Is Kappa Study Required during PPAP (Production Part Approval Process)?
Ramani Parthasarathy
Kappa study is time consuming as far as sample selection is concerned,can anybody let me know if this study is required during PPAP.
thanks in advance
Ramani.Parthasarathy
I don't know if it's required but I do know that is useful. It is worth the time to understand your measurement error including the error of inspectors or test equipment that make categorical judgments.
P
Pazuzu - 2009
I've gone through the 4th edition of the PPAP manual and nowhere is the Kappa study mentioned. Although it is a good idea to find where the comparisons are...no it is not required.
CAVEAT ALERT! There are many other Covers in here with vastly superior PPAP knowledge that may state otherwise. If so I'd be interested in knowing about it.
thanks in advance
Kappa isn't required explicitly, but some form of attributes gage study is required for any attributes gages cited on your control plan. Check with your customer and find out what's expected.
DDaenen1
First of all, what do you mean with "kappa-study"? Do you refer to the Measurement System Analysis Study (PPAP item 8) or to the Initial Process Study (PPAP item 11).
I don't know which PPAP Manuals some of you are reading, but both items need to be fullfilled to get full PPAP approval. A Gage R is mandatory for attributive measuring equipment, Gage R&R is required for variable measurement equipment. As far as sample selection goes for the MSA, you should randomly take a number of parts from your production line, no proper selection need to be done apart from ensuring they are OK-parts. The study will show if the variation is to be found in your products or in your operators.
Without proper GR&R, you cannot do a proper Initial process study anyways.
As far as the initial process study goes, this needs to be completed for all significant characteristics that have been identified on your product/process. If you do not have any SC's , than i would wonder if a proper component review was conducted.
If we are talking initial process study, there should also be no "sample selection". The standard requirement is that you collect a significant amount of OK-parts (>50) from your [email protected] and use these to conduct the the capability study.
So basically, yes, according to PPAP 4th edition, both items need to be fullfilled.
Hope this helps,
Dominique
roland_lu
I finally got out of automotive industry half year ago. Hopefully I would not have to return to it.
Sample selection is very much troublesome for attribute gaue study. It is easy to make "black/white" calls when the samples are white or black, and the study is more concerned about how the measurement system makes calls on the "grey". So the boundary samples are needed, quite often you will have to make them on purpose (not taking them from the normal production process, that is for sure). When you are doing PPAP for Ford, and you have new attribute gauges, for instance, you would need to have 50 samples ( :mg:), 3 appraisers to make 3 calls on each sample, you would really appreciate this kind of paper exercises.:mad:
I hope people (customers) understand what they are talking about.
Good Luck!
anandqgp
Involvement Access - Posts
Dear friend
I dont think you should be confused so much. Is the aim to comply with a documentation requirement or the aim is to retain the customer for a long time. Well if the aim is retain your customer for ever, then you should do every thing right.
Talking about Kappa. If you are not making any attribute studies, then KAPPA is not required since for variation study you need only GRR studies. The moment your variation becomes Operator dependent then Kappa comes in.
Have you ever thought about what MSA studies are and what its purpose is. Its purpose is simply to find out the Variation spread consumed in the process variation. You are aware about the limit i.e., 0-30%. The more the area it occupies in the process spread, the worse the impression the customer has about your company. Perhaps this could be another case Type I error.
This termite like "Spread Absorption" by the measurement system of the process variation needs to be reduced or eliminated. This termite consists of Operator variation and/or Gage variation.
So if you are interested to eliminate the TERMITE hurting the process and your business, you will welcome doing KAPPA every time there is need for doing so.
I hope your question is answered. If not,you may come back since all such forums are both-way learning processes.:nopity:
HS Anand
terranceyu
Hello guys, I am newly joined in QA Engineering filed, and actually completed the attribute GRR study based on the thumb pressure. However it has variance to every operators. When the inspectors tested the samples developed by myself and another engineer, it seems to have a lot of unmatchness. The same condition also applied to the inspectors who possessed on hand knowledge for almost 3 years. Is it mean they are not qualified, or the sample standard is simply too tight and not reasonable. I think it is reasonable tough..:cool:
And when comes to kappa study at page 2, how am I going to proceed, since we have three appraisers at page 1, but only two appraisers column (A and B) to filled? I attached the file for your better understanding.
I hope my questions could be answered.
Talk to me.
Regards,
Terrance
First, you need to review your control plan to see if you have any attribute test and monitoring to be done. If it is part of your quality control plan, then next ask the customer if he requires Attribute GR&R to be performed and by which method should you use and report it.
Kappa is only one of a couple Attribute GR&R methods.
R Cohen's Kappa Study - is it required during PPAP? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A Inspection Capability Study (Kappa Analysis / Attribute R&R) as Certification Req't Training - Internal, External, Online and Distance Learning 7
A Need help with a Kappa Study (MSA) - Reviewing x-ray Images Six Sigma 11
J Ordinal Data Gage Study - Kappa scores vs. Kendell?s Coefficient Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J What kappa value to use for Gage R+R (Gage R&R) study with > 10 parts? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
C Attribute MSA Study using Kappa - Why Kappa value is low Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
J How to do attribute data GR&R (Gage R&R)? Do a Kappa study or follow the MSA book? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
C KAPPA index Reference Value for Visual inspection IATF 16949 - Automotive Quality Systems Standard 1
R Visual Attribute Inspector Capability and KAPPA Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
C MSA-4 Attribute Kappa Template - Verification Check Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
J Attribute GRR (Gage R&R) - How to get Kappa Software Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
K The 'Cohen's kappa' method to evaluate degree of consensus between visual operator Six Sigma 9
S Attribute GRR - Cross tab - Kappa - What does "Expected Count" mean? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Marc MSA Spreadsheet in Spanish - Cohen kappa method (circa 2006) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A Measurement System Analysis - Attribute GRR - How kappa is calculated Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J Attribute R&R assessment results vs. Kappa = different conclusions Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
V To formulate an Excel .xls worksheet for MSA on attribute data using Kappa Analysis Excel .xls Spreadsheet Templates and Tools 14
J KAPPA Statistic - Comparing appraisers ratings to a known standard IATF 16949 - Automotive Quality Systems Standard 8
M ASQ certification study material Professional Certifications and Degrees 1
I Clinical study suppliers (service providers) -- extent of control ISO 13485:2016 - Medical Device Quality Management Systems 4
P Type of MSA study according to measurement equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J Using real time shelf life study as accelerated ISO 13485:2016 - Medical Device Quality Management Systems 1
T Gage R&R study - Ordinal data Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
F Using non-randomized clinical study for change in existing 510(k) device? US Food and Drug Administration (FDA) 1
E Which regulatory framework for an app-based study for research purposes? EU Medical Device Regulations 1
M Registry study in Europe CE Marking (Conformité Européene) / CB Scheme 1
P 21 CFR 58 GLP Periodic Study Phase Inspection Report Other US Medical Device Regulations 0
Aymaneh Clinical study CE Marking (Conformité Européene) / CB Scheme 1
S Equivalency study - Comparing 2 similar equipments Reliability Analysis - Predictions, Testing and Standards 1
M Early feasibility study V&V requirements Design and Development of Products and Processes 2
D Regulatory Affairs Certification (RAC) Devices Exam - Autumn 2022 study Professional Certifications and Degrees 2
M RAPS RAC Device - Looking for resources / prep materials & study group Professional Certifications and Degrees 7
V MSA - Using a R&R study for a Tape Measure Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
P Brexit Germany - Import Medical Device For Clinical Study EU Medical Device Regulations 0
M EU MDR - Retrospective Study for expanding indications of a legacy device EU Medical Device Regulations 0
Miner Reported content: Post in thread 'Form of real time study for establish shelf time' Document Control Systems, Procedures, Forms and Templates 1
A Form of real time study for establish shelf time Reliability Analysis - Predictions, Testing and Standards 4
S Capability Study for Leak Tester Capability, Accuracy and Stability - Processes, Machines, etc. 9
A % STUDY VARIATION VS. % TOLERANCE Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 31
A IATF MSA study Type 1 General Measurement Device and Calibration Topics 7
M Type 1 Gage r study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A Mistakes in the CQE Study Guide Misc. Quality Assurance and Business Systems Related Topics 5
Nihls MSA Study Type 2 (special conditions ) IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
D What are the acceptance criteria/requirements for Stability Study? General Measurement Device and Calibration Topics 7
S 95% UCL - Attaching an excel for recovery study Statistical Analysis Tools, Techniques and SPC 0
Nihls MSA Study Type 1 (CMM) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D Low risk IVD study in the UK, do I need MHRA approval? UK Medical Device Regulations 1
M Lean: Conducting Capacity Study, calculating Cycle times on laser cutting machines Lean in Manufacturing and Service Industries 2
