Is insulation between F type applied part and other parts a must?
Roland chung
Dear all,
There is a battery operated equipment. It is body-worn equipment and has a BF type applied part (esophageal catheter), plastic enclosure and a micro USB port which is intended for data transfer. The equipment does not employ isolation barrier between patient connection and internal circuits (including USB port).
But according to the clause 8.5.2.1, F type applied part shall be separated from all other parts by 1 MOPP for working voltage equal to maximum mains voltage and according to the clause 8.3 b), applied part that is intended to deliver electrophysiological signal from the patient shall be a type BF or type CF applied part.
The equipment now fails the standard clearly. Is there a way to fulfil the standard without redesign? I do not think such body-worn equipment could get an unintended mains voltage.
Any advices will be appreciated!
Roland
Peter Selvey
If the dataport is not intended for use when the patient is wearing the device, it should be OK.
In that case, when used on the patient the whole device is considered the applied part, so no F-Type isolation is necessary.
Roland chung
Thank you for your input.
A warning 'DO NOT CONNECT THE PATIENT DURING DATA TRANSFER' is specified in the user manual.
Is it necessary to prevent from the misuse by design? For example, the equipment stop acquiring data when USB port is connected to the computer.
bassa
Not always, but i believe its the best way to go. (when you read the 60601, almost every option to prevent from a risk is by design, but if that is not possible, other alternatives are reached out)
(note that you can prevent from misuse, or remove the hazards that might arise when a product is misused)
Your risk assessment should point out if the risk is bearable, when it's not, the risk must be taken away somehow.
In your case, stopping data acquisition probably won't do, the connection is already made, stopping a digital process (i guess that is what you mean) won't change that.
Maybe a physical way to prevent connection to USB and applied part might be a better option?
or build in the neccesary mop.
Peter Selvey
As mentioned, for foreseeable misuse it's OK to use risk management.
It is worth to note that the standard has a lot of worst case assumptions in the F-type requirements, for example the patient being exposed to hypothetical low impedance source of mains voltage (not just leakage current, but solid contact with a bare mains part).
When considering foreseeable misuse, it's OK to pull apart these worst case assumptions and make an overall decision based on the true probability of harm, not the probability of misuse.
W Insulation requirements between F-type applied part and enclosure IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A Insulation between Secondary Accessible Parts and Earth IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
J Aluminum anodization as MOP insulation? Clause 8.5.1.1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
E Insulation diagram for ECG monitoring and diagnosis system. IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
K Doubt on insulation class of a device IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
W Insulation requirements of BF type infant skin temperature probe IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
M 2xMOPP insulation for Applied Part B. IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
Q Isolation/Insulation Diagrams - IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
V PCB internal insulation treated as insulation formed by insulating compound IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
W HF surgery device accessory insulation requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
E Creepage distance accross insulation of step up transformer EU Medical Device Regulations 2
S Who compiles the Critical Component List, Insulation Diagram etc.? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
P Question on Table 6 "Test voltages for solid insulation forming a MEANS OF PROTECTION IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
P MOOP and insulation coordination IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
K IEC60601 3rd Edition Insulation Thickness for electrosurgical devices IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
N Cable Connectors - Insulation does not go all the way into the back of the connector Manufacturing and Related Processes 4
P IEC 60601-1-11 - Conversion to Double Insulation IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
N Insulation Diagram for Water Tub IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
W Is anybody familiar with IEC61010-1 Insulation Requirements? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
V External power supply with reinforced insulation as a simple secondary circuit? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
P Understanding IEC 60601-1:2005, Clause 8.1 b) - Short Circuiting Double Insulation IEC 60601 - Medical Electrical Equipment Safety Standards Series 13
R Determining Working Voltage - Drawing a Medical Device Insulation Diagram IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
W Insulation Grade for In Vitro Diagnostic (IVD) Device? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
S Do insulation layers in double insulation have sequence requirement? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
S Can enclosure of semiconductor or electrolytic capacitor provides basic insulation? IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
N Insulation Barrier Testing - According IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 22
T Insulation diagram for a medical electrical equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
H Insulation of FRP (fiberglass reinforced plastic) Tanks Manufacturing and Related Processes 3
B Control Chart - Minimum point & average insulation thickness for Automotive Wires Statistical Analysis Tools, Techniques and SPC 9
A Medical device with NON medical PC - USB galvanic insulation ISO 13485:2016 - Medical Device Quality Management Systems 2
U How to pick between ANSI Z1.4 vs. ISO2859-1 for AQL Inspection? What are the major differences? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
N R&R for Differences between 2 measurements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
S Distinction between a critical supplier and a Virtual manufacturer EU Medical Device Regulations 2
I Сorrespondence between hazards and risks ISO 14971 - Medical Device Risk Management 2
W What is the difference between TYPE B and TYPE BF? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Q Terminal Lugs sizes - Difference between 225/24 vs. 275/24 lugs Manufacturing and Related Processes 2
T Relationship between ISO 9001 and ISO – IEC BS EN 870079- 34 2020 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M Difference between "Production Trial Run" and "Run at Rate" IATF 16949 - Automotive Quality Systems Standard 8
Ron Rompen Surface Finish Correlation between Ra, Rz and Tp (bearing surface ratio) General Measurement Device and Calibration Topics 3
L MRA between EU and Switzerland - 1/2021 EU Medical Device Regulations 2
K Joint approval between OEM and Manufacturer on Design Documents ISO 13485:2016 - Medical Device Quality Management Systems 4
C Is my software an accessory? Telecommunication between HCP and patients EU Medical Device Regulations 10
K Verify Software Architecture - supporting interfaces between items IEC 62304 - Medical Device Software Life Cycle Processes 2
E ASTM F2118 - Fatigue testing of bone cement - Changes between the 2003 and the 2014? Other Medical Device Related Standards 1
