Is NIST traceability required if a Refractometer calibration is done in-house?
I have a refractometer which we use for measuring the quench tank solution in our Forging process.
We measure forging hardness which is the quality check on the forging however we also measure the quench solution % with the refractometer.
The refractometer is scheduled for a yearly calibration where it is sent out to a calibration lab, but I want to bring this internal and have the calibration done in house.
We are ISO 9001 certified and this is a process check not a quality check.
Considering ISO 9001 and the process, do I need the refractometer to be NIST trace-able?
Thanks for reading and replying!
Jen
:magic:
Ajit Basrur
Re: If NIST traceability required if Refractometer calibration is done inhouse ?
All calibrations should have traceability to NIST even if the calibration is done inhouse.
Considering ISO 9001 and the process, do I need the refractometer to be NIST trace-able? :
Why do it, if it's NOT a quality check? What are you doing with the measurement data? If it's the equivalent of sticking your finger under a tap to test how cold/hot the water is then it probably doesn't need a calibration - if you are relying on the hardness value achieved (ultimately) to show "quality". If you can correlate the bath temp to effectively achieving hardness, then it SHOULD be a formal check and, hence defined as a quality activity for process control.
Jen Kirley
Quality and Auditing Expert
Aside from 7.5.1 asking us to carry out production under controlled conditions, if your instrument is used to help keep a process in control do you still want to have faith in the instrument's readings?
:thanx:
I will purchase NIST refractometer calibration standards. This way I can do calibration in house.
Thanks,
Jen
:thanx:
Thanks,
Jen
Do you have the people with the competency to perform such a calibration. You MAY find that it's still more (cost) effective to have it done by a lab. Alternatively, if you're checking just a few data points why not have a lab simply verify it against a master (comparitor type check). Maybe talk with the lab you use rather than (potentially) open a can of worms which actually ends up costing more than you intended to save...
Jen Kirley
Andy is right that the matter of controlling a quench bath may not be so simple as controlling quenchant and water ratios with a refractometer, calibration for which could be similar to that of pH meters in that it is zeroed when immersed in a standard solution, in this case possibly distilled water. A paper titled IMPORTANCE OF QUENCH BATH MAINTENANCE discusses impurities and their effects on forging quality. Error can also be introduced into the Refractive Index by contamination like salts and scales in the system.
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
G Traceability - Checklist from NIST General Measurement Device and Calibration Topics 4
Raffy ISO 13485 NIST Traceability requirements for calibration of test equipment ISO 13485:2016 - Medical Device Quality Management Systems 3
D Since NIST # can not be used to verify Traceability - What an Auditor should do AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
M Pipette Calibration & ISO 8655 - No NIST Standard(s) Traceability ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S ISO 17025 requirements not enough to prove NIST Traceability? ISO 17025 related Discussions 10
S NIST Traceability Numbers: Dense people, needle in a haystack General Measurement Device and Calibration Topics 16
C Steps to NIST - Measurement Traceability for a Certified Operator Class General Measurement Device and Calibration Topics 4
Jerry Eldred Presentation About NIST Traceability General Measurement Device and Calibration Topics 8
J NIST Traceability: OEM Products - New electronics measurement device General Measurement Device and Calibration Topics 5
R Outside Calibration - Accredited, certified - Is NIST traceability guaranteed? General Measurement Device and Calibration Topics 8
Hershal Traceability - NIST Policy on Traceability, Section II.B.4 General Measurement Device and Calibration Topics 4
S NIST Traceability - Calibrating a grid w/ laser interferonmeters and microscopes General Measurement Device and Calibration Topics 4
Marc NIST Traceability Numbers - Confused Yet? General Measurement Device and Calibration Topics 5
W 17025 and NIST handbook relationship (need advice) ISO 17025 related Discussions 8
F Nist traceable calibration certificates General Measurement Device and Calibration Topics 1
R What is the correct way to refer to NIST? Calibration Frequency (Interval) 4
M NIST is one of the government services shut down General Measurement Device and Calibration Topics 2
G NIST SOP 29 - Assignment of Uncertainty - Question General Measurement Device and Calibration Topics 0
S Reference calibration tools (traceable to NIST) that are not used in production ISO 13485:2016 - Medical Device Quality Management Systems 4
Marc NIST’s Trove of Scientific Instruments and Relics After Work and Weekend Discussion Topics 2
N Anyone working on NIST SP 800-171 (Network and Information Security)? Records and Data - Quality, Legal and Other Evidence 4
D NIST HDBK 44 Table T.3. Class III Tolerance in Divisions Clarification General Measurement Device and Calibration Topics 4
C How to state that Calibration Services & Equipment are Traceable to NIST General Measurement Device and Calibration Topics 5
G Where to get a NIST Traceable Master Glass Refractive Index Sample General Measurement Device and Calibration Topics 5
A Calibration Service Suppliers refuse NIST reference numbers on C of C General Measurement Device and Calibration Topics 21
Marc CMM Training at NIST - August 28-29, 2013 General Measurement Device and Calibration Topics 1
M NIST Standard for CO2 Monitor Calibration General Measurement Device and Calibration Topics 5
N NIST Special Publications and Technical Notes inquiry General Measurement Device and Calibration Topics 4
J Unbroken Chain to NIST or a Physical Property - Request for Peer Review General Measurement Device and Calibration Topics 6
S Does NIST Certify Calibration Laboratories? General Measurement Device and Calibration Topics 4
T Outsourcing Calibration - NIST, OEM, and Calibration Laboratory General Measurement Device and Calibration Topics 2
S NIST equivalents for England and Germany Supplier Quality Assurance and other Supplier Issues 1
smryan Does the NIST certificate that came with my new ball-bar have any value? General Measurement Device and Calibration Topics 8
B NIST Traceable Thermometer Uncertainty Measurement Uncertainty (MU) 5
AnaMariaVR2 New NIST reference materials available for popular diet supplement Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
Marc NIST - US Revamps Science, Technology Standard-Setting Efforts General Measurement Device and Calibration Topics 0
R Does being traceable to NIST meet the requirements of ISO standards? General Measurement Device and Calibration Topics 16
N Thermocouple Drift Determination - Drift test done by NIST General Measurement Device and Calibration Topics 3
C Calibration Of Stop Watch using the NIST Clock General Measurement Device and Calibration Topics 4
Marc NIST Handbook of Mathematical Functions reference text World News 0
R NIST Test Number - What does it mean? General Measurement Device and Calibration Topics 3
ScottK NIST comes out against DRE voting machines. Coffee Break and Water Cooler Discussions 7
B Looking for Calibration / Reference Standards tracable to NIST General Measurement Device and Calibration Topics 15
R NIST - Primary Standard - Traceable to what? What exactly does that imply? General Measurement Device and Calibration Topics 10
Tim Folkerts Great NIST Stats Reference Statistical Analysis Tools, Techniques and SPC 2
Marc Uncertainty ListServe - NIST TN 1297 Measurement Uncertainty (MU) 3
M Calibration of Timers to NIST - How are digital and analog timers calibrated? General Measurement Device and Calibration Topics 15
D Accreditation Scheme:relationships between ANSI, NIST, NCSL, ILAC, APLAC, NCCLS, etc. General Measurement Device and Calibration Topics 3
Marc NIST 'High Integrity Software Systems Assurance' resource (site semi-abandoned) Software Quality Assurance 2
