Good day
So why do you need GLP documentation for ISO 17025 environment...
Good day
@DarkJester ;
The short answer is, 'you don't.
As you may know both the EPA and FDA (title 40 and title 21 respectively [others that I'm not aware of ??], have developed rules for GLP.
GLP, while many aspects overlap with ISO 17025 requirements, is a separate item and may or may not be an additional consideration (the reason others asked you about the scope of your laboratory).
Is your laboratory already accredited to ISO 17025 ? (if so, can you please post the actual verbatim scope of your 17025 accreditation? ...[what you provided seems like a description/paraphrase of an actual boundary scope] ).
In short, if your lab is ISO 17025 accredited and the stated titles are applicable (by definition and/or contract consideration with a client), then your lab could simply do a gap analysis between your 17025 system and the applicable title rules.
Regardless of the approach, I would highly recommend
against creating /managing two "systems". If your lab is ISO 17025 accredited, simply address any additional applicable title rules within your lab ISO 17025 system.
Hope this helps.
Be well.
