Is it normal practice to lubricate Ring Gages before use?
Q
QCOcra
I was wondering if it's normal practice to lubricate ring gages before use? And if so, what type lubrication? Should the lubrication be cleaned off after each use and re-applied after using it?
I have read some websites mention 3-in-1 oil and some companies sell specific gage lubrication (such as Deltronics gage-life-extender or lano lube).
Thanks!
Michael_M
I tell everyone to spray gage lube on thread gages once every 10-15 uses, I don't think it happens that often, but I try. We use it for thread gages as I have to replace gages due to wear and tear and it looks like it is wearing due to drag. We mostly make medium size threads 1"-3"
Q
QCOcra
Hi Michael,
Thanks for the reply! What kind of gage lube do you use?
I work with approximately 1/2" threads and smaller. We have been having issues with gages and I'm wondering if lubrication will make a difference. We mainly check threads dry. We do clean using nylon brushes.
DRAMMAN
I never worked anywhere e we lubricated plug or ring gages. But then again this was usually in machining environments where gages were continually exposed to lubricants from either machines or the parts. In other environments we always kept the gages clean and never had problems. What type of materials are you checking and how many parts do you check?
Michael_M
Hi Michael,
We use two types: Starrett M1 lubricant. This is a brush on type that typically comes in a gallon container. We also use Del-tronic gage lube spray.
I did not think of this, until I read dramman's post but material will make a difference. If you are checking soft materials such as aluminum or brass, you most likely do not need gage lube, however if you are running hard materials (316 etc), then I would recommend it.
Q
QCOcra
Our company started as a machine shop. Now we have transitioned to focus on our product line and our suppliers are machine shops. We ideally check clean parts so they won't have machine oil on them. They range from 6061 aluminum to 416 to 316 stainless steel.
Since I worked for this company lubrication was never used on the plug or ring gages. I know we've had issues with passing parts (mainly go gage), even with new calibrated gages.
Thank you for the replies, I will look into the lubricants for the gages.
Michael Malis
Isporopyl alcohol will also act as a lube that evaporates on its own after use, leaving behind no residue.
Sorry Mike,
isopropyl alcohol is a cleaner not a lubricant. Available in 50%, 70 and 90% percent concentrations is routinely used in a clean rooms to wipe parts from dust and disinfect for sterile use.
Regards,
Michael
U Theory and Practice Behind Expecting a Distribution for my Data (specially the normal Statistical Analysis Tools, Techniques and SPC 48
P Ppk results shown as asterisk after the transformation of Non-normal data Using Minitab Software 4
E Normal Condition Hazards in Risk Analysis ISO 14971 - Medical Device Risk Management 3
adir88 Tools for Normal and Fault Conditions ISO 14971 - Medical Device Risk Management 9
qualprod What is the Normal Flow in an ERP for Manufacturing? Manufacturing and Related Processes 0
A Touch current in single fault conditions test and earth leakage current in normal conditions test, are they really different tests? IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
D Do we need normal data for gage r&r studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
L How to evaluate the process capability of a data set that is non-normal (cannot be transformed and does not fit any known distribution)? Capability, Accuracy and Stability - Processes, Machines, etc. 12
R Non Normal Data in a historically normal process Capability, Accuracy and Stability - Processes, Machines, etc. 6
N Apply control limits to a non-normal distribution Statistical Analysis Tools, Techniques and SPC 13
J Is a stable process also normal at the same time? Manufacturing and Related Processes 7
S Jewelry vs. Normal Laboratory Balances - Accuracy and calibration General Measurement Device and Calibration Topics 2
R Non-normal Distribution Selection where the system is constantly being corrected Capability, Accuracy and Stability - Processes, Machines, etc. 11
J Is My AS9100 certification Auditor Normal? Registrars and Notified Bodies 9
Y Process Capability for Non-Normal Data - Philosophical Questions Capability, Accuracy and Stability - Processes, Machines, etc. 6
D Interpreting Normal vs Weibull Capabilities Capability, Accuracy and Stability - Processes, Machines, etc. 4
P Should Data be Normal before Computing Baselines? Statistical Analysis Tools, Techniques and SPC 4
A Not all characteristics follow a Normal Distribution - How do you do SPC Chart Capability, Accuracy and Stability - Processes, Machines, etc. 5
A Is normal for FORD EU ask for the PSW every year APQP and PPAP 5
V Process Capability for parameters with non-normal distribution. Capability, Accuracy and Stability - Processes, Machines, etc. 16
P Non-normal Data Cpk Statistical Analysis Tools, Techniques and SPC 5
S Non-Normal Data - Measurement for "straightness" with a 0.001" max tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 10
D Calculating Cpk on Non-Normal Data Distribution Capability, Accuracy and Stability - Processes, Machines, etc. 10
J Non-Normal Distribution Data - Tolerance Intervals and Minitab Using Minitab Software 7
J Can Normal Probability Paper and GPC be created with Excel Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M t-test with Non Normal Data Statistical Analysis Tools, Techniques and SPC 16
T Normal Distribution Test for Cpk (Minitab) Six Sigma 6
K Computing Cpk with out determining if my data is normal Capability, Accuracy and Stability - Processes, Machines, etc. 7
L Should Internal Audit CAPAs be kept separate from "normal" CAPAs? ISO 13485:2016 - Medical Device Quality Management Systems 6
A Handling Normal Capacitor Production Fallout AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
K Non-Normal Data Analysis Literature, Websites, Books for Learning Quality Tools, Improvement and Analysis 2
M Is it possible to get Natural Tolerance (Tn) with Non Normal Distribution? Statistical Analysis Tools, Techniques and SPC 9
B Is this Data a Normal Distribution? Statistical Analysis Tools, Techniques and SPC 10
L "Half Normal Plot vs Normal Probability Plot" of Effects Using Minitab Software 1
R Drawing a Normal Plot of the Effects for Multilevel Factorial Design Using Minitab Software 3
B Test of Means or Medians for Non Normal Populations? Using Minitab Software 6
B Is it normal for a procedure to begin with a conditional directive? (if statement) Document Control Systems, Procedures, Forms and Templates 30
S Relationship between Normal Distribution and AQL AQL - Acceptable Quality Level 13
R Transforming or not Transforming - Dealing with Non-Normal Data Statistical Analysis Tools, Techniques and SPC 10
O Which role plays Inverse cdf of a Standard Normal Distribution in Formula for Z-Bench Using Minitab Software 8
optomist1 Non-Normal Data F test and T test Capability, Accuracy and Stability - Processes, Machines, etc. 19
2 Medical Device Hazard Risks - Normal Use Risks vs. Faulty Use Risks ISO 14971 - Medical Device Risk Management 4
P Approved Suppliers - ISO 13485 Normal Supplier Qualification Process Requirements ISO 13485:2016 - Medical Device Quality Management Systems 9
S "Normal" vs. "Between/Within" Capability Analysis Capability, Accuracy and Stability - Processes, Machines, etc. 2
S Which Normality Test more acceptable to FDA; Also, Non-Normal Threshold? Qualification and Validation (including 21 CFR Part 11) 5
T Is Cpk Analysis only for Data that came from Normal Distribution? Capability, Accuracy and Stability - Processes, Machines, etc. 7
M Non-Normal Data & Minitab Statistical Analysis Tools, Techniques and SPC 17
