Is it required to upgrade an AS9100 B Procedure Manual to AS9100 Rev. C
sideoiler
This may sound like a real dumb question, but here it goes.... If you have recently upgraded from a AS9100 Rev. B QMS to Rev. C is it required to upgrade your AS9100 Procedure Manual to Rev. C as well? (example Rev. B has no mention of Risk Management) Can I just incorporate procedures to my existing QAP Manual for sections 3.1 - 3.4, is it necessary, or do I have to upgrade the QAP Manual to Rev. C also... This is my first Rodeo as QA and kind of got thrown into the fire because I was available to take over where the last rep stopped in mid implementation. We just got certified last year and are about to have our full third party audit here shortly. I would like to minimize the amount of what some may consider "no brainer" findings, as best I can....
Any and all feedback would be greatly appreciated....
rickpaul01
Involved in HankyPanky
Hi Side,
I’m not clear on your question, so I’ll be careful how I phrase my response.
You need a Quality Manual.
You also need some top level procedures. These could be part of the QM, or separate documents that are referenced in the QM (What most organizations do.)
These two levels of documents need to match the Rev C requirements.
The documents in the next level down probably include some “procedures” also. But to avoid confusion with level two procedures, I call these work instructions. The only level three document that I remember having to change as a result of Rev C, is a work instruction used by our internal auditors. (New revision caused us to ask different questions during the audits.) There might have been a couple others that I don’t remember, but the point is that level threes are not as aligned with the standard as the first two levels.
Hope this helps.
RCW
Could you please define what is in your "AS9100 Procedure Manual"? Is this your quality manual? All your quality procedures? A combination of both? Or something else all together?
sideoiler
Rickpaul thanks for the input, it helps a lot.... I had a good idea someone would tell me yes that it is necessary for the QM and QP to be on the same Rev. but wasn't 100% sure. I have so many loose ends that I am trying to tighten up that I almost overlooked the two manuals, making sure they are both on the same Rev.
Thanks again!:)
sideoiler
It is the quality procedures.
Joy
There is no change in requirement for quality manual (clause 4.2.2) in Rev.C.So if the requirements mentioned in the clause are met, auditor cannot object.Taking your example of risk management,if you have a good system of risk management in the organization but no mention in quality manual,would not be a problem.However, if you establish a documented procedure for the risk management,either you have to make a reference of the procedure in the quality manual or the documented procedure itself need to be in the quality manual.In such situations you have to make some changes in the manual.
As you want to save time, my suggestion would be first implement systems to meet the new requirements.Then check if you are able manage (effectively) without documented procedure.If not, go for documentation.Once it is done, go for changes in the quality manual.
Hope it helps.
dsanabria
Future reference - do not include rev in your quality manual - this way you don't have to worry about changing, upgrading or proving that it meets the latest.
Meet the requirement of the standards and in the back (or where ever you have the history of upgrade) make a statement of what was updated.
sideoiler
Hope it helps.
Joy, thanks for the great info.... I will take your advise and see if we can conform without a documented procedure for the time being...:thanx:
sideoiler
Dsanabria, Sorry for the confusion, I was not referring to the revision of my quality manual, but rather the revision of the AS9100 standards themselves.
K Upgrade scope of registration to include support site required? IATF 16949 - Automotive Quality Systems Standard 2
J Required Upgrade to ISO/TS 16949:2002 IATF 16949 - Automotive Quality Systems Standard 3
T New process capability analysis required when changing a product on the same line? IATF 16949 - Automotive Quality Systems Standard 6
G Clause 7.5.3 and Required Work Instructions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 41
K Equipment IQ/OQ/PQ required when you have 100% product inspection? ISO 13485:2016 - Medical Device Quality Management Systems 2
A Help required in establishing Laboratory Information Management System as per ISO 17025, Cl.7.11.2 ISO 17025 related Discussions 0
Z AS9102B Form 1, line 19 question. Is a printed name and signature both required or is only a signature sufficient? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
D Is it required to have the operator initial their work in the IATF 16949:2016 standard? IATF 16949 - Automotive Quality Systems Standard 3
B Are forms and templates required? Document Control Systems, Procedures, Forms and Templates 10
A Why is Protective Earth Resistance required <0.1ohm or 0.2ohm in 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 10
D Is Good Laboratory Practice (GLP) Required in ISO 17025? ISO 17025 related Discussions 4
K What are the differences between the certificates required for home and medical medical equipment? US Food and Drug Administration (FDA) 1
I MOPP required for SIP when considering Single Fault Condition (SFC) in 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 16
B AS9100:D - Purchase Order required if ordering paint on supplier portal? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
V Is it required to recalibrate reference- standard instruments after equipment qualification General Measurement Device and Calibration Topics 0
B Supplier Evaluation report - Validation required or not ISO 13485:2016 - Medical Device Quality Management Systems 3
H Registration for REACH required for Non-EU Down Stream Manufacturer? REACH and RoHS Conversations 5
P AS9100D clause 8.6 - Documentation required to show evidence of conformity AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D Is IATF certification required when customer doesn't require it? IATF 16949 - Automotive Quality Systems Standard 19
Kevin Walters IAQG Required Audit Days Needed (Please help) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S Is MDSAP Audit Required? ISO 13485:2016 - Medical Device Quality Management Systems 3
H Required explanation of sub clause 7.2.101.2 (Exception) of IEC 61010-2-020:2006 CE Marking (Conformité Européene) / CB Scheme 5
Ashland78 PPAP required for repair of machine? IATF 16949 - Automotive Quality Systems Standard 5
Y Is preventive action required for each CAPA initiated? ISO 13485:2016 - Medical Device Quality Management Systems 24
B Spreadsheet - Used for complaint investigation - Validation required or not ISO 13485:2016 - Medical Device Quality Management Systems 9
N 8.3.3.3 Special characteristics - Auditor said we are required to create our own, if no customer char. exist. IATF 16949 - Automotive Quality Systems Standard 10
P 9.2.2.2 & 9.2.2.3 Audit Cycle alignment required? IATF 16949 - Automotive Quality Systems Standard 1
M Is complete testing required as per ISO 10993 for materials used in orthopedic implants or is literature review route possible Other Medical Device Related Standards 5
I Are suppliers required to hand over process validation reports? ISO 13485:2016 - Medical Device Quality Management Systems 20
B Is 14971 Annex C checklist now in ISO/TR 24971 required to complete prior to 510k filing? ISO 14971 - Medical Device Risk Management 3
D IEC 60601-1-2: Is EMC immunity testing required for a device without essential performance? IEC 60601 - Medical Electrical Equipment Safety Standards Series 25
V ISO 9001 or ISO 17065 required for an organization issuing 5 star rating certification of digital experience? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
D Is calibration really required? IATF 16949 - Automotive Quality Systems Standard 6
D Filling totes and pails - when is a calibrated scale / flowmeter required in ISO 9001 General Measurement Device and Calibration Topics 4
S Supplier performance required to be reported to supplier? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S Is the Design Service Provider required to be ISO 13485 certified? ISO 13485:2016 - Medical Device Quality Management Systems 13
B What are "appropriate drawings" required for a MDR in 21CFR820? ISO 13485:2016 - Medical Device Quality Management Systems 4
S Record approval- Signatures required ISO 13485:2016 - Medical Device Quality Management Systems 9
M MDSAP required for Device Initial Importer/Distributor into Canada? Other Medical Device Regulations World-Wide 11
I Is SRN required for a contract manufacturer (CE-Marking product)? EU Medical Device Regulations 2
O New GTIN (DI) required? Other US Medical Device Regulations 0
P Is the second factor authentication (2FA) required for external users? Qualification and Validation (including 21 CFR Part 11) 1
validationspec EN 868-5 pdf required. Medical Device and FDA Regulations and Standards News 1
F Uncertainty not Required Measurement Uncertainty (MU) 3
I How to find required testing for a specific device? Other US Medical Device Regulations 3
U Is Initial Importer Status Required if a Medical Device is Manufactured and Sterilized by an OEM in the US Other US Medical Device Regulations 1
S Is it required to complete Internal Audits within one year? ISO 13485:2016 - Medical Device Quality Management Systems 29
D "certified" in ISO 19011, as well as IATF required? IATF 16949 - Automotive Quality Systems Standard 6
M Is validation required when consumables are changed Qualification and Validation (including 21 CFR Part 11) 7
B Is labeling on the device itself required? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
