Is NDC needed for gage used for ATE? Automated Test Equipment IC Testing
Y
yanmao
Hi, I am handling ATE IC Tesing in my company. and we are using %Grr by Tolerance (instead of TV). As the objective of the ATE is to screen-out failures.
MSA 3rd Edition introduced NDC in MSA. from the forum threads, noticed that the NDC do relelated to the %Grr (using TV).
Thus, I am wondering if NDC really needed for my case?
if do, how can I correlate my %Grr to the NDC?
thanks
thanks
You are correct. ndc is another measure that relates the measurement variation to the process variation similar to %GRR (TV).
In your situation, the P/T Ratio (please note that %GRR by Tolerance is not the correct term since MSA 3rd ed. was issued) appears to be the correct choice.
Y
yanmao
Hi Miner,
Thanks.
Can I say if we use %P/T in our MSA, we do not need to calculate NDC?
rgds
yanmao
The two measures evaluate different aspects of the gage, and are not mutually exclusive.
P/T Ratio measures the suitability of the gage or test equipment to make pass/fail decisions to a specification.
%GRR and ndc measure the suitability of the gage for process control, capability studies, or statistical studies such as DOE, etc.
Since the same gage may be used for both purposes, all measures may be appropriate.
In your situation, you stated that the gage is only used to make pass/fail decisions to specification. This makes P/T Ratio the appropriate measure. Since the gage is not used for process control or statistical studies, %GRR and ndc are not appropriate measures.
jeffrey_Chang
Re: Is NDC needed for gage used for ATE? ATE IC Tesing
Since the gage is only for pass/fail decisions, wouldn't it be more appropriate in this case to do an attribute study?
:2cents:
:2cents:
No. An Attribute study is designed for a gage such as a Go/No Go gage that can only make a Pass/Fail decision on a single tolerance (e.g., the USL OR the LSL).
While the gage in the earlier post was being used to make a Accept/Reject decisions. It does provide variable data; measures against both the USL/LSL limits and provides info on where the product is within (or out) of specification.
A statisitical study that uses variable data is more powerful than an attribute study. It also provides information on where the variation originates. That is, the problem may be caused by for Reproducibility or Repeatability.
J Question on very low NDC number with tolerable GRR ratio's Capability, Accuracy and Stability - Processes, Machines, etc. 7
C Acceptable NDC for %GR&R part inspection to Tolerance (%Tolerance) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
bobdoering "nds" or Number of Discriminate Samples - the Necessary Tool to Work With "ndc"! Imported Legacy Blogs 0
L Number of Distinct Categories" or NDC Calculation in MSA Studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
J Is a ndc less than five is also acceptable? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
R Count NDC from Graphik Sample Range vs R chart Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
B Process Control - Selecting Parts - NDC & Study Variation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Capability Study => Check %Study Variance and NDC? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
B NDC - Gauge R&R Studies with results where NDC = 1 or 0 Manufacturing and Related Processes 1
Y Poor Gage R&R Results - High R&R result and poor ndc value Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B Help with NDC (Number of Distinct Categories) Please Six Sigma 2
R ndc=0 and GRR=14% ??? Interpretation - basic question Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
S Using Range/Tolerance to Guesstimate NDC or % SV? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
C Conclusions from weird GR&R (Gage R&R) Results - 9 of 12 points have NDC of 1 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
M MSA Manual asks for NDC higher than 5 - NDC (number of distinct categories) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J Impossible to achieve NDC (Number of Distinct Categories) greater than 2 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 28
T Gage R&R Sheet Formula error?! NDC less than 4 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
V Can Anyone Give a Simple Explanation on ndc (number of distinct categories)? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J %Study %Tolerance NDC - R&R Criteria Acceptability when the Tolerance is used Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D Gage R&R %Tolerance NDC Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
C Minor NC - NDC of 0.4 yet the system had been accepted with no investigation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
B NDC relates which type of MSA Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 16
M Minitab number of distinct category (ndc) problems Using Minitab Software 4
S Ndc less than 5 (purchased part) - Auditor suggest I get waiver from customer Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
S The assessment of ndc figures in MSA studies. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S What is NDC (Number of Distinct Categories)? MSA 3rd Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
M Interpreting my R+R chart - NDC's and Out of Control Limits Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C Can someone clarify "Resolution", "Discrimination" and "ndc"? General Measurement Device and Calibration Topics 4
N Average range of measurement system NDC number Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
C Tolerance vs. Part to Part - Is it ndc? When using % of tolerance everything is fine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
K During Gage R&R, is calculation of ndc value required? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 24
G Gage R&R derivation with respect to ndc - Lessons Learned Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
G Please clarify the Rule of 10 to 1 - AND - What is the ndc number? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 66
M Calculation of ndc is 1.41PV/GRR - Origin of this coefficient? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
A Number of distinct categories (NDC) - Non ferrous metal industry Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
D Resolution, Discrimination, NDC and the Tower of Babel in Metrology General Measurement Device and Calibration Topics 5
S Number of Distinct Data Categories - NDC - AIAG's MSA Manual 3rd edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
C Discrimination - Use ndc to analyse the discrimination power? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Y NDC (Number of Distinct Categories) - Long Gage R&R Study in MSA 3rd Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 76
D Number of Distinct Data Categories:nDC: Where does the constant 1.41 come from? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
A Document Review and Document Approval --- 2 Signatures needed acc. §820.40? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
E Calibration Records needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M Advice needed for SEH Compliance Software and ISNETWord Compatabiliy Occupational Health & Safety Management Standards 2
R Advice needed: Shall I report my not complying company to NB / competent Authority (Europe) EU Medical Device Regulations 6
John C. Abnet ISO 9001 4.4.1 "...shall determine the processes needed..." ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 72
S HIPAA-compliant monitoring software (advice needed) Hospitals, Clinics & other Health Care Providers 1
C SOP Template needed for ISO 13485 6.3 Infrastructure ISO 13485:2016 - Medical Device Quality Management Systems 9
H AS9100 Checklist for Internal Audit needed AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S California Cleaning Product Right to Know Act - Product Label advice needed Miscellaneous Environmental Standards and EMS Related Discussions 1
