Is it a rule to fill in all the 5 why in order to get the actual root cause?
P
Priss80
In problem solving methodology, 5-why analysis there are 5 step to drill into root cause. May i know is it a rule to fill in all the 5 why in order to get the actual root cause? I discovered that some of the root cause can get at 3th why.
John Broomfield
Priss80,
No, the number of times your cross-functional problem solving team asks why may be more or less than 5.
The number of whys depends on how big a step is made to link an effect to possible causes.
John
somashekar
It is generally believed that by the 5th 'Why' you will hit the rootcause. It could also be the 6th in some case. Nothing hard and fast on the number of why's....
If you have discovered the rootcause by the 3rd why, so be it. However are you sure there are really no further exploration opportunities in your system.... no further why question really ??
Mike S.
Happy to be Alive
As you have seen, there is no magic in the number 5.
After all, "roots" themselves vary in size, location, and depth. If you take RCA to the extreme you go back to God or the big bang or whatever, but that is not helpful.
If you find a "root" cause that you can control and you believe will eliminate the problem, and keep a sharp eye out for contributing causes that might need a fix as well, give it a go and see what happens. PDCA.
Steve Prevette
Deming Disciple
I would suggest that 5 is a rule of thumb established from experience. Generally, folks who stop before getting to 5 are less likely to have pulled the string far enough to find the "real" cause(s), and will only end up trying to fix symptoms.
Mike S.
Happy to be Alive
There is also too often a difference in theoretical best case RCCA scenarios and what you are able to actually accomplish in the real-world.
Practicality means you will often be forced to stop and execute a CA one or two whys short of what you may be sure is the ?true? (or closer to ?true?) root cause because you know going to the next step or two will result in having to turn around and go back to something further from ideal but which you and/or your team have some control over. Finding a ?true? root cause over which you will not be able to exercise any control is only of academic value, not practical value.
Politics is one of the frequent reasons for this, IMO. For example, if experience tells you that the company President will not let you fix the problem at the 5th why, you might as well stop at the 4th if you have control over that and work with what you have, not what you wish you had. JMHO.
Watchcat REGULATORY WATCHCAT - De Novo Proposed Rule - Samples & Labeling Other US Medical Device Regulations 0
Watchcat DE NOVO FINAL RULE IS PUBLISHED Other US Medical Device Regulations 0
Watchcat REGULATORY WATCHCAT - De Novo Proposed Rule - Clinical Investigations Other US Medical Device Regulations 0
Watchcat REGULATORY WATCHCAT - De Novo Proposed Rule - Nonclinical Studies Other US Medical Device Regulations 0
Watchcat REGULATORY WATCHCAT - De Novo Proposed Rule - Benefits and Risks Other US Medical Device Regulations 0
Watchcat REGULATORY WATCHCAT - De Novo Proposed Rule - Special Controls and Standards Other US Medical Device Regulations 0
Watchcat REGULATORY WATCHCAT - De Novo Proposed Rule - Alternative Practices and Procedures Other US Medical Device Regulations 0
Watchcat REGULATORY WATCHCAT - De Novo Proposed Rule - Device Description Other US Medical Device Regulations 0
Watchcat REGULATORY WATCHCAT - De Novo Proposed Rule - Indications for Use Other US Medical Device Regulations 0
Watchcat REGULATORY WATCHCAT - De Novo Proposed Rule - General Comments Other US Medical Device Regulations 2
Watchcat De novo Final Rule Pending - Inspections 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
C MDR Classification Rule 10 EU Medical Device Regulations 16
R Nanomaterials used as coating on class I MD - rule 19 EU Medical Device Regulations 4
P MDR Rule 10 interpretation - Active Device EU Medical Device Regulations 6
N Medical Device Classification under MDR - Rule 21 EU Medical Device Regulations 12
K EU MDR Rule 11 - Does the 'Risk logic' used in Rule 11 conflict with that used in the other rules? EU Medical Device Regulations 2
M Informational From Medtech Insight – QSR/ISO 13485 Harmonization Update: FDA Enforcement Discretion Likely When New Rule Stands Up; Draft Reg Coming By Year’s End; Medical Device and FDA Regulations and Standards News 0
M Informational EU MDR Classification Rule 11 – what??? Medical Device and FDA Regulations and Standards News 9
A Please explain MDR Rule 11 to me EU Medical Device Regulations 67
Ed Panek Rule 11 Question - CE approvals for software as well as the medical device EU Medical Device Regulations 7
J MDR Annex VIII, Rule 6 Classification - Implication for lower risk CV products? CE Marking (Conformité Européene) / CB Scheme 4
Watchcat Informational Proposed Rule - De novos - 2019 Other US Medical Device Regulations 1
Q IATF rule for single site - Ingots from scrap metal recycling company IATF 16949 - Automotive Quality Systems Standard 0
R MDR Software Rule 11 Formal Interpretation EU Medical Device Regulations 7
M Informational US FDA – Requests for Supervisory Review of Certain Decisions Made by the Center for Devices and Radiological Health – Final Rule Medical Device and FDA Regulations and Standards News 0
M Informational USFDA Final Rule – Human Subject Protection; Acceptance of Data From Clinical Investigations for Medical Devices Medical Device and FDA Regulations and Standards News 0
G EU MDR 2017/745 Rule 11 interpretation - Re-classification of a Software as Medical Device Other Medical Device Related Standards 0
S AQL Inspector's Rule - bring into CQE Exam? Professional Certifications and Degrees 5
M FDA News USFDA Final Rule – Medical Device Classification Procedures: Incorporating Food and Drug Administration Safety and Innovation Act Procedures Medical Device and FDA Regulations and Standards News 0
M FDA News The FDA Issues Final Rule on Medical Device Classification Procedures Medical Device and FDA Regulations and Standards News 0
P The suspension rule and de-registration rule for a certified organization Registrars and Notified Bodies 0
bio_subbu India’s CDSCO Issues FAQ's on Medical Device Rule, 2017 Other Medical Device Regulations World-Wide 0
C Substance based Medical Device Classification under MDR - Rule 21 EU Medical Device Regulations 10
B Reclassification of Spinal Implants via Rule 8 (EU 2017/745) EU Medical Device Regulations 0
S Indian Medical Device Rule - January 29th, 2017 Other Medical Device Regulations World-Wide 51
R Technical Files Sampling Rule defined in NBOG 2009-4 EU Medical Device Regulations 2
Q Rule 5.2h - Site Separation - Audit Manday Calculation (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 17
M Final rule on use of symbols on labeling - Symbols without text under some conditions Other US Medical Device Regulations 12
M Again ... about this IATF site extension rule... IATF 16949 - Automotive Quality Systems Standard 3
C Meaning of "direct diagnosis" (Annex IX, Rule 10) EU Medical Device Regulations 6
bobdoering Who says you can't calibrate a steel rule! Funny Stuff - Jokes and Humour 17
sagai Unified Device Identification Final Rule is out - September 2013 Other US Medical Device Regulations 13
S New FDA cGMP rule for Combinational Products Other US Medical Device Regulations 0
X FDA UDI (Unique Identification) amendment on 19 Nov 2012 - Date of 'final rule'? US Food and Drug Administration (FDA) 4
Ronen E New Establishment Registration and Device Listing Rule - August 2012 Other US Medical Device Regulations 32
K Are you wondering about FDA's UDI rule? Here's a non-exhaustive summary: Other US Medical Device Regulations 12
S US FDA Unique Device Identification (UDI) Proposed Rule 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 18
R Where does 20% Lot Qualification Rule Come from? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
Q Rule for ISO/TS16949 Triennial Audit of Multiple Sites (Remote Locations) IATF 16949 - Automotive Quality Systems Standard 2
Q Non Conformity in Audit: Missing Deputy Rule ISO 13485:2016 - Medical Device Quality Management Systems 10
