Is Heat Treatment for Metal a Special Process?
blue moon
#72
Re: Is Heat Treatment a Special Process?
I will argue the other way. Just because you have the instrument, are you measuring the hardness of all the parts, at all the surface of the parts ? If you do this process item by item and then test at various places and average it to find the value meeting requirement, I will agree. However I am sure you cannot do this way. You have the measuring ability to assess and fix the heat treatment parameters by several sample results. Heat treatment is a Special process and you have asked this question earlier also if I am correct. Are you still not convinced ?
many characterstics measured by using sampling plan, where we can't inspect 100% and may be we have a customer compalints regarding this
all of these process could be special process ?
U
Umang Vidyarthi
#73
I am so sorry for this
really i am so sorry
Don't have to feel sorry. My purpose of pointing out was that there was a lot of discussion on the parent thread by esteemed covers, who had invested their valuable time, and any duplication of effort is not value added. Besides, many may not see or opine on the second thread. Miner has solved the problem by merging the two threads.
Apparently you are not satisfied by the opinions given thus far. No prob, covers will try to satisfy all your fresh querries.
I merged these two threads for continuity.
:thanks:
Umang :D
Nota-bene: May we add a poll to this?
L
Lexylou
#74
Good Morning.....Speaking of Special Processes, the company that I am working with is a tool shop that sometimes will do some welding in cavity surfaces. Is this considered a Special Process and what will they need to do in order to meet the ISO 9001:2008 requirement?
Big Jim
#75
Welding generally is considered a special process.
The premium (but not always cost effective) answer is to certify the welders.
My concept of what you need to prove is that the welds have been properly applied and will hold up to the conditions they will be subject to. You may be able to find a way to accomplish that without full blown certification. It may entail having the welders perform some test welds on material the same as or very similar to what they are doing for production (scrap may be appropriate) and then determine some in-house testing you can do to confirm that the welds have had proper penetration. That could include something like sawing it apart or bending it with a hammer and vice. This should be repeated from time to time to confirm that the skill is still viable. You can determine the interval. It could be monthly or perhaps every six months, depending on how consistent the welders are and how critical the welds are.
If your production managers understand what they need to accomplish, they may be able to come up with a viable test that can fulfill your validation requirements.
Keep in mind that with welding, it is critical that the weld joint is stronger than the parent metal. If pulled apart, the separation needs to come from the parent metal, not the weld joint. The primary skill needed is for the welder to know how to control the molten puddle.
Let us know what you come up with.
W
w_grunfeld
#76
Welding is considered a special process and while Jim focused on the welders certification I'd like to point out that there is also the qualification of the process itself. Depending on the type of weldment, there are variables of the process itself that need to be controlled, such as the electrodes, the current, the gas, times, etc. I would say that you need to develop an internal process specification, picking from standards such as the AWS D1.1,the sections that are relevant for your specific application . The level of inspection required may range from visual (to defined criteria) , through die penetrant, to X ray, all depending on the criticality of the application. A weldment for a pressure vessel or airframe structure is obviuosly a lot more stringent than for a household or other non critical application.
6
6 axis
#77
I agree heat treatment is a process.I was given a non conformity by external auditors for not maintaining oven temperature logs,now i have improved my process with clear recording of logs and hardness validation.
L
Lexylou
#78
6 Axis, the company that I am working with does Heat Treat but on Non-Critical parts. Do you think an auditor will be looking for a log record book for oven temp for that?
Big Jim
#79
They certainly could be looking for evidence of validation. Process controls such as oven temperatures as well as oven surveys and oven calibrations are certainly possibilities.
How do you validate your heat treating? If you have never considered it, now is the time.
L
Lexylou
#80
This company outsources most of their heat treating. When the part returns the toolmaker does a Rockwell inspection to verify the heat treat was done. The only record that is kept of this inspection is the toolmakers initials and date on the shipper that he has accepted it. Most of their customers do not require anything more than that. This shipper is sent to the customer only when they request it.
But this company also does some of their own heat treating on non-critical parts that they basically do the same Rockwell Inspection but once again no records are maintained for this.
Since this is a tool shop that deals more with Special Processes than I do at the sister company I want to make sure that they are meeting the all the requirements and I am pretty sure that they are not.
They do the exact same thing for welding......
Thanks for your help
R MSA studies for Heat Treatment Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M API 6D-2014 24th Ed. Pto 6.10 - Heat Treatment Equipment Qualifications Oil and Gas Industry Standards and Regulations 4
S Heat Treatment - Soaking time interpretation Manufacturing and Related Processes 5
E CQI 9 (Heat Treatment) Assessment Requirements - Company and Customer Requirements Customer and Company Specific Requirements 1
S Paperless Temperature Recorder for Temperature Surveys on Heat Treatment Ovens General Measurement Device and Calibration Topics 6
G SPC in Heat Treatment Workshop Statistical Analysis Tools, Techniques and SPC 2
A NADCAP AC 7101/03 Heat Treatment Process Acceptance Tests AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
R CQI-9 Heat Treatment Process Table C question IATF 16949 - Automotive Quality Systems Standard 3
K Heat Treatment (Softening) on Cast Iron before it can be drilled to form Thread? Manufacturing and Related Processes 4
W What can be Root Cause Analysis Methodology - Heat Treatment of Carbon-based Products Problem Solving, Root Cause Fault and Failure Analysis 5
W Calculating Minimum Heat Treatment Quench Bath Size Manufacturing and Related Processes 2
S AS9100 REV B Sampling Requirements - Heat Treatment of Large Cylinders AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
T Heat Treatment Process FMEA example wanted FMEA and Control Plans 5
somashekar Information sharing: Week 27, 2010 (HEAT TREATMENT) The Reading Room 3
A Ovality and Flatness generated after Heat Treatment of Rolled Rings Manufacturing and Related Processes 3
S Benchmarking of Capability, Accuracy and Stability analyses - In Heat treatment Capability, Accuracy and Stability - Processes, Machines, etc. 3
C ID (Inside Diameter) Threads Shrinking due to Heat Treatment and Weld Manufacturing and Related Processes 11
N Lot Capability - Forging -> CNC Machining -> Heat treatment -> Packaging Statistical Analysis Tools, Techniques and SPC 3
A Austempering Heat Treatment Machine - Problem regarding Decarb (less carbon) Manufacturing and Related Processes 16
J Heat treatment inspection and Process capability index Cpk Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
O CQI-9 #1.9 - Heat Treatment - Management shall review the furnace monitoring systems IATF 16949 - Automotive Quality Systems Standard 3
B Design of Experiment (DOE) for Heat Treatment Process Statistical Analysis Tools, Techniques and SPC 4
K CQI-9 - Heat Treatment standard for Automotive Sector IATF 16949 - Automotive Quality Systems Standard 1
A Heat Treatment Validation - Titanium (6Al 4V) for 2 hours @ 700 Deg C Manufacturing and Related Processes 6
D Process Qualification - Heat Treatment Process Furnace - What is Thermal Mapping? Manufacturing and Related Processes 7
M ISO 9002 Section 4.7 - Heat Treatment - Supplies and related services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
V Setup for testing against ISO14708 clause 16 (protection of the patient from herms caused by heat) Other Medical Device Related Standards 0
E 60950-1 resistance to abnormal heat test Various Other Specifications, Standards, and related Requirements 0
S Heat Sealers Upper and lower limit setting during OQ for Heat Sealer Qualification and Validation (including 21 CFR Part 11) 0
K Calculating Heat Dissipation Manufacturing and Related Processes 1
B API Q1 5.7.1.5 Process Validation - Machining, heat treating, Manganese Phosphate and Zinc Plating Manufacturing and Related Processes 2
G Heat Number on CofC - Stainless steel tube Manufacturing and Related Processes 2
K Moist Heat Sterilization worldwide Requirements and Regulations Other Medical Device Regulations World-Wide 1
D Minor non-conformance for not receiving a CofC from a heat treater Manufacturing and Related Processes 10
T Heat treat test dimple Manufacturing and Related Processes 3
X Heat Treat - Verifying mechanical properties on heat treated material per the ASTM Manufacturing and Related Processes 6
Ron Rompen The Effect of Heat on Production and Quality Human Factors and Ergonomics in Engineering 14
S Performing PQ on a Small (tabletop) Air Heat Treating Oven ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
H Standards to use for Propylene Glycol Heat/Cooler Fluid in a Device RoHS, REACH, ELV, IMDS and Restricted Substances 2
C Practical use of Heat Input calculation for Manual MIG Welding Manufacturing and Related Processes 4
S Industrial Aseptic Bag Heat Sealing Sampling and Qualification Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
I AS9100 PPAP requirements for outside Heat Treat vendors/suppiers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
S AMS 2750E Heat Treat Furnace System Accuracy Test SAT Report question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S Heat Map ISO/TS 16949:2009 Clauses IATF 16949 - Automotive Quality Systems Standard 1
M AMS2770 Aluminum Heat Treat - Determining Soak Time Various Other Specifications, Standards, and related Requirements 1
S Thermal Sensitivity Testing - Heat Lamp - ILY - Increased blood circulation IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
F Heat and Moisture Oxygen Port Changes Classification 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
J ISO 17665-1 & 2 Review and approval of validation (of moist heat sterilizers) Other ISO and International Standards and European Regulations 3
Q Heat Treat Steel, Rockwell C - Variability in Complex Machined Shapes Manufacturing and Related Processes 7
