Is ISO 9001 Cresting? Is a rebellion in the works?
Has ISO 9001 reached a level where a rebellion is in the works?
  • ISO 9001 is still on the rise.
    Votes: 11 25.0%
  • ISO 9001 is near its peak.
    Votes: 15 34.1%
  • The rebellion has started or is starting.
    Votes: 14 31.8%
  • We have already rebelled. We will not register.
    Votes: 4 9.1%
  • Total voters
    44
Paul Simpson
Quality vs. System
Marc said: "Equating 'quality' with ISO 9001 or QS-9000 or TS 16949 registration is a common mistake."
I agree that there isn't the link between the system the company is registered to and the quality of the product. The thing is there should be a very good link. There is still scope within the best systems to make mistakes, the systems are inhabited by humans after all but with a qms in place we should all be learning by our mistakes and putting improved systems in place to prevent recurrence. If not we should all be packing up and going home.
64 thousand currency of your choice question: Why is the link between the systems we work to and product quality so weak? Is it the companies, quality managers, certification bodies / registrars or the accreditation bodies?
CarolX
I'll throw some thought at this
I put a little in here...one of the BIG reasons, IMHO, is the requirement to meet the standard EVEN if it makes no sense to your company.
And here is one example. This goes back to the 1994 standard on periodic inspection of stock. Now, we are a just in time sheet metal fabricator. We carry almost no stock that isn't turned around in a week. But because this was in the standard, we had to come up with a procedure and forms. This has not been a value added process to our operation, and takes time away from my schedule.
CarolX
P
peterd
Is02000
I'm new to this forum but the discussion in the link seems to show all sides of the argument regarding whether having an accreditation actually means you'll provide a 'quality' product to the customer.
The argument as far as I can see is this. All the accreditation tells you is that the company has systems/processes in place as detailed in the standard and that these have been checked by an outside source who states they believe that the company is acceptable.
The accreditation itself does not demonstrate anything to do with product conformity, only that processes are in place to address non-conformance, internal audit etc. Taking the ISO1994 this is all that was demonstrated. You had a procedure and you could demonstrate that you worked to it.
The ISO2000 standard took that one stage further and added the elements of measuring you processes, setting objectives, making sure your staff are competent and demanding more involvement and commitment from the management of the company.
I don't know about you but these are many of the reasons that us quality people struggle in our daily working lives.
If implemented properly and used as the basis for a management system within the business ISO2000 will give a good way of running the business that will also benefit your bottom line. Again this may not demonstrate product conformity but means you are demonstrating your focus on it.
The ISO2000 series may not be for everyone but then again most companies are not capable of generating their own corporate systems such as Toyata et al.
The AS9100 type standards then take that a stage further by incorporating specific industry requirements, and surely that can't be bad thing.
It's good to find a place where these things are talked about.
:bigwave:
RoxaneB
Because, even in this technical society, we are in business only to make money. Only now is "quality" entering the picture of manufacturing courses (at least in the ones I took not so long ago). And the quality course is still separate from both my manufacturing AND business courses. Only when quality is integrated into the courses, will the "next generation" of business leaders understand that quality can help make money.
As Carol pointed out, a lot of unnecessary documentation was created with the 1994 standard, as well. The phrase "We're only doing this because of ISO" was commonly heard and many of us questioned the value of our systems.
My company, as part of the transition to the 2000 standard, began the justification of all the documentation. Streamlined the documented processes. Revamped our training programme. Introduced new tools that could work within our management system. Began focusing not only on the Customer, but our Employees, the Community, the Suppliers, the Shareholders. In essence we moved well beyond ISO 9001 and have taken ISO 9004 to heart.
Randy Stewart
I'd add . . . .
I agree with the non-value added comment and add that; once the standard has one subclause seen as non-value added the whole relativity is thrown out.
We have focused on making any system to be compliant with the standard as long as we address the "shalls". Even then it is must be "bought off" by the external auditor.
Just look at the rush to get job descriptions in place. Company's had operated for years without them. Some had skill set compiled for positions but not a 'job description'. So what did they do? Put away the skill sets that had been developed based on experience and went to a job description because of what the auditor wanted to see. You just threw a wet blanket on getting most changes put through.
Everyone was looking for the piece of paper to produce for "objective evidence" and not for the approval of the customer.
CarolX
Last week I met with the President to discuss our plans for 2K upgrade (getting some resistance to some of the changes). And I flat out asked him "Have you seen any improvement because of ISO?". He said he was disappointed at the results, but wants to continue because it may help in getting new business. (FYI - this was the only reason we went for it in the first place). He could not provide one single new customer that mandated ISO certification/registration, nor was he sure if any of our newer customers really needed it. He was also disappointed at the surveliance schemes - only one NC that was addressed before the auditor left. Not that we were hiding a bunch of stuff, or that we don't do what we say...but...again....no value added.
We are going for the 9K2K...but he wants it put off until January 2004. Maybe the end is here!!!!
CarolX
RoxaneB
CarolX
Just a thought, sometimes the big fellas at the top of the corporate food chain need to see the actual numbers for them to know/acknowledge the benefits attained.
I had to sell our Sales Departments (one located in Tampa, Florida and the other on the other side of Toronto, Ontario from my location) on the benefits of ISO 9001 and understand why they fell under our scope and provide objective evidence that ISO 9001 really does work (if implemented properly).
I showed numbers - pre-ISO era vs ISO era. Drastic improvement in such areas like production, energy consumption, quality products, quality complaints, internal nonconformances, truck turnaround time, employee turnaround, etc.
Sales, who was traditionally impacted on the smallest of small scales by our ISO programme, had seen service and invoicing/pricing complaints skyrocket. Customers would say horrible things about our service and our sales reps on the surveys. Employee turnover was at an all-time high.
Sales bought it and while they still grumble at some of the paperwork, they are already beginning to see some improvement. Not only is the process consistent so everyone is doing it the right way. They are now learning to make their processes more effective so that their jobs are becoming less stressful. Their morale is improving. They smile more...which means our Customers smile more.
Paul Simpson
We need to change!
CarolX said: “ We carry almost no stock that isn't turned around in a week. But because this was in the standard, we had to come up with a procedure and forms.”
Where does it say in the standard that you have to carry out periodic checks on stock? I know that you need to have processes in place to ensure that stock hasn’t deteriorated but there is no need to have a procedure if you have records that show the stock is all used up before it has a chance to go off … and steel? I think your auditor has pushed the envelope a bit far.
peterd said: “The accreditation itself does not demonstrate anything to do with product conformity, only that processes are in place to address non-conformance, internal audit etc. Taking the ISO1994 this is all that was demonstrated. You had a procedure and you could demonstrate that you worked to it.” And “The ISO2000 standard took that one stage further and added the elements of measuring you processes, setting objectives, making sure your staff are competent and demanding more involvement and commitment from the management of the company.”
This is my point. If the system doesn’t mean anything in terms of product then surely all the measures in Peter’s post would be going the wrong way and the system would be non ISO 9001.2000 compliant because of failures to corrective and preventive action. So the system should pick up on the product “blips” and fix them if it is to mean anything.
RC Beyette said: “Because, even in this technical society, we are in business only to make money. Only now is "quality" entering the picture of manufacturing courses (at least in the ones I took not so long ago). And the quality course is still separate from both my manufacturing AND business courses. Only when quality is integrated into the courses, will the "next generation" of business leaders understand that quality can help make money.”
Again as I understand ISO the money should follow the system. If you have been having product problems and correct them using systems then the bottom line should improve, or is it me and I am naïve. I agree totally with the education line. The only problem is who is doing the teaching a nd what slant do they put on it, I remember when I was finishing my degree we had lectures on Production and the lecturer was implying that we professional engineers had to beware the systems guys who would document us into submission.
RC Beyette said: ”My company, as part of the transition to the 2000 standard, began the justification of all the documentation. Streamlined the documented processes. Revamped our training programme. Introduced new tools that could work within our management system. Began focusing not only on the Customer, but our Employees, the Community, the Suppliers, the Shareholders. In essence we moved well beyond ISO 9001 and have taken ISO 9004 to heart.”
Again, great news. To my mind this sounds like a proper ISO 9001.2000 system, not written with the standard in mind (and the long list of shalls) but around what the company does and how it wants to describe it.
Randy Stewart said: “ I agree with the non-value added comment and add that; once the standard has one subclause seen as non-value added the whole relativity is thrown out.
Everyone was looking for the piece of paper to produce for "objective evidence" and not for the approval of the customer.”
And this is the problem with the whole process. Systems written for auditors are not the same as systems that work for companies … there I’ve said it! We need to change the whole ethos of registration so that the auditors work for us and not the other way round. The problems are to get them to buy into this and for the senior managers to recognize that to be able to do this we have to spend time on implementing the right systems and not get a quick win of a cert on the wall by addressing the shalls. There are no subcaluses that are non value added, only ones that do not apply.
Randy Stewart
Yes, exactly. It has taken a while for systems and their owners to mature into a useable commodity. For most of us we were given a short deadline to implement a (un)known standard. Today, not only has the standard changed but the coordinators/owners also.
gpainter
CarolX
We do this when we take our physical inventory and have added a comment area to the inventory tag. If someone notes a possible nonconforming material its location is noted on the PIT ( Physical Inventory Ticket).
Q Audit report template ISO 9001/14001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
Q Process matrix examples of ISO 9001 & 14001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
chris1price Archiving of paper records - ISO 9001 7.5.3.1b Records and Data - Quality, Legal and Other Evidence 4
D Common practices in ISO 9001 deployment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
P Audit check for IT company (ISO 9001) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
W First time being audited (ISO 9001), asking for advice ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Q ISO 9001 - Reseller Exclusions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
N ISO 9001 - Training business with fewer than 5 employees ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J Opportunity in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
D Reports under change management | ISO 13485:2016 & ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 3
K Integrating ISO 9001:2015 with ISO 17025:2017 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
R Remote Audits for ISO 9001 (or any other standard) General Auditing Discussions 31
T Relationship between ISO 9001 and ISO – IEC BS EN 870079- 34 2020 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Sequence of ISO 9001:2015 Implementation Steps ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
qualprod Business Continuity Planning in ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Brizilla Employee Data Privacy Policy - ISO 9001:2015 requirement(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
P ISO 9001 certification with zero customers? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
A What must be recorded? (ISO 9001:2015, subclause 10.2) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
B Updated IATF 16949 - Will IATF 16949 get revised when ISO 9001:202X is released? IATF 16949 - Automotive Quality Systems Standard 4
S ISO 9001:2015 vs 21 CFR Part 211 matrix Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
S ISO 9001 implementation in a Gold exporting business ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Tips and Tricks to understand ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
B ISO 9001 - "Remote Audit Fee" Registrars and Notified Bodies 13
John C. Abnet ISO 9001 4.4.1 "...shall determine the processes needed..." ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 72
S ISO 9001 Clause 8.2.3 - Review of the requirements for products and services in a Cafe ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
D ISO 9001 certificate issued by QMS International for 10 years - legit? Registrars and Notified Bodies 17
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
M ISO 9001:2015 and AS6081:2012 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Implementation ISO 9001: 2015 ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Audit Checklist for Integrated Management System for ISO 9001:2015, ISO 14001 & OHSAS18001 (IMS) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
G National Structural Steel Specification 7th Edition - Do I now have to be audited against ISO 3843-3 as well as ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
J Sister-company providing parts is only ISO 9001 registered IATF 16949 - Automotive Quality Systems Standard 7
G Copy of withdrawn ISO 9001:1994 Quality Management Standard ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A Does ISO 9001:2015 cover all the requirements of ISO 10012:2003? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
G Logistic organization and controls - IATF/ISO 9001 audit Nonconformance and Corrective Action 2
J Scope of ISO 9001 clause 10.2 in the product life cycle ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T ISO 9001 8.5.2. - Identification and traceability to Identify Outputs - Services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T ISO 9001:2015 - Small Shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M ISO 9001:2015 case study sample ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Sample of Nonconformity report for ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
