Is it possible to make an educated decision using a very very small sample size?
P
ProblemChild
When an inspection is complex and very costly. Is there a way to make an educated decision based on a very very very small sampling size?
For example, I have a population of 10,000 units. Based on the AQL table at level II, I suppose to inspect a lot size of 200 units.
What happens when an inspection becomes very costly. (due to complex inspections steps, high transportation cost, or inspection itself is destructive. )
Is there a "logical" way one can make an acceptance decision based on a single digit sample size in this case?
I know how it sounds, but inspecting 200 units is just impossible in this case.
Mike S.
Happy to be Alive
Like another recent poster, you seem to want a treasure trove of data to be extracted from just a few samples. Don't we all! Unless you have valid reasons to believe that the homogeneity of the lot is exceptionally good, the answer is no.
Now, if your process controls are such that you do have valid reasons to believe that the lot is very homogenous, then small sample sizes can be said to be representative of the lot. I have had processes where I would use 2 samples to represent thousands of parts, and did so successfully, but only when my other process controls showed the process was in control.
Without knowing your process and process controls, we cannot answer that question.
One thing to keep in mind is that most sampling plans were designed for binomial data (i.e., pass/fail). If you are able to collect variable data during your inspection, these sampling plans are not appropriate. You can either switch to a variable data sampling plan, or use other statistical methods designed for variable data. Either approach would reduce the sample size required.
When an inspection is complex and very costly...
To complete the sentence, you need to do whatever you can in terms of process control to avoid expensive post-production inspection. Sampling is all about risk. No one here knows anything about the history of the product in question or the potential risks involved in reducing or eliminating lot acceptance sampling. You need to determine (or recognize) what bad things might happen if a given lot isn't inspected, or if a radically reduced sample size is used, and act accordingly.
J EC Certification transfer from CMO to Legal Manufacturer Possible? CE Marking (Conformité Européene) / CB Scheme 0
K Silver Plating corroding possible during SMT Manufacturing and Related Processes 10
K Is it possible to avoid the OQ? ISO 13485:2016 - Medical Device Quality Management Systems 20
G Special 510K possible? Only the packaging has changed Other US Medical Device Regulations 0
supadrai Possible to Submit a 510(k) if you have never, do not and cannot produce the device for which you're submitting the application? US Food and Drug Administration (FDA) 4
J Possible to get ISO 13485 certified with only OEM Product? ISO 13485:2016 - Medical Device Quality Management Systems 4
D Where does "as far as possible" stop? FMEA - EN 14971 ISO 14971 - Medical Device Risk Management 29
M Informational EU – Possible EUDAMED delay Medical Device and FDA Regulations and Standards News 3
M Is it possible to get iso 13485:2016 certified as a one man band ISO 13485:2016 - Medical Device Quality Management Systems 1
Ashok sunder Is it possible to reduce Risk likelihood and impact Post control Ranking after corrective action taken for risk? FMEA and Control Plans 1
dhuot1990 USP 41 Hanging Scale - Is it possible to make a hang scale adhere to USP41 Standards? ISO 17025 related Discussions 3
F Apple Watch is not a medical device. How can this be possible? CE Marking (Conformité Européene) / CB Scheme 1
qualprod ISO 9001:2015 Clause 8.3 - Is it possible to exclude one product but include it in other? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Ashok sunder Is it possible to reduce FMEA Occurrence and Detection Ranking after corrective action taken for customer complaints? FMEA and Control Plans 6
B Integrated management system - ISO 9001 and ISO 14001 - Is possible to have a joint certificate covering both standards? ISO 14001:2015 Specific Discussions 6
E Is it possible to start an ISO 9001 QMS from scratch (Really) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
M Some possible misunderstandings on the application of ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 10
a_bardi Is it possible to exclude internal audit from qms scope? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
G ISO 9001:2015 - Is control possible with Excel adaptable measurement sheets? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
S Indications for Use - Is it possible to have a different indication for use EU Medical Device Regulations 1
C %GRR <10% not possible. How to get approval by auditor? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 15
I Is risk acceptability really needed if all risks must be reduced as far as possible? ISO 14971 - Medical Device Risk Management 6
M Is Automated Internal Auditing Possible? Internal Auditing 13
A Integrated Management Systems - ISO 50001 and ISO 9001 possible? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
P Is it possible to receive EASA STC within 48 hours after modification? EASA and JAA Aviation Standards and Requirements 1
3 Israel: 1 Medical Device, Multiple Registrations = Possible? Other Medical Device Regulations World-Wide 3
Marc Yahoo probes possible huge data breach - BBC News - 2016 World News 1
Marc Yahoo probes possible huge data breach World News 0
S Preparing a Root Cause Report - Possible Root Causes Document Control Systems, Procedures, Forms and Templates 11
M Future of ISO 14971 - Possible revision? ISO 14971 - Medical Device Risk Management 9
M Is IEC 60601 compliance possible when only generic power-supply is specified? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
M Is it possible to have more than one authorized representative in Saudi Arabia? Other Medical Device Regulations World-Wide 6
Y Is it possible to check the authenticity of a CFDA registration certificate? China Medical Device Regulations 7
T Reduced Audit days when UPGRADING from AS9100 to TS16949 - Is it possible? IATF 16949 - Automotive Quality Systems Standard 2
Ajit Basrur Is Biocompatibility study performed on medical devices for possible contaminants? Other Medical Device Related Standards 4
B Subsidiary - No Managing Director - Is ISO 9001 Certification Possible? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Is it possible to randomly select samples from 1 column to many column Using Minitab Software 2
Marc Google Fiber chooses nine metro areas for possible expansion After Work and Weekend Discussion Topics 1
Hershal ILAC is preparing to start the possible revision to ISO/IEC 17025 ISO 17025 related Discussions 2
0 Is it possible to use a threaded ring gage to calibrate the M8 gage? Calibration and Metrology Software and Hardware 4
A Is it possible for STC application before issue of TC ? EASA and JAA Aviation Standards and Requirements 4
B Is it possible that a virus sends spam on Facebook? After Work and Weekend Discussion Topics 6
Ronen E Incretin Mimetic Drugs for Type 2 Diabetes: Possible Increased Risk Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
R Is it possible for medical power supply to declare CE based on MDD? IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
S Is it possible to have a General Change Control SOP and Form? Document Control Systems, Procedures, Forms and Templates 6
J Quality Management Process Model Possible Interactions and Effects ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M Is it possible to have two QMSs? One for each or our two products EU Medical Device Regulations 9
T Is "World Class" Quality possible by Accident? Coffee Break and Water Cooler Discussions 18
J Two Quality Management Systems - ISO 13485 in one company possible? Quality Manager and Management Related Issues 4
Marc Great Lakes - 24 foot waves possible! October 2012 Coffee Break and Water Cooler Discussions 1
