Is it possible to start an ISO 9001 QMS from scratch (Really)
E
esadaddy
Hello everyone,
I have spent numerous hours combing the pages of the internet searching for an answer to my question.
Is it possible to establish a draft of an ISO 9001 QMS within a company that is new, new as in there isn't any work, any past performance. The company's ownership would like to get the ball running as fast as possible and as a result would like as much of the QMS developed prior to the doors openeing.
Most of the "starting from scratch" scenarios involved companies that were at least having some sort of work going on.
leftoverture
Everyone started somewhere. I don't see why you couldn't do this. It will take planning, and may require several revisions as things get up and running, but in some ways it might even be easier because you won't have any bad habits to deal with.
Sent from my LG-TP260 using Tapatalk
Hello everyone,
If what you are saying is that the business isn't yet launched, no orders taken etc. then yes it can be done, with the exception that it's only a plan. You can't do some of the things the standard requires since there is no "performance" to evaluate, to audit and review.
Golfman25
Sure you can do it, but why? To me it may just complicate things. You'll have enough work to do just getting started. Since 90% of ISO QMS is just regular business sense, why not focus on setting up your processes and procedures -- how are you going to run the business. Get some draft flow charts together. Then if you really want to, apply the ISO standard and fill in any gaps. To me it's more important that you apply the standard to your business (what works for you) rather than the business to the standard (simply trying to comply). Good luck.
Kronos147
Great post right there!
I'll add that most successful companies already do many of the requirements, they would just have trouble showing effective documented information as objective evidence.
Do a gap analysis after you follow the Golfman approach and fill in the gaps.
Finally, find SIMPLE methods of creating effective documented information as evidence of compliance.
qualprod
Esadady
Most of opinions are missing the more important thing.. knowledge and experience.
It is true, it is possible to start from scratch, but are you experienced enough for this task?
Have you evaluated, how long will it take to finish the project.
If you are novice, and want to achieve this alone, for sure will face a lot of problems, if you have a decent experience I don't see problems.
What I have seen , is if you have a short time frame to achieve this goal, and want to start the knowing of ISO, don't take risks, hire a consultant, if you have a long timeframe , ok you can try it, but if you are experienced go ahead it can be done in the short timeframe.
Hope this helps
Ninja
Looking for Reality
Funny, I thought something totally different was missing...
Why would you do this?
Why invest money (someone's time) into building out a QMS for a company that doesn't do anything yet?
Get customers first...get revenue first...then establish the QMS out of the profits.
If you need the QMS first, in order to get the first customer...then it is one of the extremely rare times I would point toward "ISO in a box".
Any QMS you establish before you have a functioning process is going to be pretty useless anyway...
Once you have revenue, rewrite the whole darned thing into something of value.
mikegospo
For a new start-up company you would start from scratch completely. The QMS would be developed based on risk which would meet the requirements of the particular standard. If you want to be certified, your CB would need to determine the extent of the records needed in order to prove that your system is effective.
For an existing company, the historical records are typically available as you have produced and shipped product. The missing information typically would relate to the evaluation of quality objectives evaluated during management review. I typically try to resurrect data from the past 6 months of previous production.
Wesley Richardson
Wes R
I think it is important to start a discussion with the ownership so they understand the purpose of a quality management system (QMS), and that it is not a static system, but one the evolves over time. A QMS helps to create consistency in processes, attempts to prevent undesired results, and provides a method for corrective actions when results are different than desired, so they may be prevented from occurring in the future.
The ownership also needs to understand that drafts of procedures and methods can be created before processes are started, but these procedures will also change when the processes (production or services) actually start, and again when the processes are refined to make improvements.
Verification that the methods and procedures are being followed, are sufficient to describe the methods, and that the product or service outcomes meet the intended requirements, can only be completed after the processes are being performed.
A realistic time frame to implement a QMS from scratch is about two years. I am aware of organizations that have meet ISO 9001 in 6 months, but this is where most of the documents and procedures were already in place, and the entire organization, including management, was involved with the process.
ISO 9001 is only one of many possible QMS available. The organization should select the QMS that most closely aligns with the ownership's goals, and one that fulfills client or customer requirements.
Once a QMS standard is selected, carefully go through each element, assign responsibilities for a person to lead each area, set timelines, and monitor progress. Everyone, all departments, including management, and upper management, needs to be involved. This change is not something that can just be assigned to the quality manager or quality department, and expect it to happen on its own. Ownership and upper management must also understand that it will require resources in terms of time (labor hours), probably software development and implementation, and investment in equipment for process monitoring and control.
With a realistic timeline, ongoing implementation and feedback, a QMS can be created from scratch, just not one that is fully functioning on the day the organization opens for business.
Hershal ILAC is preparing to start the possible revision to ISO/IEC 17025 ISO 17025 related Discussions 2
D FMEA as a tool for identifying possible failures in Acquisition / New Start Up FMEA and Control Plans 4
J Possible to get ISO 13485 certified with only OEM Product? ISO 13485:2016 - Medical Device Quality Management Systems 4
D Where does "as far as possible" stop? FMEA - EN 14971 ISO 14971 - Medical Device Risk Management 29
M Informational EU – Possible EUDAMED delay Medical Device and FDA Regulations and Standards News 3
M Is it possible to get iso 13485:2016 certified as a one man band ISO 13485:2016 - Medical Device Quality Management Systems 1
Ashok sunder Is it possible to reduce Risk likelihood and impact Post control Ranking after corrective action taken for risk? FMEA and Control Plans 1
dhuot1990 USP 41 Hanging Scale - Is it possible to make a hang scale adhere to USP41 Standards? ISO 17025 related Discussions 3
F Apple Watch is not a medical device. How can this be possible? CE Marking (Conformité Européene) / CB Scheme 1
qualprod ISO 9001:2015 Clause 8.3 - Is it possible to exclude one product but include it in other? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Ashok sunder Is it possible to reduce FMEA Occurrence and Detection Ranking after corrective action taken for customer complaints? FMEA and Control Plans 6
B Integrated management system - ISO 9001 and ISO 14001 - Is possible to have a joint certificate covering both standards? ISO 14001:2015 Specific Discussions 6
M Some possible misunderstandings on the application of ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 10
P Is it possible to make an educated decision using a very very small sample size? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
a_bardi Is it possible to exclude internal audit from qms scope? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
G ISO 9001:2015 - Is control possible with Excel adaptable measurement sheets? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
S Indications for Use - Is it possible to have a different indication for use EU Medical Device Regulations 1
C %GRR <10% not possible. How to get approval by auditor? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 15
I Is risk acceptability really needed if all risks must be reduced as far as possible? ISO 14971 - Medical Device Risk Management 6
M Is Automated Internal Auditing Possible? Internal Auditing 13
A Integrated Management Systems - ISO 50001 and ISO 9001 possible? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
P Is it possible to receive EASA STC within 48 hours after modification? EASA and JAA Aviation Standards and Requirements 1
3 Israel: 1 Medical Device, Multiple Registrations = Possible? Other Medical Device Regulations World-Wide 3
Marc Yahoo probes possible huge data breach - BBC News - 2016 World News 1
Marc Yahoo probes possible huge data breach World News 0
S Preparing a Root Cause Report - Possible Root Causes Document Control Systems, Procedures, Forms and Templates 11
M Future of ISO 14971 - Possible revision? ISO 14971 - Medical Device Risk Management 9
M Is IEC 60601 compliance possible when only generic power-supply is specified? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
M Is it possible to have more than one authorized representative in Saudi Arabia? Other Medical Device Regulations World-Wide 6
Y Is it possible to check the authenticity of a CFDA registration certificate? China Medical Device Regulations 7
T Reduced Audit days when UPGRADING from AS9100 to TS16949 - Is it possible? IATF 16949 - Automotive Quality Systems Standard 2
Ajit Basrur Is Biocompatibility study performed on medical devices for possible contaminants? Other Medical Device Related Standards 4
B Subsidiary - No Managing Director - Is ISO 9001 Certification Possible? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Is it possible to randomly select samples from 1 column to many column Using Minitab Software 2
Marc Google Fiber chooses nine metro areas for possible expansion After Work and Weekend Discussion Topics 1
0 Is it possible to use a threaded ring gage to calibrate the M8 gage? Calibration and Metrology Software and Hardware 4
A Is it possible for STC application before issue of TC ? EASA and JAA Aviation Standards and Requirements 4
B Is it possible that a virus sends spam on Facebook? After Work and Weekend Discussion Topics 6
Ronen E Incretin Mimetic Drugs for Type 2 Diabetes: Possible Increased Risk Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
R Is it possible for medical power supply to declare CE based on MDD? IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
S Is it possible to have a General Change Control SOP and Form? Document Control Systems, Procedures, Forms and Templates 6
J Quality Management Process Model Possible Interactions and Effects ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M Is it possible to have two QMSs? One for each or our two products EU Medical Device Regulations 9
T Is "World Class" Quality possible by Accident? Coffee Break and Water Cooler Discussions 18
J Two Quality Management Systems - ISO 13485 in one company possible? Quality Manager and Management Related Issues 4
Marc Great Lakes - 24 foot waves possible! October 2012 Coffee Break and Water Cooler Discussions 1
R Possible Actions for Nonconforming Product besides issuing NC Nonconformance and Corrective Action 6
M Is it possible to get Natural Tolerance (Tn) with Non Normal Distribution? Statistical Analysis Tools, Techniques and SPC 9
N Is it possible to get Minitab for free? Older downloadable version for free online? Using Minitab Software 5
J Customer PPAP Approvals - Internal PPAP Possible? APQP and PPAP 7
