Is it possible for medical power supply to declare CE based on MDD?
Roland chung
Dear all,
As you can see from the caption, my question is about the CE declaration of non-medical equipment. Is it possible for medical power supply to declare CE based on Medical Device Directive?
Thanks,
Roland
SteveK
Dear all,
Thanks,
Roland
Hi Roland,
We use a switching power adaptor from XP Power (AFM45/60) and we were supplied a EN 60601-1:2006 Certificate. However, there is no reference in the documentation I have to MDD 93/42/EEC but it does carry a CE mark as you would expect. I assume that it is CE marked under the Low Voltage Directive - but it does not reference this either.
This probably only muddy the waters.
Sorry
Steve
Roland chung
Thank you for your input.
If the power supply is tested to EN 60601-1, it seems not suitable to declare CE based on the LVD directive.
SteveK
Hi again Roland,
I've found a very similar certificate to the one I indicated for a similar adaptor which does reference the MDD.
http://proe-fuhua-cn.kenfor.com/dat...om/db_pictures/201112/02/1322792363817467.pdf
I assume that if the adaptor carries the NB CE number (assuming Class IIa - Rule 9) then that would prove that the CE mark is covered through the MDD. Will have to track down a label on such a unit to view this though.
Steve
somashekar
Medical power supply (Medical grade power supply) in conjunction with the medical device constitute within the 60601-1 scope.
As a standalone they can be certified to applicable UL, CSA, and IEC/TUV standards.
It is the choice of the medical device manufacturer which makes it a medical device power supply. Power supply manufacturers consider the requirements of medical devices and application to build power supplies that can be said as medical grade / custom made to medical devices.
So I would say NO. Is it not possible for medical power supply to declare CE based on Medical Device Directive?
As always with CE stuff ... Ask NB
Peter Selvey
It's a good question.
Basically I would say yes it's possible to CE mark under medical device directive, and without involvement of a notified body (i.e. a Class I medical device).
Although it's intended purpose is not fully specified, it would be in the same category as other broadly applicable devices, like a general purpose syringe.
The problem is, though, that the CE marker probably would not have really checked all requirements in the regulation. They most likely just did a 601-1 electrical safety and possibly the 601-1-2 EMC test, extracting the relevant clauses to a power supply, and that's it.
Those familiar with the directive would know there are a bunch of other things like marking and registering EU reps, marking date of manufacturer etc. So the absence of such marking might give a hint that it's a bit of a fudge CE mark.
Roland chung
If I understand correctly, components intended to be used in medical equipment can bear the CE mark (self-declaration) if all requirements of medical device directive are checked.
I am not familiar with self-declaration. If we just have test reports and mark the CE on the label, will we be punished?
Peter Selvey
You need to fulfill all the requirements in the relevant Articles and Annexes. Key ones will be Article 14 (registration) and Annex VII for self declaration. Also, you need to check the specific marking requirements in Section 13 of Annex I.
Search the directive for any reference to the "manufacturer" and/or "shall", to sure everything applicable is done.
F Apple Watch is not a medical device. How can this be possible? CE Marking (Conformité Européene) / CB Scheme 1
3 Israel: 1 Medical Device, Multiple Registrations = Possible? Other Medical Device Regulations World-Wide 3
Ajit Basrur Is Biocompatibility study performed on medical devices for possible contaminants? Other Medical Device Related Standards 4
P Import of medical devices to Brazil without registration possible ? Other Medical Device Regulations World-Wide 5
J Medical Device Risk Analysis - FMEA vs ALARP (As Low As Reasonably Possible) FMEA and Control Plans 3
J EC Certification transfer from CMO to Legal Manufacturer Possible? CE Marking (Conformité Européene) / CB Scheme 0
K Silver Plating corroding possible during SMT Manufacturing and Related Processes 10
K Is it possible to avoid the OQ? ISO 13485:2016 - Medical Device Quality Management Systems 20
G Special 510K possible? Only the packaging has changed Other US Medical Device Regulations 0
supadrai Possible to Submit a 510(k) if you have never, do not and cannot produce the device for which you're submitting the application? US Food and Drug Administration (FDA) 4
J Possible to get ISO 13485 certified with only OEM Product? ISO 13485:2016 - Medical Device Quality Management Systems 4
D Where does "as far as possible" stop? FMEA - EN 14971 ISO 14971 - Medical Device Risk Management 29
M Informational EU – Possible EUDAMED delay Medical Device and FDA Regulations and Standards News 3
M Is it possible to get iso 13485:2016 certified as a one man band ISO 13485:2016 - Medical Device Quality Management Systems 1
Ashok sunder Is it possible to reduce Risk likelihood and impact Post control Ranking after corrective action taken for risk? FMEA and Control Plans 1
dhuot1990 USP 41 Hanging Scale - Is it possible to make a hang scale adhere to USP41 Standards? ISO 17025 related Discussions 3
qualprod ISO 9001:2015 Clause 8.3 - Is it possible to exclude one product but include it in other? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Ashok sunder Is it possible to reduce FMEA Occurrence and Detection Ranking after corrective action taken for customer complaints? FMEA and Control Plans 6
B Integrated management system - ISO 9001 and ISO 14001 - Is possible to have a joint certificate covering both standards? ISO 14001:2015 Specific Discussions 6
E Is it possible to start an ISO 9001 QMS from scratch (Really) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
M Some possible misunderstandings on the application of ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 10
P Is it possible to make an educated decision using a very very small sample size? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
a_bardi Is it possible to exclude internal audit from qms scope? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
G ISO 9001:2015 - Is control possible with Excel adaptable measurement sheets? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
S Indications for Use - Is it possible to have a different indication for use EU Medical Device Regulations 1
C %GRR <10% not possible. How to get approval by auditor? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 15
I Is risk acceptability really needed if all risks must be reduced as far as possible? ISO 14971 - Medical Device Risk Management 6
M Is Automated Internal Auditing Possible? Internal Auditing 13
A Integrated Management Systems - ISO 50001 and ISO 9001 possible? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
P Is it possible to receive EASA STC within 48 hours after modification? EASA and JAA Aviation Standards and Requirements 1
Marc Yahoo probes possible huge data breach - BBC News - 2016 World News 1
Marc Yahoo probes possible huge data breach World News 0
S Preparing a Root Cause Report - Possible Root Causes Document Control Systems, Procedures, Forms and Templates 11
M Future of ISO 14971 - Possible revision? ISO 14971 - Medical Device Risk Management 9
M Is IEC 60601 compliance possible when only generic power-supply is specified? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
M Is it possible to have more than one authorized representative in Saudi Arabia? Other Medical Device Regulations World-Wide 6
Y Is it possible to check the authenticity of a CFDA registration certificate? China Medical Device Regulations 7
T Reduced Audit days when UPGRADING from AS9100 to TS16949 - Is it possible? IATF 16949 - Automotive Quality Systems Standard 2
B Subsidiary - No Managing Director - Is ISO 9001 Certification Possible? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Is it possible to randomly select samples from 1 column to many column Using Minitab Software 2
Marc Google Fiber chooses nine metro areas for possible expansion After Work and Weekend Discussion Topics 1
Hershal ILAC is preparing to start the possible revision to ISO/IEC 17025 ISO 17025 related Discussions 2
0 Is it possible to use a threaded ring gage to calibrate the M8 gage? Calibration and Metrology Software and Hardware 4
A Is it possible for STC application before issue of TC ? EASA and JAA Aviation Standards and Requirements 4
B Is it possible that a virus sends spam on Facebook? After Work and Weekend Discussion Topics 6
Ronen E Incretin Mimetic Drugs for Type 2 Diabetes: Possible Increased Risk Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
S Is it possible to have a General Change Control SOP and Form? Document Control Systems, Procedures, Forms and Templates 6
J Quality Management Process Model Possible Interactions and Effects ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M Is it possible to have two QMSs? One for each or our two products EU Medical Device Regulations 9
T Is "World Class" Quality possible by Accident? Coffee Break and Water Cooler Discussions 18
