Is Heat Treatment for Metal a Special Process?
Big Jim
#12
i think it is not special process because we have a device to measure the Hardness of metal
Is hardness the only characteristic you care about, or is hardness used to confirm that the heat treat has progressed to the point you want?
Depending on what you are after, hardness could be part of your validation or it might be your ability to fully test the outcome.
You really need to be able to answer the question "does hardness tell us all we need to know?"
The heat treat shops I call on check hardness, but they also keep meticulous records about oven temperatures and times during the heat treat process. In their case, hardness is not enough.
Kales Veggie
People: The Vital Few
#13
Do you measure 100% of the parts?
What is your process capability?
Is the hardness check destructive to the part?
Is hardness the only criteria? (what about through hardening, micro/macro structure?
What is your customer requirement?
I think it is unless it can be proven otherwise?
#14
Plus, an indentor check isn't a check of homogeneity of the hardness throughout the part.....
No, it is a special process and requires validation.....
(unless you're checking the hardness of dairy products......)
#16
As in the Welding - Is welding always a special process per ISO9001:2000 Clause 7.5.2 thread, my conclusion is that all encompassing generalizations bring a degree of risk.
Well yes Sidney, however, once again, since we're only given a general question, we can only reasonably answer in general terms, lest we confuse the issue with all the caveats..........and what use is that for 90+% of the cases we're presented with.
There is an inherent risk with anything you read here. Who knows anything about the background competencies, knowledge etc. of anyone offering advice?
Sidney Vianna
Post Responsibly
#17
Well yes Sidney, however, once again, since we're only given a general question, we can only reasonably answer in general terms, lest we confuse the issue with all the caveats..........and what use is that for 90+% of the cases we're presented with.?
In another post, you were concerned with someone potentially misleading readers here.
If someone asks
Is Heat treatment for metal a special process?
the only possible answer is: Not always/It depends.
To state that heat treating is ALWAYS a special process that requires validation would be misleading, in my opinion.
#19
If someone asks the only possible answer is: Not always/It depends.
So, I will have to disagree with you. Heat treatment in my experience - not opinion - has always been something that cannot be checked - adequately - after the product has been processed! Ask anyone who has ever cooked something......
R MSA studies for Heat Treatment Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M API 6D-2014 24th Ed. Pto 6.10 - Heat Treatment Equipment Qualifications Oil and Gas Industry Standards and Regulations 4
S Heat Treatment - Soaking time interpretation Manufacturing and Related Processes 5
E CQI 9 (Heat Treatment) Assessment Requirements - Company and Customer Requirements Customer and Company Specific Requirements 1
S Paperless Temperature Recorder for Temperature Surveys on Heat Treatment Ovens General Measurement Device and Calibration Topics 6
G SPC in Heat Treatment Workshop Statistical Analysis Tools, Techniques and SPC 2
A NADCAP AC 7101/03 Heat Treatment Process Acceptance Tests AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
R CQI-9 Heat Treatment Process Table C question IATF 16949 - Automotive Quality Systems Standard 3
K Heat Treatment (Softening) on Cast Iron before it can be drilled to form Thread? Manufacturing and Related Processes 4
W What can be Root Cause Analysis Methodology - Heat Treatment of Carbon-based Products Problem Solving, Root Cause Fault and Failure Analysis 5
W Calculating Minimum Heat Treatment Quench Bath Size Manufacturing and Related Processes 2
S AS9100 REV B Sampling Requirements - Heat Treatment of Large Cylinders AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
T Heat Treatment Process FMEA example wanted FMEA and Control Plans 5
somashekar Information sharing: Week 27, 2010 (HEAT TREATMENT) The Reading Room 3
A Ovality and Flatness generated after Heat Treatment of Rolled Rings Manufacturing and Related Processes 3
S Benchmarking of Capability, Accuracy and Stability analyses - In Heat treatment Capability, Accuracy and Stability - Processes, Machines, etc. 3
C ID (Inside Diameter) Threads Shrinking due to Heat Treatment and Weld Manufacturing and Related Processes 11
N Lot Capability - Forging -> CNC Machining -> Heat treatment -> Packaging Statistical Analysis Tools, Techniques and SPC 3
A Austempering Heat Treatment Machine - Problem regarding Decarb (less carbon) Manufacturing and Related Processes 16
J Heat treatment inspection and Process capability index Cpk Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
O CQI-9 #1.9 - Heat Treatment - Management shall review the furnace monitoring systems IATF 16949 - Automotive Quality Systems Standard 3
B Design of Experiment (DOE) for Heat Treatment Process Statistical Analysis Tools, Techniques and SPC 4
K CQI-9 - Heat Treatment standard for Automotive Sector IATF 16949 - Automotive Quality Systems Standard 1
A Heat Treatment Validation - Titanium (6Al 4V) for 2 hours @ 700 Deg C Manufacturing and Related Processes 6
D Process Qualification - Heat Treatment Process Furnace - What is Thermal Mapping? Manufacturing and Related Processes 7
M ISO 9002 Section 4.7 - Heat Treatment - Supplies and related services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
V Setup for testing against ISO14708 clause 16 (protection of the patient from herms caused by heat) Other Medical Device Related Standards 0
E 60950-1 resistance to abnormal heat test Various Other Specifications, Standards, and related Requirements 0
S Heat Sealers Upper and lower limit setting during OQ for Heat Sealer Qualification and Validation (including 21 CFR Part 11) 0
K Calculating Heat Dissipation Manufacturing and Related Processes 1
B API Q1 5.7.1.5 Process Validation - Machining, heat treating, Manganese Phosphate and Zinc Plating Manufacturing and Related Processes 2
G Heat Number on CofC - Stainless steel tube Manufacturing and Related Processes 2
K Moist Heat Sterilization worldwide Requirements and Regulations Other Medical Device Regulations World-Wide 1
D Minor non-conformance for not receiving a CofC from a heat treater Manufacturing and Related Processes 10
T Heat treat test dimple Manufacturing and Related Processes 3
X Heat Treat - Verifying mechanical properties on heat treated material per the ASTM Manufacturing and Related Processes 6
Ron Rompen The Effect of Heat on Production and Quality Human Factors and Ergonomics in Engineering 14
S Performing PQ on a Small (tabletop) Air Heat Treating Oven ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
H Standards to use for Propylene Glycol Heat/Cooler Fluid in a Device RoHS, REACH, ELV, IMDS and Restricted Substances 2
C Practical use of Heat Input calculation for Manual MIG Welding Manufacturing and Related Processes 4
S Industrial Aseptic Bag Heat Sealing Sampling and Qualification Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
I AS9100 PPAP requirements for outside Heat Treat vendors/suppiers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
S AMS 2750E Heat Treat Furnace System Accuracy Test SAT Report question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S Heat Map ISO/TS 16949:2009 Clauses IATF 16949 - Automotive Quality Systems Standard 1
M AMS2770 Aluminum Heat Treat - Determining Soak Time Various Other Specifications, Standards, and related Requirements 1
S Thermal Sensitivity Testing - Heat Lamp - ILY - Increased blood circulation IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
F Heat and Moisture Oxygen Port Changes Classification 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
J ISO 17665-1 & 2 Review and approval of validation (of moist heat sterilizers) Other ISO and International Standards and European Regulations 3
Q Heat Treat Steel, Rockwell C - Variability in Complex Machined Shapes Manufacturing and Related Processes 7
