Is Energy Labelling Directive appliable to the Medical Devices?
ShareKing
Hello, all,
I'm working on the DoC of medical product that uses Computer mother boards as the central piece and it integrates LED lights, power supply and liquid-Crystal display as well. By reviewing the directives in the blue guide, I noticed that the MDD and RoHS are appliable. However the Energy Labelling Directive 2010/30/EU seems to be controversary.
It is no doubt that the product is an energy-related Product and it falls in the scope of the directive. However, there is no Guidelines for the ecodesign of medical devices. Therefore the question is:
Is the Energy Labelling Directive appliable for the product?
If yes, should I in the DoC explicitly exclaim the conformity?
If yes, which material should be included in the technical Documentation to give evidence of conformity?
Thank you!
Qing
somashekar
Hello, all,
Thank you!
Qing
Good though.
Medical device word is not found in the directive. The definitions in the 2010/30/EU says Energy related product as " goods having an impact on energy consumption during use "
I found this in the FAQ on the Energy Labelling Directive and its Implementing Regulations
(Not legally binding. Last updated October 2014. This document will be regularly updated.)
(1) Question on lamps and LED modules with luminous flux of less than 30 lumen
It is stipulated in Article 1.2a) that lamps and LED modules with a luminous flux of less than 30 lumen shall be excluded from the scope of the regulation. Does this mean that it does not matter how many lamps the luminaire has as long as all of them separately have a luminous flux of less than 30 lumen? If the lamps are attached to a luminaire and are not exchangeable are you then supposed to add the lamps luminous flux together to see if the requirements (less than a luminous flux of 30 lumen) are met?
(1) Answer on lamps and LED modules with luminous flux of less than 30 lumen
LED modules not intended to be removed by the end-user from the luminaire do not need to be labelled at all (Article 2(d)). It is the luminaire itself which will get the luminaire label, regardless of its light output or that of its LED modules. The label for LED luminaires only shows that the incorporated lamps are LEDs and that they belong to classes A to A++, without more precise allocation, and without any testing to be done other than checking that the included light sources are indeed LEDs. When LED modules are sold as spare parts, they have to be labelled and they are indeed excluded under 30 lumens. This is coherent with the exclusion of other replacement lamps under 30 lumens, which could equally be present in a luminaire in high quantities, adding up to substantial light output.
May be this will set some direction.
I see this directive applicable to Electrical and Electronic appliances, Lighting, and several type of heaters and storage equipment.
Ed Panek Interesting Perspective on Russia, Ukraine, China, energy and the Future Coffee Break and Water Cooler Discussions 0
B 3'rd party mains power supply with unknown energy source level. CE Marking (Conformité Européene) / CB Scheme 3
bayram kevrek EN 60350-1 & EN 50304 Energy Consumption Standarts Various Other Specifications, Standards, and related Requirements 0
L IEC 62368-1 / Electrical Energy Source vs. Power Source? CE Marking (Conformité Européene) / CB Scheme 2
Sidney Vianna NASA to Develop a Novel Approach for All-Electric Aircraft Using Cryogenic Liquid Hydrogen as Energy Storage World News 2
Sidney Vianna Interesting Discussion World wide energy demand will peak in the early 2030's Sustainability, Green Initiatives and Ecology 0
Rincewind Pressure energy - Essential Requirements (MDD/MDR) EU Medical Device Regulations 2
kedarg6500 APQP & PPAP for Process Industry - Concept for Waste to Energy Program APQP and PPAP 0
Sidney Vianna Promotion Threads The DNV Energy Transition Outlook - 5th Edition, September 2021 Sustainability, Green Initiatives and Ecology 2
Marc The Future of Geothermal Energy Coffee Break and Water Cooler Discussions 0
E RF Energy Treatment Devices for CFDA Registration China Medical Device Regulations 1
W What is ISO 50001 (energy management systems)? Sustainability, Green Initiatives and Ecology 1
V NESCC (Nuclear Energy Standards Coordination Collaborative) participants here? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 2
R Energy Baseline in ISO 50001:2011 Sustainability, Green Initiatives and Ecology 1
A Auditor Man-Day table for ISO 50001 (Energy Management Systems) Sustainability, Green Initiatives and Ecology 3
S What is the future of ISO 50001 EnMS (Energy Management Systems)? Miscellaneous Environmental Standards and EMS Related Discussions 3
J Does a Lower Thermostat Setting really save Energy? Coffee Break and Water Cooler Discussions 11
D Creepage and Clearance for high voltage low energy circuits IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
P Energy Saving Walkthrough Audit Suggestions General Auditing Discussions 15
E Applicability of Defibrillator Energy Test to Implantable Devices IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
Hershal Update for EPA Energy Star and question General Measurement Device and Calibration Topics 3
R Energy and Environmental Legal and other requirements in Canada Miscellaneous Environmental Standards and EMS Related Discussions 2
somashekar EXAM for Energy Managers and Energy Auditors (INDIA) Miscellaneous Environmental Standards and EMS Related Discussions 2
R Is FCC required for Medical Equipment without Radio Frequency Energy? Other US Medical Device Regulations 6
P Advice for Career Change - Energy or Customer service ? Career and Occupation Discussions 2
J Define Energy Used/Delivered - Applicable to Electrical or Mechanical Power or both? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M ISO 50001 Energy Management Lead Auditor Training Training - Internal, External, Online and Distance Learning 4
M Free Webinars on ISO 50001 Energy Management - 2011 and 2012 Miscellaneous Environmental Standards and EMS Related Discussions 6
D Defibrillation Energy Reduction ? PWB Connector Pitch Spacing IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
Hershal Who among users here is involved in ENERGY STAR? Sustainability, Green Initiatives and Ecology 8
A Significant Aspects required by Auditor for Water and Energy Miscellaneous Environmental Standards and EMS Related Discussions 24
K Energy Reduction Objectives and Targets help ISO 14001:2015 Specific Discussions 2
Randy ISO 50001 Energy Management Systems - Requirements Sustainability, Green Initiatives and Ecology 29
somashekar Making permanent savings through Active Energy Efficiency Sustainability, Green Initiatives and Ecology 7
G Energy Policy Example wanted Sustainability, Green Initiatives and Ecology 2
somashekar The Plasma Thermal Destruction and Recovery (PTDR) Waste-to-Energy Technology Sustainability, Green Initiatives and Ecology 4
somashekar Information sharing: Week 19, 2010 (SOLAR ENERGY) The Reading Room 0
somashekar Information sharing: Week 19, 2010 (ENERGY) The Reading Room 0
L Korean energy standards Various Other Specifications, Standards, and related Requirements 1
D Renewable Energy - Is there is a standard that we must follow? Other ISO and International Standards and European Regulations 25
G Saving energy through GOOGLE!!! After Work and Weekend Discussion Topics 6
A Positive Performance Indicator (PPI) for Energy/Utilities organization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S How to measure Energy Use for individual users in a shared business Miscellaneous Environmental Standards and EMS Related Discussions 23
O Personnel Turnover & Energy Consumption Rate Career and Occupation Discussions 3
Y Energy Savings in Glass Tablewares Company - Continuous Improvement Manufacturing and Related Processes 3
A ISO sharpens focus on int'l stds for energy efficiency and renewable energy source Other ISO and International Standards and European Regulations 0
Steve Prevette Example SPC Control Charts posted by the Department of Energy EFCOG Statistical Analysis Tools, Techniques and SPC 1
Jen Kirley "Micro Combined-Heat-and-Power" System (micro-CHP) - The future of home energy? World News 10
Claes Gefvenberg MR Agenda - Combined Quality, Environmental & Energy Mgmt System Other ISO and International Standards and European Regulations 5
Marc Plasma Screen TVs Use 4 Times the Energy CRT TVs Do After Work and Weekend Discussion Topics 10
