Is implementing Electronic Signatures a Significant Change to the QMS?
kchan
We currently have a hybrid QMS system where we write paper records, then scan them into our network. We use the network copies as the official record.
If I were to switch to using entirely electronic records and signatures (never a paper copy), would that be considered a significant change to the QMS?
All I can find is the NBOG 2014-3 article that says switching from paper to electronic is considered significant, BUT, we already had electronic records.
Thanks in advance for your input!
Tidge
I say "Yes" but the change may not be as extreme as some folks may advise. The most significant aspects IMO are:
  • The QMS must unequivocally state the meaning and understanding of an electronic signature
  • There must be proof of correct implementation of electronic signatures where they are employed
In the USA, 21 CFR part 11 spells out necessary implementation details for electronic records/signatures. These are straightforward and well-intentioned rules that can be adapted for other jurisdictions.
Also, the FDA requires formal notification that a company is using electronic signatures (if you never deal with the FDA, I suppose this doesn't matter to you)
Yes, it is significant change.
For reason.,
The records control process now interacts with your 4.1.6 (software used in the quality management system) You will need to document a procedure for its validation and validate this software.
You will have to ensure by the validation that the responsibilities and authorities about records approvals are mapped as you have documented under the clause 5.5.1, and that they are effective.
You wll have to pay attention about the controls you put in place about records security and integrity and being retreievable and the authorities mapped to persons who can retreive the records. This is in consideration with the records control process interaction with the Internal audit process. This also helps you to demonstrate the records well during any external audits by the auditee responsible adequately.
With the remote audits becomming the new way forward, I have seen many examples of poor records retreievability by the designated auditee leading to poor audit performances and time delays. Situations across processes can lead to a finding. It will do good when you can check this well in your internal audits as well as determine how the MR can get involved in the records retreivable authority given to him based on his responsibility. This is a good point to consider in your software validation.....
kchan
Thank you both for your input!
We sell in the USA and in Europe (under MDD). We are under MDSAP. We already utilize a validated eQMS system, which has digital signatures for process-based workflows, so we are familiar with Part 11.
In order to move to AdobeSign/certified electronic signatures on records, I believe the process is to:
a. Validate AdobeSign and the process used for Part 11 compliant electronic signatures.
b. Contact our MDSAP AO to inform them of the change and get permission / undergo a delta audit for the use of electronic signatures
c. Start using electronic signatures.
Would I also need to contact our NB about it in Europe? Or let the FDA know?
med_cert
Hi @kchan can I ask which eQMS system you use?
Tidge
I would like to keep reading how your discussions with AdobeSign go. Based on the specific functionality of AdobeSign, it may be necessary to also establish them as a (software) service provider. (specific) Supplier controls could reduce the burden of validation on your end.
Ed Panek
QA RA Small Med Dev Company
Run validation by using both manual and E sign off for a period of 1-3 months. Then validate the outputs match.
I would also complete this checklist
kchan
Hi all,
Thanks for your answers. We certainly intend to validate any software we use for Electronic Signatures. However, my question is more aimed towards understanding whether we need to notify our registrar and NB and if it is considered a 'significant change' to the QMS in that regard.
K EQMS question - Implementing an electronic QMS to support ISO 13485:2016 Quality Assurance and Compliance Software Tools and Solutions 4
G Implementing a Part 11 approved fully electronic QMS system Quality Assurance and Compliance Software Tools and Solutions 29
H Implementing ISO14001:2015 ISO 14001:2015 Specific Discussions 4
A Small Company Implementing ISO 13485 Timeline/Process/Steps Advice ISO 13485:2016 - Medical Device Quality Management Systems 5
E Theoretical project: Implementing ISO 13485:2016 into a start up acrylic bone cement manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 4
G ISO 9001 - when implementing customer requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Moncia Implementing ISO 50001 Sustainability, Green Initiatives and Ecology 21
H Implementing ISO22301 on a Limited Scope Business Continuity & Resiliency Planning (BCRP) 2
J Implementing an ISO 13485 QMS Software ISO 13485:2016 - Medical Device Quality Management Systems 11
Sravan Manchikanti How to interpret '8.3 Control of nonconforming product' for SaMD device while implementing ISO 13485 & MDSAP ISO 13485:2016 - Medical Device Quality Management Systems 7
L Implementing the PRRC role in a company EU Medical Device Regulations 8
A Implementing ISO 20000-1 - Where to start Other ISO and International Standards and European Regulations 4
B Lessons Learned Implementing ISO 50001 (Chemical Engineering Progress) Other ISO and International Standards and European Regulations 0
C How medical device manufacturers are implementing standards like GDPR and HIPAA Other ISO and International Standards and European Regulations 5
M Informational EU – Commission Implementing Decision (EU) as regards the designation of expert panels in the field of medical devices Medical Device and FDA Regulations and Standards News 0
R Implementing Design History Documents/ Technical Documents in the QMS ISO 13485:2016 - Medical Device Quality Management Systems 3
tnorton Lessons learned from implementing Customer Complaints Customer Complaints 1
M Informational Update – MDR and IVDR implementing measures rolling plan – 2 more NBs designated under the new regulations Medical Device and FDA Regulations and Standards News 0
S Implementing a 45001 Health & Safety standard - Internal audit plan wanted Internal Auditing 1
M Informational Commission Implementing Decision (EU) 2019/939 of 6 June 2019 designating issuing entities designated to operate a system for the assignment of Unique Medical Device and FDA Regulations and Standards News 0
J Implementing Machine Replacement Part Reverse engineering technology Manufacturing and Related Processes 4
Q Does anyone have experience implementing a QMS without ISO certification? Quality Manager and Management Related Issues 2
M Informational EU – April 2019 update of the MDR and IVDR implementing measures rolling plan Medical Device and FDA Regulations and Standards News 0
I First Time Implementing Document Control for ISO-9001 - how far back do you go? Document Control Systems, Procedures, Forms and Templates 15
M Medical Device News Last update of the MDR and IVDR implementing measures rolling plan – December 2018 Medical Device and FDA Regulations and Standards News 0
J Implementing EN 62304:2006 on existing and proven medical devices IEC 62304 - Medical Device Software Life Cycle Processes 6
M Medical Device News MDR and IVDR implementing measures rolling plan EU Medical Device Regulations 0
B Implementing an Escalation Process and Andon system Supplier Quality Assurance and other Supplier Issues 1
T Is there any requirement to be compliant with IEC 62304 while implementing ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 5
armani Compliance Obligations - Implementing 6.1.1 and 6.1.3 NOTE - Determine risks and... ISO 14001:2015 Specific Discussions 1
G Heavy Civil Construction Company Implementing ISO 9001:2015 for Certification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
K Implementing ISO13485:2016 in the Middle of a New Device Project ISO 13485:2016 - Medical Device Quality Management Systems 1
D Implementing 5S for Multiple Shop Floor Layout Workstations Lean in Manufacturing and Service Industries 2
N FDA Guidelines for implementing Continuous Improvement Process US Food and Drug Administration (FDA) 5
Q Easy Way of "Implementing" Risk in ISO 9001 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
N Implementing ISO 17025 in a Calibration Laboratory ISO 17025 related Discussions 8
E Does anyone have experience implementing a Tiered QMS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
A Implementing an AS9100 Aerospace Quality System AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
L Implementing ISO 9001 in small Trading Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
C Implementing a set of bore gages at a machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
A Implementing Risk Management in a Medical Device "Distributor Only" company ISO 13485:2016 - Medical Device Quality Management Systems 6
T Implementing a Suspect Counterfeit Identification Program Quality Manager and Management Related Issues 3
O Implementing Lean Intranet Sharepoint Lean in Manufacturing and Service Industries 6
F Implementing ISO 9001:2008 in a new Food Processing company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
J ISO 22301 - Implementing a Business Continuity Management System Business Continuity & Resiliency Planning (BCRP) 15
M Does anyone here have experience implementing PCI DSS (Data Security Standard) IEC 27001 - Information Security Management Systems (ISMS) 10
L Implementing a new quality management system for a new engineering company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Implementing ISO 9001 in an Assembly Plant ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
D Understanding and implementing ISO 17025 ISO 17025 related Discussions 9
Q Implementing ISO 9001 and ISO 22000 systems at the same time Document Control Systems, Procedures, Forms and Templates 2
