Is it OK to calibrate a measurement device tighter than manufacturer specifications?
Q
Qualqueen
#11
Re: Is it OK to calibrate a measurement device tighter than manufacturer specificatio
I would never try to calibrate to a tighter tolerance than the gage will read. Half a mark or 1/4 a mark? Phooey. If one wants a tight tolerance, one gets a gage designed and built for accurately measuring to said tolerance. Period. :2cents:
:applause::applause::applause: Couldn't say it better
bobdoering
Stop X-bar/R Madness!!
#12
I guess it depends on the calibration method, huh? If you adjust the pressure until you are on the gage to be calibrated mark (right on it, ok?), then read your 10:1 standard gage and have it determine the error, then I don't see the problem. E.g., set the pressure to exactly 50 PSIG on the gage being calibrated. The standard gage reads 50.3 PSIG. You're in.
Besides, the manufacturer's specification does not meet your mark to mark tolerance requirement. +/-30 PSIG with 50 PSIG increments. For mark to mark calibration you would need +/-50PSIG just to get adjacent marks.
Some folks might be mixing up resolution with bias error. The OP did not have clear info on the customer use to clarify if resolution is even an issue...although it is suspicious...
Wesley Richardson
Wes R
#13
So get this... A customer sends us a dial pressure gauge, 0-3000 PSIG, rated at 1% of full scale by the manufacturer (±30 PSIG.) The customer wanted it calibrated to 0.5% of FS, which is ±15 PSIG. The gage is marked in 50 PSIG increments, with a needle that is maybe 1/4 as wide as the spacing between the markings and no parallax mirror behind the needle.
It sounds like the customer is wanting a more accurate gauge, without paying the additional cost to purchase what is required for the application.
ASME B40.1 provides pressure grades and accuracies. Note that these do not include the effects due to measurement uncertainties. From the description, the customer has a Grade 1A (1% full scale) gage, and wants it calibrated to then become a Grade 2A (0.5% full scale) gage.
I recommend against providing a calibration certificate that the gage meets the tighter specification. This is based on the fact that the inherent characteristics of the gage are not changed by calibration. If it met the tigher requirements, then the manufacturer would have specified it as being the tighter tolerance gauge.
Wes R.
bobdoering
#14
Or, if it doesn't it will fail calibration and the problem is solved.
Jen Kirley
Quality and Auditing Expert
#15
I was responding to a post describing how the tolerance was being attempted to less than one measurement increment on the dial. The gage has a dial with those increments for a reason - the gage is designed and constructed to function in a range. A large range gage will generally have larger accuracy tolerances. One selects the gage one needs based on range or tolerance.
In a quality system, as a good practice I wouldn't dream of asking for a gage with, for example .001" increments to produce accuracy of .0005" and the gage user to read .0005" with the needle floating somewhere between two lines.
bobdoering
#16
Yes, I agree, resolution 10:1 to the tolerance or 10:1 to the control limits - no need to interpolate.
However, calibration is looking to how close the gage reads to the standard - is 50PSIG really 50PSIG? For that the tolerance of the standard gage must be 10:1 (or some say 4:1) to the gage being calibrated.
Fact is, they may have done exactly that (we don't know from the info we received what the actual measurement tolerance is), but they just want to be sure that if the gage they bought reads 50PSIG, it is really between 35 and 65PSIG, not 20 and 80 PSIG. That is bias, not resolution.
Hershal
Metrologist-Auditor
#17
If the customer wants it, and it's properly documented in contract review, I don't see how you could be liable for anything. I would also put a note on the cert stating the customer's requirement.
Now common sense tells you that you should really explain the reasoning to the customer as to why this shouldn't be done.
But, bottom line, if the customer wants it and it's documented, you're operating within the requirements of 17025 as a cal provider.
Daniel is correct.
The technical issues aside, it is allowed under 17025 though not good practice, as your uncertainty for the cal will likely approach 20% or even more because now resolution and parallax will drive the Type B's, and subsequently affect the Type A's as well.
But if the customer understandards that any reading he makes using that item will be indication +/- a 25% error (uncertainty) and is comfortable with that, then document it really well, and make sure the customer signs off on it.
But do suggest acquisition and use of a different instrument that will actually provide what the customer truly needs.
ScottBP
#19
Ok, well I just had another situation where a customer wanted a thermocouple measuring device to read within ±1.0°F at certain test points. All the readings were well within that limit (the largest deviation was 0.2°F), but when we put down the manufacturer's spec of ±1.4°F like we always do for this particular model, the customer got bent out of shape, so I ended up amending their certificate to show the deviation was within the ±1.0°F spec that the regulation they were using called for (AMS-2750D raises its ugly head again). I left the manufacturer's spec in place for all to see so the customer can decide for themselves if it is acceptable to rate the meter tighter than what the manufacturer's specs call for, or go out and get a more accurate meter.
J Calibrate before use required? Inspection Gages and Measurement Equipment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M Measurement System Analysis (MSA) - 2500 Instruments - Calibrate every one? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A Looking for a third party to calibrate our measure equipment - South Carolina General Measurement Device and Calibration Topics 6
I Can I Calibrate On Demand? General Measurement Device and Calibration Topics 9
S Calibrating our own equipment, can we? Micrometers to calibrate vernier calipers General Measurement Device and Calibration Topics 13
F Crimper Calibration - How do you Control & Calibrate your crimpers? Calibration Frequency (Interval) 13
P How to Calibrate a HP 3458A Digital Multimeter with Fluke 5080A calibrator General Measurement Device and Calibration Topics 1
B Choosing not to calibrate (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 6
K New Kilogram - The process we use to calibrate the standards General Measurement Device and Calibration Topics 6
D How to Calibrate any Digital Sphygmomanometer under use for 2 years in a Hospital Forum News and General Information 1
L Re-calibrate after software update? Calibration Frequency (Interval) 3
J To Calibrate or not to calibrate electronics rack components Manufacturing and Related Processes 5
T How to Calibrate Taper Gages General Measurement Device and Calibration Topics 1
N Calibrate temperature on refrigerated Centrifuges? General Measurement Device and Calibration Topics 2
B Can we calibrate a standard pin with a gauge? General Measurement Device and Calibration Topics 2
D Lesser expensive to calibrate various test weights General Measurement Device and Calibration Topics 5
A How to Calibrate Laser Beam Tester & Radiation Monitor General Measurement Device and Calibration Topics 3
D How to Calibrate and Verify a Heating Oven General Measurement Device and Calibration Topics 3
P How do you calibrate a VNA (Vector Network Analyzer) cal kit? General Measurement Device and Calibration Topics 4
V How to Calibrate Ring Force Gauges Service Industry Specific Topics 1
bobdoering Who says you can't calibrate a steel rule! Funny Stuff - Jokes and Humour 14
S How can I Calibrate a Biosafety Cabinet? General Measurement Device and Calibration Topics 1
C How to Calibrate a Viscosity Tester General Measurement Device and Calibration Topics 3
0 Is it possible to use a threaded ring gage to calibrate the M8 gage? Calibration and Metrology Software and Hardware 4
C How to Calibrate a Medical Infrared Thermometer General Measurement Device and Calibration Topics 3
T How do I calibrate NPT Thread Plug Gages? General Measurement Device and Calibration Topics 9
E Do you need a Certification to Calibrate Gauges? General Measurement Device and Calibration Topics 2
B Calibrate Hole Presence Detection Device? General Measurement Device and Calibration Topics 5
J What do you use to Calibrate 40" Calipers General Measurement Device and Calibration Topics 10
A Guideline to Calibrate Chamber Temp. & Pressure of a Medical Steam Sterilizer General Measurement Device and Calibration Topics 8
S How to calibrate AOI (Automated Optical Inspection) for IOPQ Qualification and Validation (including 21 CFR Part 11) 3
S Laboratory to Calibrate Objective Micrometer needed General Measurement Device and Calibration Topics 4
C Tolerance Estimation of a Load Cell I want to Calibrate General Measurement Device and Calibration Topics 9
D Procedure on How to Calibrate a External Micrometer General Measurement Device and Calibration Topics 1
B ISO/TS 16949 Section 7.6.3 - Use of Manufacturer to Calibrate IATF 16949 - Automotive Quality Systems Standard 21
W How to verify/calibrate a Neptune Water Meter General Measurement Device and Calibration Topics 4
N Laboratory that is able to Calibrate Dew Point Meter up to 60?Cdp - Needed General Measurement Device and Calibration Topics 1
C How to Calibrate and Verify Torque Multiplier Gages General Measurement Device and Calibration Topics 6
C How to calibrate or control patterns for fiberglass General Measurement Device and Calibration Topics 4
N Scale with Internal Calibration - Do I need to calibrate? How to document this? Calibration Frequency (Interval) 8
I Need help finding an Accredited Lab that can Calibrate Brunson 76-RH Survey Transits General Measurement Device and Calibration Topics 5
M Controlling Temperature and Time - Do I need to calibrate the thermostat? IATF 16949 - Automotive Quality Systems Standard 4
D How much Tolerance do I use to Calibrate a 150kgs capacity Scale? General Measurement Device and Calibration Topics 5
M To Calibrate or Not to Calibrate various Weight Scales ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
N Thermocouple Inhomogeneity - Need to calibrate a roll of 50m thermocouple type K General Measurement Device and Calibration Topics 3
R Traceability for Mercury Argon Calibration Source to Calibrate a Spectrometer? General Measurement Device and Calibration Topics 5
P How to Calibrate Laser Micrometer when no Calibration Company in the Country? General Measurement Device and Calibration Topics 3
S 3 Point Calibration or Calibrate to Extreme High and Low? General Measurement Device and Calibration Topics 9
C Seeking a holder/jig to calibrate large OD micrometer calipers (up to 23") General Measurement Device and Calibration Topics 8
B Difference between Calibration & Verification and How to calibrate Go/No Go gauge? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
