Is it Time for New Rules for SPC (Statistical Process Control)?
Modernize the SPC Rules?
  • Sure, anything to improve the ability to detect out-of-control conditions
    Votes: 2 13.3%
  • Perhaps, if the new system becomes common in the quality field
    Votes: 0 0.0%
  • No, the current rules work well enough
    Votes: 13 86.7%
  • Total voters
    15
Status
Not open for further replies.
Tim Folkerts
Walter Shewhart introduced control charts 80 years ago, when computers were unheard of and all plotting and searching for out-of-control (OOC) situations had to be done by hand. He was pragmatic in his approach to statistics, creating simple, almost foolproof tests like "1 point beyond the 3 sigma limit". The rules for detecting OOC have gotten a little more sophisticated (e.g. "4 oout of 5 point more that 1 st dev from center line on one side), but they can still be done by a person looking at a paper chart.
In the end, the goal was to detect 1) changes in the mean or 2) changes in variation. Well, in this era, specific tests for these quantities (e.g. T-Tests and F-Tests) can be cranked out be computer in no time. Why not switch over to rules that are based on specific statistical tests?
PROS of the statistical approach:
* more accurately detects shifts in mean or st. dev.
* easy to adjust the sensitivity. If you wanted fewer false positives, you adjust a parameter in the program, rather that trying to create rules like "3 of 5 points more than 2 sigma from the center" to replace than the standard "2 of 3 points more than 2 sigma from the center".
* It solves the question asked recently about handling points that are on the 1,2, or 3 sigma lines. Before it made a big difference whether the point was 2.99 sigma or 3.01 sigma from the center; now it is a small change in a calculation.
* currently, many people skip many of the tests, so they miss opportunities to detect smaller shifts.
CONS:
* Requires a computer. The calculations involved would be completely impractical without specialized software (although even Excel could be set up to do the testing). On the other hand, I doubt many people calculate control limits by hand even now, so the requirement of a computer & special software is not really new.
* The rules are not easily explained to non-statisticians, so it is less intuitive. You can't draw a dot on a chart and check by eye for OOC rules.
* The system is not familiar, so it might be hard to convince customers (or even your own boss) to use something new.
To me (being mathematically inclined) the greater accuracy & flexibility of the more mathematical system outweigh the simplicity of the more intuitive system. A quick look using Excel and random data indicates that the new system is indeed better at spotting OOC conditions.
Any other thoughts??? Would it be valuable to have a system that is better at finding OOC situations, or is the current system good enough?
Tim F
I voted in favor of the "old" system, which in fact includes any sort of statistical tools one might choose to use. The idea behind statistical analysis in manufacturing is the same as in any other endeavor; statistics is used to prove a point or validate a hypothesis, and that proof* or validation should abide by Occam's Razor--one should not increase, beyond what's necessary, the number of entities required to explain something. Another way of expressing the Razor is that the simplest answer is almost always the best one. If that means that Shewhart control charts are appropriate, then they should be used, and if some other method is more amenable to the desired result, no one should feel obligated to use Shewhart charts.
*"Proof" is used here in the sense of "preponderance of evidence," and not "irrefutable fact."
Statistical Steven
Statistician
Ahhh...but SPC is not about showing that two means or variances are different as would a t-test or F-test. It was established to look at "trends" in the data. SPC is more about sampling statistics than any other statistics. What Shewhart did was proposed a method to ask, does this data point come from the "population" of possible observations.
If you look at using either a z-test or t-test, your limits will be much wider than control limits.
Having said that, I do not think that all the rules for determining out of control should be implemented simultaneously. I used 3 basic rules.
1. Out of 3S limits
2. A run of 8 points above or below the center line
3. A run of eight points that are either all increasing or all decreasing.
Just my $0.02
Wes Bucey
Prophet of Profit
I have to think about my response to the poll a little bit more, but I have an observation.
We all laugh or at least smirk when we hear the term "close enough for government work." The reason for the smirk is that we know an overwhelming majority of decisions are made on the basis of
"good enough"
versus
"as close to the perfect ideal as possible."
Similarly, the overwhelming majority of control charts are maintained to keep the system "good enough." Very few organizations have a systemic system of initiating DOE unless some crisis triggers a quest for a better way.
Some (many?) folks faced with instant feedback of data find themselves rerunning a Funnel Experiment where they continually tinker with setups and target points because they ignore the concept of individual variation of a system and try to narrow the variation beyond the ability of the system to comply. (Try as one might, it is next to impossible to adjust a 50 year old Brown & Sharpe lathe to hold plus or minus one ten thousandth of an inch (1/10,000) tolerance consistently!)
I tend to agree with Jim (JSW) in letting the existing system muddle along while those with high powered equipment, automatic data collection and computers to analyze and adjust systems go the extra mile (in other words, let the control system fit the equipment and the need, rather than try to upgrade all control charts to "state of the art" statistical glory.)
Yes - SPC was never intended to be a hypothesis test. in fact you lose a lot of insight and accuracy of decision when using the hypothesis test approach over the traditional SPC approach.
I have founf that there is far more power in looking at the data in the trend line than can come from any statistics that might be applied to the data.
Brian Myers
Right tools int he right hands...
To me SPC is "statistics for the shop floor". In other words, give the operators, maintainence, and supervisors a tool they can use to help the overloaded QA/QC folks keep those machines in control. To be this tool, SPC is intentionally easy to explain, easy to implement, and easy to interpret.
Leave the fancy statistical stuff to the QA/QC folks.
Besides, Deming disliked Anova, t-tests, confidence intervals, and other statistical techniques because they "provide no basis for prediction and because they bury the information contained in the order of production".:yes:
I have seen this in action. The t-tests and confidence intervals showed nothing useful, but the raw data (run data) showed very clear trends and indicated the source of the issue very clearly. I learned from experience to carefully monitor how data is filtered and grouped. Anytime you distill a large amount of data down to a few "key" statistics, you run a great risk of losing valuable information.
SPC for manufacturing, Higher Statistical Methods for Design. QA/QC has to be able to "play" in both worlds equally adroitly.
Brian
Tim Folkerts
JSW05 said:
...Occam's Razor--one should not increase, beyond what's necessary, the number of entities required to explain something. Another way of expressing the Razor is that the simplest answer is almost always the best one. If that means that Shewhart control charts are appropriate, then they should be used, and if some other method is more amenable to the desired result, no one should feel obligated to use Shewhart charts.
I hadn't thought about it from the perspective of Occam's Razor, but that is a good insight.
You suggest that we are free to choose alternative to Shewhart's rules, but I would argue that there are really no alternatives at the moment. What SPC system is there that doesn't start with "1 pt outside 3 sigma"?
Besides, are the current rules really that simple? There are 8 rules listed in Minitab and I'm sure there are others. The rules themselves seem arbitrary and the choice of which rules people actually use is often arbitrary. Lots of arbitrary rules is the antithesis of Occam's Razor.
But aren't the current rules simply crude hypothesis tests anyway?
  • 1 pt +/- 3 sigma
    = test for a large shift in mean
  • 2 of 3 pts +/- 2 sigma
    = test for a moderate shift in mean, or a shift in sigma
  • 8 pts all on one side
    = test for small shift in mean
  • 15 pts within +/- sigma
    = test for decreases in sigma
And all the rules suffer from the problem that no one really knows what sort of confidence the rules provide with detecting what sort of changes.
I have found that there is far more power in looking at the data in the trend line than can come from any statistics that might be applied to the data.
But as Steve Prevette has indicated (particularly in his "Lies, ****ed Lies, and Statistics), it it easy to misinterpret data. Of course you & I would never do that;) , but those less knowledgeable in the ways of statistics might.
But isn't one of the simplest ways to determine if a set of points comes from the same population to perform the tests that tell you if there has been a significant change in either the mean of the standard deviation?
I don't think so. And anyway, control limits are rather arbitrary. Why artificially draw a lines at 1,2,3 sigma? Why not every 0.5 sigma? Or 0.67 sigma? Instead, why not "draw the lines" at some known statistical level like "look for a shift in mean or in sigma that would only occur by random 0.3% of the time"?
The rules I would propose would run something like this. Flag the result of any test that would occur less that 1/1000 times (or a similar small number) for:
  • 1 point (to detect drastic changes)
  • 3 pts with a new mean (to detect large changes)
  • 10 pts with a new mean (to detect medium changes)
  • 30 pts with a new mean (to detect small changes)
  • 3 pts with a new sigma (to detect large changes)
  • 10 pts with a new sigma (to detect medium changes)
  • 30 pts with a new sigma (to detect small changes)
  • 10 pts with a non-zero slope (to detect trends)
Granted, the exact interpretation of probabilities depends on the distribution. Still, there is at least a specific, rational choice in the tests and the interpretation.
Tim Folkerts
What I was suggesting is that we are free to determine the statistical methods that best fit the case at hand, whether that be Shewhart charts and the WECO rules, or some other method. We should also feel free to suggest alternatives to customers who normally expect x-bar/r charts, although I realize that some customers would rather see a well-constructed fudged control chart than have to think about something else.
No, the choice of rule application should be guided by the Razor. We know, for instance, that it's dangerous to apply the rules on top of one another. Far from arbitrary, the rules are based on probability of occurrence, and tell us when to suspect that something might be amiss.
Tim Folkerts
I agree in principle, but is that how most people choose which rules to use? My unsystematic observations are that most people pick a few rules that "seem" right to them. I doubt many people really think about the statistical implications of using particular rules, let alone think about particular combinations.
What I am proposing is basically to bring those probabilities out into the open, and make them more robust. A rule like "2 of 3 pts at least 2 sigma out" is an approximation for a more precise rule. Consider the following sets of three consecutive points on an I-chart or X-bar chart (measured in standard deviations from the center):
  • 2.9, 1.9, 1.9
  • 2.1, 1.9, 1.9
  • 2.1, 2.1, 0.5
I'll bet by any statistical test (and just about everyone's intuition), these are in order of "unusualness", but by SPC rules, only the least "unusual" will trigger the alarm.
Since the computing power is now easily available, why not use a more accurate test? Why be restricted to an oversimplification of the "true" rule?
Tim F
Tim Folkerts
To me, this is probably the biggest reason not to change:agree1:. The current system can be used well enough with minimal train and minimal statistical expertise. For small operations, a fancy system may be overkill, in the same way an expensive robotic system would be overkill for a 3 person machine shop.
I'm trying to get the best of both worlds:yes:. By recalculating t-tests after every new point, my system maintains information about the run order. The information about unusual t-test results is immediately available, just the same way the information from an unusual "8 in a row on the same side" test is available immediately.
Tim F
Status
W How to Set Rules to Review SPC Center Line, UCL and LCL? Statistical Analysis Tools, Techniques and SPC 15
C SPC Chart Run Rules - 7 in a row vs. 8 in a row Statistical Analysis Tools, Techniques and SPC 3
A SPC Rules Question for Moving Range chart Statistical Analysis Tools, Techniques and SPC 9
D What are the accepted standard rules for SPC analysis ?(7 points rising, WECO, etc.) Statistical Analysis Tools, Techniques and SPC 2
R Assignable causes rules clarification Statistical Analysis Tools, Techniques and SPC 4
O Release of Sanctioned Interpretations (SIs) related to Rules 5th Edition and Sanctioned Interpretations related to IATF 16949:2016 IATF 16949 - Automotive Quality Systems Standard 0
G IATF Rules for COVID 5th revision - Re-certification audit timing IATF 16949 - Automotive Quality Systems Standard 3
T IATF Rules for sharing production space with another company IATF 16949 - Automotive Quality Systems Standard 10
M Indian Medical Device Rules - Manufacturing and Wholesale Lic. Required? Other Medical Device Regulations World-Wide 12
S Is QMS like a set of rules and regulations that a company follows? ISO 13485:2016 - Medical Device Quality Management Systems 10
D Rules for Paper Forms outside of an eQMS - 3 Questions (ISO 13485) Document Control Systems, Procedures, Forms and Templates 9
S Drugs and Cosmetics Rules - India Other Medical Device Regulations World-Wide 0
G Do HIPAA Rules Apply to a 3rd Party Logistics Shipper? Other US Medical Device Regulations 2
shimonv Rigid rules for handling supplier audit findings ISO 13485:2016 - Medical Device Quality Management Systems 11
K EU MDR Rule 11 - Does the 'Risk logic' used in Rule 11 conflict with that used in the other rules? EU Medical Device Regulations 2
N Is there a standard / rules pertaining to eating in medical device manufacturing area? Manufacturing and Related Processes 5
M Informational TGA – Advertising health products: Rules about safety claims in advertising Medical Device and FDA Regulations and Standards News 0
D Volkswagen Complaints Management Rules Customer and Company Specific Requirements 0
M Informational US FSA – Surgical staples – Guidance and proposed rules Medical Device and FDA Regulations and Standards News 0
M Informational MDCG 2019-2 Guidance on application of UDI rules to device-part of products referred to in Article 1(8), 1(9) and 1(10) of Regulation 745/2017 Medical Device and FDA Regulations and Standards News 0
M Medical Device News EU – MDCG 2019-1 MDCG guiding principles for issuing entities rules on Basic UDI-DI Medical Device and FDA Regulations and Standards News 0
M Why have IATF rules required the CBs to audit remote supporting functions at first? IATF 16949 - Automotive Quality Systems Standard 11
T Informational Family or Baseline PFMEA Rules FMEA and Control Plans 22
A Where are the rules for when a repeat minor nonconformance becomes a major? IATF 16949 - Automotive Quality Systems Standard 36
M Medical Device News FDA Withdrawals Two Proposed Rules Other US Medical Device Regulations 0
R How to keep track of all FDA rules and regulations for medical device companies 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
C What are rules to notify customers if IATF cert is put on hold? IATF 16949 - Automotive Quality Systems Standard 2
L What are the rules on significance of digits in numbers in IEC/ISO standards? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
J Rules associated with introducing new QMS processes IATF 16949 - Automotive Quality Systems Standard 1
R IATF 16949 certification rules IATF 16949 - Automotive Quality Systems Standard 5
K Rules or guidelines for quoting FDA announcements and such? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
M INDIA - GSR 78 (E) - New Medical Device Rules - 2017 Other Medical Device Regulations World-Wide 6
L Hypothesis Testing + Thumb Rules Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
L Percentage Thumb Rules for Quality Costs Misc. Quality Assurance and Business Systems Related Topics 1
A EASA Easy Access Rules for Continuing Airworthiness - June 2017 EASA and JAA Aviation Standards and Requirements 0
Sidney Vianna IATF 16949 Areas of Impact - Rules 5th Edition Document (February 2017) IATF 16949 - Automotive Quality Systems Standard 0
Uriel Alejandro Including "Internal Rules" as Controlled Documents in a QMS Document Control Systems, Procedures, Forms and Templates 7
Marc Rules for Posting in the Paid Consulting, Training and Services Forum Paid Consulting, Training and Services 3
M I am looking for the text of the copyright 'rules' for AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
F Rules to respect when changing from Certification Body ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Anerol C IATF or ISO TS 16949 rules about Scope of QMS IATF 16949 - Automotive Quality Systems Standard 7
Crimpshrine13 Rules of achieving and maintaining IATF recognition - Determining audit days IATF 16949 - Automotive Quality Systems Standard 2
Ajit Basrur New Medical Device and IVD Registration Rules - Pakistan Other Medical Device Regulations World-Wide 5
A PUWER (Provision and Use of Work Equipment Regulations) and old machines (UK rules) Occupational Health & Safety Management Standards 4
M Translating and Rotating Rules when programming or measuring with a CMM Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
M Are there specific rules regarding ISO 13485 and R&D? ISO 13485:2016 - Medical Device Quality Management Systems 4
Mikey324 Questionable Audit Findings after Rules 4th Edition Release IATF 16949 - Automotive Quality Systems Standard 4
M ISO/TS 16949 Rules about Commodities IATF 16949 - Automotive Quality Systems Standard 4
N IATF Appeals on ISO/TS16949 Rules - 4th Ed. - Removal of Site Extensions IATF 16949 - Automotive Quality Systems Standard 2
M Scope content of TS 16949 certificate under Rules 4 IATF 16949 - Automotive Quality Systems Standard 6
