Is Heat Treatment for Metal a Special Process?
BradM
#61
The answer is: It depends. Is the heat treatment done solely for hardening the part? Is the hardening of the metal localized to a specific area of the part? Can you effectively measure the hardness of the area without inducing unacceptable denting onto the part?
If you can answer these 3 questions as "yes", then, this is not a process that needs to be validated since you can effectively "inspect" the characteristics at the end of the process, against the requirements.
:agree1::yes:
Hi all! I know I'm late into the discussion. One always hates Old Sayings. But that does not take away from their legitimacy.:D Saying, it depends.
Whether heat treat is a special process will depend on several factors including the type of material, the ability to run post checks, redundant checks, etc.
If you are solution heat treating aluminum, it's probably too late to find out there was a temperature problem when a part gives way under stress 10,000 feet in the air.:D
However, (thanks NADCAP) a Chem Mill process was having to do uniformity surveys, which the owners were strongly objecting. They know their process, and they can tell by the condition of the skin when it comes out if there is a hot spot/ cold spot. Now... would uniformity surveys be helpful? Yes. Did it require validation? No. They could justify the acceptance of the product (depth/deviation of etching) from the final product, and did not need the uniformity survey.
You are heat treating to do something to the product/surface. If the acceptable results of that something can be verified through inspection/testing or some other means, that the validation of the process is optional. If it cannot be conclusively tested, then validation is in the forecast.:2cents:
blue moon
#63
Is Heat Treatment a Special Process?
Dear Friends
Now in our factory we make heat treatment for metal to raise the rigidity of metal and after finish the heat treatment process we meausre the rigidity " Hardness" of the metal if we didn't reach the desired value we repeat this process again
Is it will be a special process or not ?
where :
clause 7.5.2 at ISO 9001:2008: Validation of processes for production and service provision The organization shall validate any processes for production and service provision where the resulting output cannot be verified by subsequent monitoring or measurement and "But already we have the device to measure the rigidity " Hardness".
, as a consequence, deficiencies become apparent only after the product is in use or the service has been delivered.
please advice
blue moon
#64
Re: Is Heat Treatment a Special Process?
My Question focus on
1- if we have a device to check the quality and check the characterstics
2- if we can check error in our factory before using by customer or before deliver to customer
at this case the process will not be special process
because the standard say
The organization shall validate any processes for production and service provision where the resulting output cannot be verified by subsequent monitoring or measurement and, as a consequence, deficiencies become apparent only after the product is in use or the service has been delivered.
somashekar
#65
I will argue the other way. Just because you have the instrument, are you measuring the hardness of all the parts, at all the surface of the parts ? If you do this process item by item and then test at various places and average it to find the value meeting requirement, I will agree. However I am sure you cannot do this way. You have the measuring ability to assess and fix the heat treatment parameters by several sample results. Heat treatment is a Special process and you have asked this question earlier also if I am correct. Are you still not convinced ?
U
Umang Vidyarthi
#66
Dear Friends
where :
please advice
Heat treatment is a special process, since the resulting output can not be verified by subsequent measuring/monitoring.
BTW it is a replica of your post on Is Heat Treatment for Metal a Special Process? which was discussed here in detail. If you need further discussion, it would be better to resume it on the existing thread.
Umang :D
Nota-bene: oops! Somashekhar beat me on this by two minutes.
blue moon
#67
Really last time i can't catch points exacatlly so i hope if you help me step by step on this way
i have one question then i will ask general questions
we also deign Molds and Dies and after manfucaturing of it we validate at customer end
then is the process of design of Molds and dies is special process
blue moon
#68
BTW it is a replica of your post on 8 Aug.2009. which was discussed here in detail. If you need further discussion, it would be better to resume it on the existing thread.
Umang :D
I am so sorry for this
really i am so sorry
SteelMaiden
#69
It's OK, Tech4. We all make mistakes, so don't worry too much about it. The other thread does give a lot of information, as well as examples of heat treating as a special, or a non-special process. Heat treating is not always a special process, we usually think of it as one, but there are some circumstances that do no qualify. Check out the other thread, and also remember that there is a good search function as well as similar threads listed at the bottom of the page.
P
Phiobi
#70
In my experience all aerospace primes call for HT to be used as a special process. This is in both AS9100 and NADCAP terms.
R MSA studies for Heat Treatment Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M API 6D-2014 24th Ed. Pto 6.10 - Heat Treatment Equipment Qualifications Oil and Gas Industry Standards and Regulations 4
S Heat Treatment - Soaking time interpretation Manufacturing and Related Processes 5
E CQI 9 (Heat Treatment) Assessment Requirements - Company and Customer Requirements Customer and Company Specific Requirements 1
S Paperless Temperature Recorder for Temperature Surveys on Heat Treatment Ovens General Measurement Device and Calibration Topics 6
G SPC in Heat Treatment Workshop Statistical Analysis Tools, Techniques and SPC 2
A NADCAP AC 7101/03 Heat Treatment Process Acceptance Tests AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
R CQI-9 Heat Treatment Process Table C question IATF 16949 - Automotive Quality Systems Standard 3
K Heat Treatment (Softening) on Cast Iron before it can be drilled to form Thread? Manufacturing and Related Processes 4
W What can be Root Cause Analysis Methodology - Heat Treatment of Carbon-based Products Problem Solving, Root Cause Fault and Failure Analysis 5
W Calculating Minimum Heat Treatment Quench Bath Size Manufacturing and Related Processes 2
S AS9100 REV B Sampling Requirements - Heat Treatment of Large Cylinders AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
T Heat Treatment Process FMEA example wanted FMEA and Control Plans 5
somashekar Information sharing: Week 27, 2010 (HEAT TREATMENT) The Reading Room 3
A Ovality and Flatness generated after Heat Treatment of Rolled Rings Manufacturing and Related Processes 3
S Benchmarking of Capability, Accuracy and Stability analyses - In Heat treatment Capability, Accuracy and Stability - Processes, Machines, etc. 3
C ID (Inside Diameter) Threads Shrinking due to Heat Treatment and Weld Manufacturing and Related Processes 11
N Lot Capability - Forging -> CNC Machining -> Heat treatment -> Packaging Statistical Analysis Tools, Techniques and SPC 3
A Austempering Heat Treatment Machine - Problem regarding Decarb (less carbon) Manufacturing and Related Processes 16
J Heat treatment inspection and Process capability index Cpk Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
O CQI-9 #1.9 - Heat Treatment - Management shall review the furnace monitoring systems IATF 16949 - Automotive Quality Systems Standard 3
B Design of Experiment (DOE) for Heat Treatment Process Statistical Analysis Tools, Techniques and SPC 4
K CQI-9 - Heat Treatment standard for Automotive Sector IATF 16949 - Automotive Quality Systems Standard 1
A Heat Treatment Validation - Titanium (6Al 4V) for 2 hours @ 700 Deg C Manufacturing and Related Processes 6
D Process Qualification - Heat Treatment Process Furnace - What is Thermal Mapping? Manufacturing and Related Processes 7
M ISO 9002 Section 4.7 - Heat Treatment - Supplies and related services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
V Setup for testing against ISO14708 clause 16 (protection of the patient from herms caused by heat) Other Medical Device Related Standards 0
E 60950-1 resistance to abnormal heat test Various Other Specifications, Standards, and related Requirements 0
S Heat Sealers Upper and lower limit setting during OQ for Heat Sealer Qualification and Validation (including 21 CFR Part 11) 0
K Calculating Heat Dissipation Manufacturing and Related Processes 1
B API Q1 5.7.1.5 Process Validation - Machining, heat treating, Manganese Phosphate and Zinc Plating Manufacturing and Related Processes 2
G Heat Number on CofC - Stainless steel tube Manufacturing and Related Processes 2
K Moist Heat Sterilization worldwide Requirements and Regulations Other Medical Device Regulations World-Wide 1
D Minor non-conformance for not receiving a CofC from a heat treater Manufacturing and Related Processes 10
T Heat treat test dimple Manufacturing and Related Processes 3
X Heat Treat - Verifying mechanical properties on heat treated material per the ASTM Manufacturing and Related Processes 6
Ron Rompen The Effect of Heat on Production and Quality Human Factors and Ergonomics in Engineering 14
S Performing PQ on a Small (tabletop) Air Heat Treating Oven ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
H Standards to use for Propylene Glycol Heat/Cooler Fluid in a Device RoHS, REACH, ELV, IMDS and Restricted Substances 2
C Practical use of Heat Input calculation for Manual MIG Welding Manufacturing and Related Processes 4
S Industrial Aseptic Bag Heat Sealing Sampling and Qualification Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
I AS9100 PPAP requirements for outside Heat Treat vendors/suppiers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
S AMS 2750E Heat Treat Furnace System Accuracy Test SAT Report question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S Heat Map ISO/TS 16949:2009 Clauses IATF 16949 - Automotive Quality Systems Standard 1
M AMS2770 Aluminum Heat Treat - Determining Soak Time Various Other Specifications, Standards, and related Requirements 1
S Thermal Sensitivity Testing - Heat Lamp - ILY - Increased blood circulation IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
F Heat and Moisture Oxygen Port Changes Classification 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
J ISO 17665-1 & 2 Review and approval of validation (of moist heat sterilizers) Other ISO and International Standards and European Regulations 3
Q Heat Treat Steel, Rockwell C - Variability in Complex Machined Shapes Manufacturing and Related Processes 7
