Re: Not having an original copy of ISO 9001 standard, Is it a NonConformance?
This requirement to be in possession of a copy of the applicable standard is implicit in the design and creation of a compliant system.
If you have (or even if you don't have) comprehensive flow charts, you would still have had to identify the standard as an "input" to your Operating System design and also, as input to the Internal Audit process (all your auditors need to be able to cite which clauses are involved in any non-conformance). As such, you are obliged to provide evidence of that input, and the auditor should be able to verify that you are in fact, using the latest revision level of the standard.
The same applies to "Customer specifications" which might be identified as "input" to your "product design process". As such, you would be obliged to provide evidence of that "required input" defined in your process.
Consider the standard as the "specifications" which define your System. There's no doubt that you need to be in possession of a current original document (unless you have ISO permission to create or distribute reproductions).
No doubt there are considerably bigger fish to fry in terms of audit focus...so why waste our energies on this rhetoric...just do it!
Patricia
P.S...By the way...what do you use (or what did you use, to create your system), if you don't have an original copy? Did you take one out from the local library?
I was one of the folks who didn't see this a non-conformance so unless the auditor could sight rhyme and verse I am not worrying about it.
Patricia
but if I can show revision control on my "copy" I would argue only that it is not a finding.
