Is Heat Treatment for Metal a Special Process?
Big Jim
#81
They really do need to do more in my mind. At the very least they should be able to explain or defend how they are validating it. A hardness test may or may not be enough depending on circumstances, but they are completely missing 7.5.2 d concerning the need to maintain records for validation.
They need to sit down and read all of 7.5.2 and become prepared to show what validation is needed for their circumstances and they also need to determine what records are needed and start keeping them.
L
Lexylou
#82
Big Jim,
I thank-you for your response because I know that there is more they need to do in order to meet the requirements. I'm trying to guide them is this ISO certification process and I have had no experience in Special Processes.
I am planning a meeting with all of those involved so we can discuss this. This thread including your response will be apart of that discussion. Is there anyone that has an example that I can use as a guide to where I can start? I would probably need the same for welding too.....
W
w_grunfeld
#83
The criticality factor was related to weldments and specifically for the level of inspection required as a function to criticality.
Heat Treatment is a different process, and basically in order to be effective all that is required is that temperature and time be controlled. Even if the part is not critical, the purpose to heat treat is to achive a hardness level as specified on the blue print. You have to record for each batch that the required time and temperatures where maintained. If the part was subjected to 2 hrs in the oven instead of say 4 hrs, or 150 deg instead of 200, the part, critical or not ,is not going to have the intended hardness.
So what you need is to be able to show that each parts batch was exposed to the correct temperature and time. It also follows that you have to periodically calibrate (verify) that the indicated temperature is indeed correct
ABCquality
#84
Hi all,
A special process is any production or service delivery process that generates outputs that cannot be measured, monitored, or verified until it's too late. It's often too late because deficiencies may not be obvious until after the resulting products have been used or services have been delivered. In order to prevent output deficiencies, these special processes must be validated in order to prove that they can generate planned results.
I believe the above definition applies for Heat Treatment. In my company, postweld heat treatment is a special process which requires personnel and procedures to be approved before work.
Regards,
Richardo
David Hartman
#85
Just let me share one more though with you, were there many competitors competing for a chunk of business??? Were there laid down specifications those days? IMO - no!!!!!
Actually there were competitors hence the reason that certain craftsman's works are more valuable than others, and yes there were "laid down specifications" in that the craftsman taught their apprentice precisely how to duplicate his work (OJT). :2cents:
BTW: I worked for a company that required heat treating of some small steel covers not for increased hardness, but for the change in the metals magnetic properties. So verifying the hardness would not have validated the process at all.
P
p_mani888 - 2010
#86
Heat treatment is indeed a special process, whether your sole activity is only heat treatment or not.
If you are supplying / sub-contracting this heat treatment activity to any of the BIG 3's / IATF customers / their TIER vendors, you need to have your process qualified for CQI 9 requirements.
achorste
#88
Validation can only be performed against the specification requirements - if this was hardness, grainsize or magnetic properties - these would be the factors that are validated against.
I would disagree with this definition - A special process is one where the output cannot effectively inspected, tested or verified.
An example - I worked on a blasting process that had to achieve a specific surface finish (between 6 and 20 Ra). Obviously we can measure surface finish, but only at discrete points, measuring the surface finish at every point would be completely excessive, take far too much time and just be ridiculous. Hence it was treated as a special process and was validated.
This has a parallel in heat treatment - hardness can only be measured at discrete points on the surface on the product, grainsize at sections where it is cut up mounted & polished etc etc
How do you know the heat treatment process gives even properties across the component? Different component geometries, variations in the component before heat treatment, variations in temperature uniformity across the furnace or heating process and many other factors can affect these properties - hence without validation of the process at the worst case limits of the variables, or combinations of variables, hardness testing each output from the process is insufficient.
What about cooling rates, atmosphere, pressure etc etc? Are there not plenty of other variables that would need to be considered?
Process records like these do not validate the process. To validate the process you would need to show the process, even at the worst case limits of each variable or combination of variables still produces conforming product. The process records would then be of use in showing that the manufacturing process conforms to this validated process.
R MSA studies for Heat Treatment Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M API 6D-2014 24th Ed. Pto 6.10 - Heat Treatment Equipment Qualifications Oil and Gas Industry Standards and Regulations 4
S Heat Treatment - Soaking time interpretation Manufacturing and Related Processes 5
E CQI 9 (Heat Treatment) Assessment Requirements - Company and Customer Requirements Customer and Company Specific Requirements 1
S Paperless Temperature Recorder for Temperature Surveys on Heat Treatment Ovens General Measurement Device and Calibration Topics 6
G SPC in Heat Treatment Workshop Statistical Analysis Tools, Techniques and SPC 2
A NADCAP AC 7101/03 Heat Treatment Process Acceptance Tests AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
R CQI-9 Heat Treatment Process Table C question IATF 16949 - Automotive Quality Systems Standard 3
K Heat Treatment (Softening) on Cast Iron before it can be drilled to form Thread? Manufacturing and Related Processes 4
W What can be Root Cause Analysis Methodology - Heat Treatment of Carbon-based Products Problem Solving, Root Cause Fault and Failure Analysis 5
W Calculating Minimum Heat Treatment Quench Bath Size Manufacturing and Related Processes 2
S AS9100 REV B Sampling Requirements - Heat Treatment of Large Cylinders AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
T Heat Treatment Process FMEA example wanted FMEA and Control Plans 5
somashekar Information sharing: Week 27, 2010 (HEAT TREATMENT) The Reading Room 3
A Ovality and Flatness generated after Heat Treatment of Rolled Rings Manufacturing and Related Processes 3
S Benchmarking of Capability, Accuracy and Stability analyses - In Heat treatment Capability, Accuracy and Stability - Processes, Machines, etc. 3
C ID (Inside Diameter) Threads Shrinking due to Heat Treatment and Weld Manufacturing and Related Processes 11
N Lot Capability - Forging -> CNC Machining -> Heat treatment -> Packaging Statistical Analysis Tools, Techniques and SPC 3
A Austempering Heat Treatment Machine - Problem regarding Decarb (less carbon) Manufacturing and Related Processes 16
J Heat treatment inspection and Process capability index Cpk Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
O CQI-9 #1.9 - Heat Treatment - Management shall review the furnace monitoring systems IATF 16949 - Automotive Quality Systems Standard 3
B Design of Experiment (DOE) for Heat Treatment Process Statistical Analysis Tools, Techniques and SPC 4
K CQI-9 - Heat Treatment standard for Automotive Sector IATF 16949 - Automotive Quality Systems Standard 1
A Heat Treatment Validation - Titanium (6Al 4V) for 2 hours @ 700 Deg C Manufacturing and Related Processes 6
D Process Qualification - Heat Treatment Process Furnace - What is Thermal Mapping? Manufacturing and Related Processes 7
M ISO 9002 Section 4.7 - Heat Treatment - Supplies and related services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
V Setup for testing against ISO14708 clause 16 (protection of the patient from herms caused by heat) Other Medical Device Related Standards 0
E 60950-1 resistance to abnormal heat test Various Other Specifications, Standards, and related Requirements 0
S Heat Sealers Upper and lower limit setting during OQ for Heat Sealer Qualification and Validation (including 21 CFR Part 11) 0
K Calculating Heat Dissipation Manufacturing and Related Processes 1
B API Q1 5.7.1.5 Process Validation - Machining, heat treating, Manganese Phosphate and Zinc Plating Manufacturing and Related Processes 2
G Heat Number on CofC - Stainless steel tube Manufacturing and Related Processes 2
K Moist Heat Sterilization worldwide Requirements and Regulations Other Medical Device Regulations World-Wide 1
D Minor non-conformance for not receiving a CofC from a heat treater Manufacturing and Related Processes 10
T Heat treat test dimple Manufacturing and Related Processes 3
X Heat Treat - Verifying mechanical properties on heat treated material per the ASTM Manufacturing and Related Processes 6
Ron Rompen The Effect of Heat on Production and Quality Human Factors and Ergonomics in Engineering 14
S Performing PQ on a Small (tabletop) Air Heat Treating Oven ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
H Standards to use for Propylene Glycol Heat/Cooler Fluid in a Device RoHS, REACH, ELV, IMDS and Restricted Substances 2
C Practical use of Heat Input calculation for Manual MIG Welding Manufacturing and Related Processes 4
S Industrial Aseptic Bag Heat Sealing Sampling and Qualification Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
I AS9100 PPAP requirements for outside Heat Treat vendors/suppiers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
S AMS 2750E Heat Treat Furnace System Accuracy Test SAT Report question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S Heat Map ISO/TS 16949:2009 Clauses IATF 16949 - Automotive Quality Systems Standard 1
M AMS2770 Aluminum Heat Treat - Determining Soak Time Various Other Specifications, Standards, and related Requirements 1
S Thermal Sensitivity Testing - Heat Lamp - ILY - Increased blood circulation IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
F Heat and Moisture Oxygen Port Changes Classification 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
J ISO 17665-1 & 2 Review and approval of validation (of moist heat sterilizers) Other ISO and International Standards and European Regulations 3
Q Heat Treat Steel, Rockwell C - Variability in Complex Machined Shapes Manufacturing and Related Processes 7
