Is Failure to achieve a Goal a Major Non-Conformance?
#11
My point is, Jennifer, that a blanket 30 days isn't appropriate for ALL CAs! Some should be done within 24 hours, if they warrant it. Sure, that's within 30 days, but what about those which don't have a timetable of fewer than 30 days? Design related? Customer related? As with many things in life, doing something to a calendar isn't an appropriate method to show how effective CA is. They could be closing is 100% within 30 days, but they were 20 days late!
Jen Kirley
Quality and Auditing Expert
#12
Oh I am sorry I misunderstood you, yes I totally agree. :agree:
I have had to defend a year-old open CA with a TS 16949 auditor. I did it by explaining its containment, the fact that it needed some rather extensive resources to fix the scheduling bugs in the app, and a string of notes in my corrective action tracking log what had been verified done on what day, meetings and who committed to what, reaudit results and following actions, etc. He gave up and moved on.
Kevin Mader
One of THE Original Covers!
#13
Something to guard against: extensions on extensions on extensions.
In years past, CA closures were prolonged (resource constraints, interest...the usual suspects). It got easy for folks to ask for an extension and then close something out a day or two later. Metrics improved but of course (CAPAs done within our arbitrarily set 30 days, yada-yada) but didn't tell the whole story. I ended up creating a second metric to track the number of extensions given. This curbed padding a number while allowing another to run away. Sad it had to happen that way.
OK - where's my soap box?
Deming warned about setting Goals without a Method. Lloyd Nelson also warned that the most important numbers are unknown and unknowable. Both agreed that abstaining from managing a process because a 'hard' number could not be established was not an answer either. When establishing 'hard' numbers, folks must be intimate with the process, understand control limits and process controls before setting them. Otherwise, numbers are arbitrary and usually end up causing more trouble than you would have had without them. Managing a process, CA (CAPA) or otherwise, requires theory and knowledge of the process. Statistically speaking, is there a difference between 75% and 85%? Examining the process closely might reveal that either exist between the control limits - no difference (each had the equal chance to appear). What happens is that folks kick off the new year with new 'numbers'. Business folks are infamous for doing this. What's needed is appropriate goal setting under the conditions Deming and Nelson suggest. In a nut shell, forget the goal setting and manage the process. Show auditors this kind of data, this level of intimacy, and you won't have to argue much at a closing meeting
Good luck everyone!
Sidney Vianna
Post Responsibly
#14
Could an auditor consider this a Major non-conformance?
I will assume you are talking about an external (CB) auditor type.
In addition to the great advice you have already received, especially the one that questions the adequacy of setting a goal such as this, I would say: If I were an external auditor assessing this issue, I would focus on top management and their involvement in the management review, as "status of corrective actions" is a mandatory item to be reviewed. I would interview top management and ascertain if they are aware of the situation and their knowledge of the reasons on why, apparently, closure of corrective actions take longer than you anticipate.
But, without a question, pre-defined set times for CAR closure is not a wise approach.
M Test failure Root cause not found Customer Complaints 10
T Risks of failure to meet intended use ISO 14971 - Medical Device Risk Management 6
P Missing 1m visual alarm signal in case of software/display failure, mitigation? ISO 14971 - Medical Device Risk Management 3
D Failure rate vs hazard rate vs rate of failure Reliability Analysis - Predictions, Testing and Standards 2
silentmonkey How to measure severity if my product is designed for emergency use and failure would result in death? ISO 14971 - Medical Device Risk Management 9
C Corrective action for failure in documents control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
T Root Cause Failure Analysis - Not following Customer packaging Specification Problem Solving, Root Cause Fault and Failure Analysis 9
A Exact terms for a plating failure and difference between rejection rate and failure rate Manufacturing and Related Processes 9
JoCam Failure to test Class I medical device to IEC 60601-1-11 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
C Kaizen Events - Factors Affecting Failure Lean in Manufacturing and Service Industries 13
C Failure nets - Same level effects FMEA and Control Plans 0
C Failure mode at 0h, vs. 1 year vs. 5 year... FMEA and Control Plans 8
R How to properly use Survival Analysis to predict time to machine failure Reliability Analysis - Predictions, Testing and Standards 0
D Testing to failure for design verification Reliability Analysis - Predictions, Testing and Standards 11
M Informational US FDA – Ethicon Recalls Circular Staplers for Insufficient Firing and Failure to Completely Form Staples Medical Device and FDA Regulations and Standards News 0
C Detection Action for Failure Effects - AIAG 4th Edition Layout FMEA and Control Plans 5
Marc NASA Says Oregon Company Metals Fraud Caused $700 Million Satellite Failure - 2019 World News 16
C PCBA Hardware Component different failure types - How to rate detection? FMEA and Control Plans 8
N PFMEA repetitive failure modes in subsecuent stations. FMEA and Control Plans 1
P Detection rating for a user (surgeon) related failure mode in DFMEA APQP and PPAP 3
J How to look up Failure Modes on FDA website FMEA and Control Plans 4
P Electronic component failure analysis turnaround time Reliability Analysis - Predictions, Testing and Standards 0
C Design for Assembly in DFMEA - Failure Effect of Sub-System(s) FMEA and Control Plans 5
Marc Server RAM Failure - 7 Dec 2018 Forum News and General Information 3
K Spot weld - Peel test failure Manufacturing and Related Processes 3
C Electrical Power Plant Supply failure in PFMEAs FMEA and Control Plans 10
kisxena Memo to File - Failure to Validate Supply Chain Security Management Systems 1
Y IEC 62304 Section 4.3(a) - 100% probability of failure IEC 62304 - Medical Device Software Life Cycle Processes 3
S FMEA column column ''therblig motion'' for a given potential failure FMEA and Control Plans 12
J What does "factional and failure dependencies“ mean? FMEA and Control Plans 1
N PFMEA Potential Failure Mode for Weight FMEA and Control Plans 5
P Root Cause for a Process Validation Batch Failure 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
M Infusion Pump Power Failure Alarm IEC 60601-2-24 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
K Determining Effect of Failure without a DFMEA (Design FMEA) FMEA and Control Plans 1
R Will multi-time flashovers constitute a failure of Hi-Pot test? IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
P IATF 16949 - 10.2.5 Warranty and 10.2.6 Field failure IATF 16949 - Automotive Quality Systems Standard 1
J Medical Device Failure Effects - Where to draw the line? FMEA and Control Plans 8
kedarg6500 Potential Effects of Failure(s) FMEA and Control Plans 23
Marc Definition PFH - Probability of dangerous failure per hour Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
Marc Definition PFD - Probability of failure on demand Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
C Squeeze in one more - Rate of failure Statistical Analysis Tools, Techniques and SPC 6
L First Time Completing a 5 Why/RootCause Failure Analysis Nonconformance and Corrective Action 8
Z Failure Mode Identification in PFMEA according to AIAG FMEA Rev.4 FMEA and Control Plans 6
B IPCD Sterility test failure during MPQ (EO sterilization validation) ISO 13485:2016 - Medical Device Quality Management Systems 2
A Failure Mode from Operator "Components Fallen but Loaded" FMEA and Control Plans 3
M Population failure rate based on attribute data Statistical Analysis Tools, Techniques and SPC 4
P UFMEA - Use Failure Mode Effects Analysis FMEA and Control Plans 7
S Seeking Feedback on ASQ Guide to Failure Mode and Effect Analysis FMEA and Control Plans 2
