i think it is not special process because we have a device to measure the Hardness of metal
Dear Tech.
I think your ability to measure hardness is in a way giving you the confidence to say it is not special. However as said in one of the thread here, heat treatment is a very complex process and the desired results can be achieved only in the controlled conditions necessary for the desired result.
I have this list for you to think and make a judgement about it :
1. How big is the heat treatment furnace ?
2. Are you able to get the same range of temperature at all zones of the furnace ?
3. What is the load everytime to the furnace ? Is it same or it varies ?
4. Do you measure the hardness of parts heat treated from all zones of the furnace each time ?
Hardness measurement capability that you have is one of the required measure to assess that the set parameter for the heat treatment process is good. It helps you to validate and revalidate the heat treatment process as and when charge batch changes or a maintenance schedule on the furnace is executed or any such repairs are done to the furnace. Hence on a larger look you have to notice that you have ability to validate the heat treatment process and that is the requirement.
Hence with just the ability to measure hardness, do not dilute the requirment of validation of this very critical metal process. It needs validation and constant revalidation as you go along.
I hope you are able to appreciate the requirement my friend .... good luck
