughts?
Yep. more WHYs are needed, if that's the methodology you've chosen. "Did not follow procedures" is no different than "I didn't do it the way I was supposed to". And you wouldn't accept that, would you?
WHY were procedures not followed? Were they not available? Were they unclear? The root cause can lay in the training program (because lack of training itself is not a root cause), document control, D&D....
More examples of no-no's for root cause statements:
- The employee was counselled/talked to.
- Operator error - we retrained him.
- Employee no longer does that job.
- We had to use temps - it's HR's problem.
- Disciplinary process has been put into place.
- Customer used the product incorrectly.
- Replacements have been made.
- We added two more inspectors.
- We fired his a**.
I
isoalchemist
I'd look at scale/extent of the issue. If it is 1 of 100's I would not be to concerned, if it was 10% I'd be asking a lot of questions. Sometimes people just mess up and the root cause may as simple as not reading the procedure.:2cents:
Jen Kirley
Quality and Auditing Expert
If this happens more than once or twice with a given employee I would start to wonder if there's something going on that the QMS doesn't always recognize. See the list of related threads at the bottom of the page? The top one has my paper in it, titled When Employees Don't Follow Procedures.
That's one dimension, but what about the "content" of the procedure? What if it's the "final acceptance" procedure? It's only 1, but wow...
Marc Quiz - Where did the idea of an assembly line come from? Coffee Break and Water Cooler Discussions 4
S Where did FDA 510(K) form 3654 go? Other US Medical Device Regulations 4
A Drawing Issue with Supplier - xb file did not match that of the pdf drawing Nonconformance and Corrective Action 4
Marc How did you "get" a full-time job? (A 2017 discussion) Career and Occupation Discussions 11
Marc When did you first use what we call E-Mail (aka email) today? Coffee Break and Water Cooler Discussions 17
Q Did you use consultants for UDI? Other US Medical Device Regulations 4
B How did you grow your QMS in a Job Shop? Quality Manager and Management Related Issues 11
B Did UL 60601-1 change when the IEC 60601-1 standard changed to the 3rd edition? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
T Test Report - Customer Signature - Customer did not witness test General Measurement Device and Calibration Topics 2
Marc Just for fun - How did you find the Elsmar Discussion Forum Forum News and General Information 9
Wes Bucey Did somebody drop the ball at Boeing? Quality Manager and Management Related Issues 38
Marc Did Stone Age cavemen talk to each other in symbols? Coffee Break and Water Cooler Discussions 7
A The auditor documented that we did not have control of Outsourced Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Hershal Travel! Where have you been of late? What did you see? What do you think? Travel - Hotels, Motels, Planes and Trains 15
T Did any of you use these sticks and rocks? Funny Stuff - Jokes and Humour 32
Q AS9100B Clause 7.5.1.5 - Where did it go in AS9100C? Servicing/Post Delivery Support AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
Jim Wynne What did they do before Powerpoint? Funny Stuff - Jokes and Humour 3
Hershal How did you spend New Years? 2009 Coffee Break and Water Cooler Discussions 8
P New Year Goals and Resolutions - Did you keep your goals and resolutions in 2009? Coffee Break and Water Cooler Discussions 5
M Where did "breakpoint" analysis come from? AIAG MSA book Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
JoCam We did it!!! ISO 13485:2016 - Medical Device Quality Management Systems 7
L Where did the name Elsmar come from? Coffee Break and Water Cooler Discussions 17
N CQC (China Quality Certification) did not issue an Audit Report ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
T Passed our registration audit - Well we did it!!!!!!! ISO 13485:2016 - Medical Device Quality Management Systems 16
P NC from TS16949 stage 2 audit - Internal Auditing - Auditor did not record evidence General Auditing Discussions 15
D Out of tolerance gauge blocks - How did these blocks go out of tolerance? General Measurement Device and Calibration Topics 21
Wes Bucey Laid off? Downsized? What did you learn? Career and Occupation Discussions 80
M TUV NCR 1 - Internal Audit did not audit the second shift Internal Auditing 26
R Looking for a link to a story - Because Nobody did it, the project didn't get done Coffee Break and Water Cooler Discussions 4
Ajit Basrur Certified Biomedical Auditor (ASQ) - What study materials did you use? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 6
Govind Did you know about ASQ Membership value Assessment Calculator? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 5
Govind ISO 10031- Did you know about this standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Wes Bucey Why did they need laptops in the first place? After Work and Weekend Discussion Topics 20
M Did anyone take the CSQE exam on saturday (6/3/2006) Professional Certifications and Degrees 6
C How did you survive your childhood? Coffee Break and Water Cooler Discussions 31
C Why did you not choose mechanical engineering? Interview Question Career and Occupation Discussions 6
C Career Change Question - Why did you choose Quality Engineer as starting job? Career and Occupation Discussions 3
SteelMaiden ISO 14001 certification yesterday afternoon - We did it! ISO 14001:2015 Specific Discussions 15
J Happy 2006 - How did you ring in the New Year Coffee Break and Water Cooler Discussions 16
P Why did ISO assign the number 16949 to TS 16949? Why not 123456 IATF 16949 - Automotive Quality Systems Standard 7
G Green Buildings And Leed - Did anyone go to "greenbuild" in Atlanta last week? Sustainability, Green Initiatives and Ecology 7
J TS 16949 8.5.2 Corrective Action - Auditor did not like the customer related form Nonconformance and Corrective Action 13
I We Did it!! Recommended for TS 16949 certification IATF 16949 - Automotive Quality Systems Standard 8
Marc Acronym DID - Acronym Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
Q SPC Terminoloy & Jargon: Cpk, Ppk etc.: How did it evolve? Capability, Accuracy and Stability - Processes, Machines, etc. 8
Wes Bucey ASQ (American Society for Quality) By-Laws Changes - How did you vote? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 15
Q Curiosity... The popularity of ISO 9001 if NA Automakers did not require it ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
B Question about AQL - Why did the customer reject our products??? AQL - Acceptable Quality Level 6
Govind Did Ken throw away his game? Coffee Break and Water Cooler Discussions 24
T Six Sigma: Did I really want it THAT bad?? Six Sigma 4
