Is MSA useful to prove a Measurement System after Relocation?
AgnieszkaSz
I've been with quality for several years now, but by knowledge of MSA is vague at best :eek:.
I've been assigned a task - a CMM and measuring fixture are moved from overseas location to us and we have to prove that the measurements of the parts will not suffer. I know that CMM must be installed and calibrated, but am I right in my assumption that MSA for this fixture will provide evidence that CMM plus fixture can be commissioned?
If so, should I design MSA for two operators - before and after relocation? Or four? The fixture is designed to hold 80 pieces, so I assume that the only sound decision is to make MSA on 80 samples.
Can anybody comment?
JAltmann
I assume you'll be having the machine calibrated to previous spec's after the move.
The GR&R of the fixture is not necessarily a bad idea, but I would probably be more concerned with how well it matches the GR&R done prior to moving the machine. Example if the previous GR&R = 5% and now your at 19% some may say it is good, but we obviously see a difference.
It's a good idea to perform a basic reproducibility study.
yes 80 parts is OK although 30 woul also work. The ideal would be for the same 80 pieces to be measured twice before the move and twice after the move/calibration.
you can then directly assess if the repeatability was effected adn if there is a bias due to the move or calibration.
I would NOT use the standard Gage R&R as it will be only vaguely informative. I would use the Youden plot and simply calculate the measurement error for both studies and compare (SD_error = R-bar/1.128)
I woudl plot the two repeatability studies on their own Youden plots to comapre repeatability, then plot the first reading for each study on a thrid Youden plot to see if any bias is present. simple, easy, elegant.
R MSA for ATE (Automatic Test Equipment) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Bev D MSA Tools Misc. Quality Assurance and Business Systems Related Topics 3
R MSA studies for Heat Treatment Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
C Industrial scales and MSA (IATF 16949 requirement 7.1.5.1.1) IATF 16949 - Automotive Quality Systems Standard 30
M Test method validation - Is MSA (MSA1, MSA2, MSA3 and linearity) a good solution? Medical Device and FDA Regulations and Standards News 1
A MSA results differences - Supplier results vs. My results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R Preliminary MSA and Sockets' correlation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
I MSA requirement for 5 Micrometers + CP changes need customer approval? IATF 16949 - Automotive Quality Systems Standard 2
Bev D MSA Misc. Quality Assurance and Business Systems Related Topics 46
N MSA Study for a Leak Testing Device Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
Prashant G MSA Study - AS 9100 and and our customer want us to do MSA study for their parts dimension Reliability Analysis - Predictions, Testing and Standards 4
D Compression Spring Force MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
E MSA Study on MTS dynamic rate measurements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A The FILE recommended by AIAG MSA 4ed for LINEARITY Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
S IATF 16949 Audit MSA IATF 16949 - Automotive Quality Systems Standard 10
C Do Calibration Reference Standards require an MSA study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A MSA When an Instrument Measures More than One Parameter Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
G MSA Type 1 - Cg and Cgk ranges Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
O MSA Study for a steel ruler Manufacturing and Related Processes 6
P IATF 16949 MSA Studies for CMM machines IATF 16949 - Automotive Quality Systems Standard 3
B 7.1.5.1.1 MSA for inline dimension vision inspection equipment IATF 16949 - Automotive Quality Systems Standard 5
G MSA on a Counting System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C AIAG's IATF 16949 section 7.1.5.1.1 - Torque MSA Requirement Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
S IATF 16949 7.1.5.1.1 Measurement System Analysis (MSA - Die casting) IATF 16949 - Automotive Quality Systems Standard 5
J MSA on Part Specific Attribute Fixtures Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Test Method Validation or MSA for Batch Manufacturing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S MSA on a process using different fixtures Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Camera Vision System Measurement System Analysis (MSA) Reliability Analysis - Predictions, Testing and Standards 3
D Cp/Cpk on Gages for MSA (vs. Cg/Cgk) Capability, Accuracy and Stability - Processes, Machines, etc. 21
L Number of Distinct Categories" or NDC Calculation in MSA Studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
Q Doing an MSA on a Climatic Chamber Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
L IATF 16949 7.1.5.1.1 Measurement System Analysis (MSA) - Visual Inspection IATF 16949 - Automotive Quality Systems Standard 14
C MSA for Non Manufacturing - Design Validation, Characterization and Qualification Lab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
C PPAP Rejection for "MSA-GR&R are not using the latest AIAG format" APQP and PPAP 9
C MSA (Measurement System Analysis) - Instrument Selection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
C MSA (Measurement System Analysis) - Dimension Selection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
P Frequency and Sample Size Requirements for an MSA Studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
A Automated Measurement Machine MSA - Small Parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Crimpshrine13 MSA for a part Automated and part Manual Inspection Machine IATF 16949 - Automotive Quality Systems Standard 7
S MSA (Measurement System Analysis) - Process Tolerances Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
B How to do an MSA on an Automated Torque / Angle System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B How to perform a MSA - GRR (Gage R&R) A&R/ANOVA Vs GUM/VDA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Gage R&R MSA - Variation, Tolerance, Variance by different methods IATF 16949 - Automotive Quality Systems Standard 23
I MSA related questions Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
MSA
