Is MSA needed once or once a year for Verniers, Micrometers, Gauges, etc?
P
philip1989
i have a question. is it need to do msa for all intruments once in a year?? or one time for each instrument? (vernier, micrometer diff type of gauges??
plz clarify my doubts..
Welcome to the Cove. :bigwave:
MSA should have to be redone only if something significant changes. For example, if you're using a caliper to measure a given part feature and change to using something else, the something else should be qualified for that particular use. You might also want to do it again if you have questions about operators doing measurements properly. In general though, MSA is not something that needs to be done on a periodic basis.
qusys
Agree with Jim.
I would only like to add that if your customer require MSA each year for the tools/equipment on your control plan ,it becomes a requirment and you shall comply with it.
it is clearly a cost for the organization that impact the price of your product you provide.
Hope this helps too:bigwave:
sitapaty
Agree with Jim.
A wellinformed customer has no basis to specify repeat of MSA when no significant change is there in the process inputs.
-Sitapaty
bobdoering
Stop X-bar/R Madness!!
Re: Is MSA needed once or once a year for Verniers, Micrometers, Gages, etc?
I would only like to add that if your customer require MSA each year for the tools/equipment on your control plan, it becomes a requirement and you shall comply with it.
Here is how this works. The is no time function to Gage R&R. I hate to call it MSA, because MSA is actually all functions of gage verification, such as linearity bias, stability, etc. - some of which are time functions and do have periodic requirements dealt with in calibration.
Gage R&R answers the question "Is this the right gage for the job?" Logically, you should only have to answer that question once. But, if you did not capture the operator variation adequately by not using a wide enough sample of skill levels, you may have to redo it if the skill levels of the operators drops. If you change the gage, you may have to redo it if the relation of the gage to the operator or part changes. Significant changes in the gage system (operator, part, gage, environment) would initate a need for redoing the gage R&R.
There may be two reasons why a customer may require annual gage R&R: 1) they are ignorant to the point of gage R&R and rubber stamp useless requirements to cover up their fear of their ignorance, OR 2) they know their suppliers will mess with the gage and not redo the gage R&R as the should, so to make sure they didn't "break it" when they thought they were "fixing it" they try to catch these problems by forcing periodic gage R&R. Many customer requirements are generated by suppliers messing up - so they stuff more and more requirements on the supplier to try to catch them and keep them from burning the customer again. So, the true basis for the requirement may get lost.
qusys
-Sitapaty
Sometimes they can could also ask even if there was no change and setting MSA for the equipment in the control plan each year .
This could be a customer requirement and you have the chance to raise the price of your product upon agreement .:bigwave:
X
xxyuan
Does someone can help give more examples of significant change?
I only think two things: repaired equipment/Relocation equipment.
qusys
A suggestion could be in the case the equipment was not actually used into production for long time ( I mean 1 year as an example).:bigwave:
optomist1 Is a MSA (Measurement System Analysis) needed on these two tests Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
S Cross Tabulation in Attribute MSA - Help Needed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
Stijloor MSA Trainer/Consultant Needed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
O How many bad parts needed for Attribute MSA? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A Needed: MSA (Measurement Systems Analysis) Terms translated to Spanish Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
G MSA Manual Bias Calculation - Why is the d2* correction factor needed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
Nihls When the MSA results show no operator influence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Nihls MSA Study Type 1 (CMM) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 8
P MSA for titration Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
P MSA - what exactly mean "system" and master sample Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
P MSA study for visual system with artifical inteligence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D MSA strategy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
K Updated MSA with the Annual PPAP validations APQP and PPAP 8
E MSA for Push and Pull test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
6 MSA for Calculated Clearance Dimension Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
G MSA check list to audit IATF 16949 - Automotive Quality Systems Standard 10
R MSA for ATE (Automatic Test Equipment Embedded Software) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
Bev D MSA Tools Misc. Quality Assurance and Business Systems Related Topics 3
R MSA studies for Heat Treatment Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
C Industrial scales and MSA (IATF 16949 requirement 7.1.5.1.1) IATF 16949 - Automotive Quality Systems Standard 30
M Test method validation - Is MSA (MSA1, MSA2, MSA3 and linearity) a good solution? Medical Device and FDA Regulations and Standards News 1
A MSA results differences - Supplier results vs. My results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R Preliminary MSA and Sockets' correlation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
I MSA requirement for 5 Micrometers + CP changes need customer approval? IATF 16949 - Automotive Quality Systems Standard 2
Bev D MSA Misc. Quality Assurance and Business Systems Related Topics 46
N MSA Study for a Leak Testing Device Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
Prashant G MSA Study - AS 9100 and and our customer want us to do MSA study for their parts dimension Reliability Analysis - Predictions, Testing and Standards 4
D Compression Spring Force MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
E MSA Study on MTS dynamic rate measurements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A The FILE recommended by AIAG MSA 4ed for LINEARITY Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
S IATF 16949 Audit MSA IATF 16949 - Automotive Quality Systems Standard 10
C Do Calibration Reference Standards require an MSA study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A MSA When an Instrument Measures More than One Parameter Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
G MSA Type 1 - Cg and Cgk ranges Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
O MSA Study for a steel ruler Manufacturing and Related Processes 6
P IATF 16949 MSA Studies for CMM machines IATF 16949 - Automotive Quality Systems Standard 3
B 7.1.5.1.1 MSA for inline dimension vision inspection equipment IATF 16949 - Automotive Quality Systems Standard 5
G MSA on a Counting System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C AIAG's IATF 16949 section 7.1.5.1.1 - Torque MSA Requirement Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
S IATF 16949 7.1.5.1.1 Measurement System Analysis (MSA - Die casting) IATF 16949 - Automotive Quality Systems Standard 5
