Is it mandatory for Medical Devices to work properly after dielectric strength tests?
We are developing a ME device with BF type AP.
The device is powered from 240 VAC.
The device passes all the tests about 60601.
But after dielectric strength test some electronic parts get damaged. So the device does not work.
There is no problem about leakage or isolation.
The test laboratory tests dielectric strength by connecting one lead to both L, N of the AC plug and other lead to Appled part of the device.
Is it mandotary for Medical Devices to work properly after dielectric strangth tests?
Thanks.
Tidge
It has been some time since I was directly involved with 60601-1 (3rd edition), but from memory: generally the ME Device is required to maintain essential performance (in addition to providing basic safety) when subjected to a single-fault condition. I seem to recall that after some of the more destructive tests that if the device provides an indication of loss of function (with no impact to basic safety) and the risk profile of the device tolerates this circumstance, that this might be acceptable. I would also appreciate a response from someone with more direct, recent experience with a NRTL.
I would suggest that the test house is doing the test wrong.
If you apply a dielectric test voltage all the way from 'front to back' the stress will be created across more than one insulation, with the division of the overall voltage being set by things like the capacitance involved. You will not be able to tell which part is getting the most stress.
For this, it is essential that you develop an 'Insulation Diagram' (See Annex J - and google for background info). This will set out the various insulations that are required to be tested. Remember that dielectric tests are only applied for solid insulation - you analyse others using creepage and clearance rules.
Send the repair bill to the test house!
Peter Selvey
Pads38 is correct, dielectric strength is intended to test solid insulation only, which is typically implemented in wiring, opto-couplers, safety capacitors (Y1, Y2 types) and transformers. In principle this should be done on the parts themselves. If it is unavoidable to do it on the parts, 8.8.3 (c) has instructions such as shorting out circuits to avoid damage. It's also worth to note that if the parts are certified, you don't actually need to do test.
In practice, the test for 1 MOP (one means of protection, typically 1.5kV) can safely be done in an assembled device, but the test for 2 MOP (typically 4kV) is rarely possible to do on a fully assembled device. This is not only because it will stress parts not intended to be stressed, but because the parts that are intended to provide the insulation are not likely to be stressed. So you end up with broken equipment and an invalid test.
I recommend to claim damages to the test lab, it's a big mistake to do the test this way. This is not to be nasty but just to make sure they don't it again to other customers.
Thanks all for your answers.
We have already draw an insulation diagram. Because of its detailed with our markings and brands I can not post it in here.
I will try to explain:
- AC power input socket is CE certified and on the socket it is written " HIPOT tested"
- Cables from socket to Power supply have drawing that explains isolation to earth 1MOOP (enclosure class 1 to the cables) and isolation to BF applied part has 2MOPP.
-The power supply that we use also have 2 MOPP input to output, 1 MOOP input to earth.
- Our BF applied part has 4kv insulation tested between its cables and its lead.
We can test all insulations separately. Once the whole assembled device tested end to end, some parts have stresses that can cause expensive damages.
Our conflict with our LAB is about "how we can test our device after humidity preconditioning?"
Because of its enclosure is resistant to humidity, the insulations are not affected.
Should we disassembly the device after humidity preconditioning and test insulations separately?
And at which environment should we test? (inside humidity room or normal environment)
I load the humidity chamber with a complete device plus samples of things like the transformers. That way I can do the necessary dielectric tests without any disassembly - some on the device, some on the components.
If the chamber is big enough then the tests can be done inside (a 'walk in' chamber). The one I use is smaller so the tests have to be done outside. For best validity keep the test objects inside until the very last second.
A Mandatory Languages Requirements for Medical Devices CE Marking (Conformité Européene) / CB Scheme 2
N Is IEC 62353 Mandatory for Medical Devices? IEC 60601 - Medical Electrical Equipment Safety Standards Series 11
U ISO 13485 mandatory for a factory making Medical Devices for EU? EU Medical Device Regulations 6
R US FDA Mandatory Labelling contents for an OTC medical device US Food and Drug Administration (FDA) 0
R Is there a mandatory medical device warehouse standard for europe? EU Medical Device Regulations 3
J Emergency Switch - Mandatory for Medical Device? IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
J Canadian Medical Device Reg -- Mandatory Reporting? Various Other Specifications, Standards, and related Requirements 1
D 6 mandatory documents for ISO13485 ISO 13485:2016 - Medical Device Quality Management Systems 7
T Is TR 60601-4-2 mandatory? IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
Sidney Vianna Interesting Discussion IAF Mandatory Document for the Harmonization of Sanctions and Dealing with Fraudulent Behaviour ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 3
Ajit Basrur Electronic Records - leave non-mandatory fields blank? Qualification and Validation (including 21 CFR Part 11) 10
M Is there a mandatory requirement to notify customers of the complaint resolution in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
B Run at Rate - when to perform / is it mandatory? IATF 16949 - Automotive Quality Systems Standard 19
M Minimum/ mandatory core processes AS9100 Process Maps, Process Mapping and Turtle Diagrams 6
H Is testing according to IEC 60601-1 & IEC 60601-1-2 mandatory for a device being registered under MDR? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
T Is NRTL certification mandatory in the US ? Registrars and Notified Bodies 2
R ISO 27001 Mandatory Policies , Procedures and Records IEC 27001 - Information Security Management Systems (ISMS) 0
Y Is Power Switch button mandatory IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Sidney Vianna IAF PR 7:2022 - Requirements for Producing IAF Mandatory Documents on Transitions ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 1
S Mandatory tests for IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 11
D IATF mandatory KPI? IATF 16949 - Automotive Quality Systems Standard 15
D Distribution Center mandatory addition to Certificate? IATF 16949 - Automotive Quality Systems Standard 3
J Mandatory Problem Reporting and Recalls Canada Medical Device Regulations 0
Dazza 9001, 14001 and 45001 mandatory documents and records cross reference matrix Process Maps, Process Mapping and Turtle Diagrams 2
S IEC 60601-2-30 - Is it mandatory to claim alarms? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
B What regulates DICOM Viewer? Wat are the mandatory info that shall be displayed on the screen? Other Medical Device Related Standards 1
Pau Calvo Quality Management process is mandatory in ISO9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
A Is it mandatory to obtain ISO13485 certificate prior to CE marking? EU Medical Device Regulations 8
K Is UDI (Unique Device Identifier) symbol mandatory under EU MDR? EU Medical Device Regulations 11
K Class III Kit Box - Are translations mandatory under EU MDR? EU Medical Device Regulations 5
M When is EN 62133-1 (new version i.e. IEC 62133:2017) mandatory in EU Other ISO and International Standards and European Regulations 3
S Mandatory documents vs shall "something" but without mandatory documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
M What is PESTLE Analysis and is it mandatory? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
F ISO 17025:2017 mandatory documentation requirements ISO 17025 related Discussions 1
D Is Human Factors testing mandatory for a 510(k) submission? Human Factors and Ergonomics in Engineering 16
K Mandatory Documents for EU authorized Representative under MDR CE Marking (Conformité Européene) / CB Scheme 8
Sidney Vianna Interesting Discussion Hello IAF. Are you listening? Please explain the inconsistency in your IAF Mandatory Documents ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 7
M Informational Health Canada – Mandatory reporting requirements for hospitals Medical Device and FDA Regulations and Standards News 0
Sidney Vianna The mystery of an IAF Mandatory Document disappearance ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 6
S IATF 16949: Is "Certified" Internal Auditor mandatory? IATF 16949 - Automotive Quality Systems Standard 9
K Is Compliance Testing of IEC 60601-2-63 mandatory for Europe - Dental X-Ray machine CE Marking (Conformité Européene) / CB Scheme 3
N IATF 16949 - Mandatory Corporate Documents IATF 16949 - Automotive Quality Systems Standard 10
S Are Defibrillator Protection and Pacemaker pulse detection features mandatory as per IEC 60601-2-25 or 2-27...? IEC 60601 - Medical Electrical Equipment Safety Standards Series 11
C ISO 7010 m002 mandatory action - Color requirements on Packaging IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
K Is Defib Protection mandatory for wearable ECG? IEC 60601 - Medical Electrical Equipment Safety Standards Series 10
U Whether First Article Inspection Report- FAI is mandatory for regular Human Factors and Ergonomics in Engineering 4
Sidney Vianna IAF Mandatory Document #23 - Control of CB Franchisees and Agents Registrars and Notified Bodies 3
Marc IAF Mandatory Documents (MD Series) - Required to be used by certification bodies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A Policies Mandatory or essential for ISO 27001 implementation IEC 27001 - Information Security Management Systems (ISMS) 6
