Is Notification of the Test Laboratory always necessary for Supplier Changes?
Mark Meer
Wondering when it is necessary to update the Constructional Data Form (CDF) i.e. list of critical components, of a 60601-1 test report if information changes...
Our situation is this:
- We have an IEC 60601-1 test report issued by a 3rd party test lab.
- This has been used in an FDA 510k and part of our technical file.
- We do not, however use the NRTL mark, and hence there is no annual surveillance from the test lab.
Now, we want to have an alternate supplier for our LiIon battery.
So the question is:
- Is it absolutely necessary to inform the test lab and have them update the test-report?
- Or, is it acceptable to perform our own validation of the new supplier and process the change internally?
The battery specs are identical, the only difference is that while the first was certified to UL1642, the new one is to IEC62133 2nd Ed.
N
NickM
If you are utilizing compliance to 60601-1 as part of your regulatory submissions, you need to have a method that ensures that you meet this standard throughout the product lifecycle. If a critical component of your product changes, someone needs to assess how the change impacts compliance to 60601-1, whether it is you or a 3rd party. Regardless of who is doing it, you need to have documented objective evidence to support this change.
Nick
Mark Meer
As far as compiling the critical components list, as far as I can tell, all the test lab did was request supplier info and technical specs from us and tabulate it. Notes were made as to which were UL-listed or otherwise certified, but other than that, they didn't do any specific tests on, say, the battery.
Which is why I find it hard to justify paying them a lump more money to do what is essentially just a textual change to the critical components table.
Instead, it'd be nice if we could just validate the change internally, and create our own "addendum" to the test-report.
N
NickM
Since you are not trying to maintain an NRTL certification, you are free to do the analysis/justification yourself. Assuming both batteries are certified by UL, ensure you can confirm the certification through the UL certifcations directory (big counterfeit issue with batteries). Not sure if these batteries are UL Listed or Recognized, but if they are Recognized, you will want to evaluate the Conditions of Acceptability to see if the new battery has any new/different CoA's. I would also double check to see if they originally did any temperature testing of either the battery or areas close to the battery. If they did, you may need to repeat that.
Mark Meer
Thanks NickM. Good to have some reassurance that we aren't completely beholden to the test lab. :)
And herein lies the main issue I'm struggling with. The original batteries were UL1642 certified, whereas the new ones are IEC62133(2nd ed.) tested (but not UL certified).
The original 60601-1 testing was to the 2nd edition, prior to the requirement of IEC62133 for secondary batteries in the 3rd edition.
So, as far as "state-of-the-art", the new batteries would presumably match the current 60601-1 safety requirements better than the original ones, no?
N
NickM
Now you complicated things! If the new battery is not certified, what objective evidence do you have from your supplier that it meets IEC 62133? Is it an internal report or 3rd party test report? It would be a red flag to me that the battery does not have any certification. How do you ensure that that battey you buy a year from now still is compliant to this standard if there is no 3rd party follow-up service activity happening?
Mark Meer
It is tested by a 3rd party, ISO/IEC 17025 accredited test lab (we have the test-report), but the battery is not NRTL marked.
The manufacturer runs an ISO9001 quality system and, as part of our supplier validation, we've also conducted an onsite facility inspection. Their controls (at present) exceeded our expectations.
True, we don't have plans to schedule future (e.g. annual) inspections and no plans to re-test periodically, so technically there is no CERTAINTY that the product remains the same, but there is a relatively high degree of confidence.
I don't see how UL-certified would make the situation any better...
N
NickM
It's your burden of proof to ensure that what you sell today or 3 years from now is still in compliance with 60601 and more importantly, safe for its users. If you have a robust supply chain management process, you can certainly lean on that but that would not be without risk. Having 3rd party certification (and follow-up service activities) on a battery does not eliminate the risk but certainly helps lower it. Given the failure mode of batteries (i.e, heat/fire) and the amount of recalls you see about batteries in the news, I personally would want to reduce the risk as much as possible.
Peter Selvey
NickM is correct - if there is no product certification scheme (NRTL being the most popular) there is no obligation to inform the test lab of the changes.
You do need to be careful about misrepresentation of the (old) test report. For example, if you keep it in the technical file there needs to some mechanism which identifies that parts of the report are no longer valid, and point to the location where (new) evidence of compliance is kept.
Li-ion batteries are a bit of an odd one. Although the packs are often "certified" this often comes with some quiet conditions of acceptability which are impossible to maintain in practice. For example, UL listings will often place a limit of X.XX V with the expectation that the end product manufacturer will implement protective circuits to ensure this condition is never exceeded in both normal and fault condition. The IEC standards seem to be no better.
In practice, most end product manufacturers use battery charging ICs that keep below the limit in normal condition, but this does not cover the fault condition.
At the same time, the risk of explosion is so serious that manufacturers of the battery pack will usually incorporate an electronic protection circuit inside the pack, on top of multiple protection features built into each cell. It really is serious stuff, not to be taken lightly.
The upshot is that in this particular areas the test and certification agencies appear to be behind the curve, and a bit disingenuous in they way they present a pack as "certified". Anyway, you would almost definitely be wasting your money reporting this particular change to a test lab :)
D CE marked MD Notification to Spain & Italy EU Medical Device Regulations 4
M Notification Requirements for Medical Device Raw Materials 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
Q Corrective Action Notification - Registration Audit ISO 13485:2016 - Medical Device Quality Management Systems 12
S Foreign Risk Notification Canada Medical Device Regulations 2
J Device notification / registration with competent authority EU Medical Device Regulations 2
John C. Abnet Special Status Notification IATF 16949 - Automotive Quality Systems Standard 1
L Change Notification Requirements for class 1 devices Medical Device and FDA Regulations and Standards News 1
M IATF16949 Clause 9.1.2.1e - Customer notification related IATF 16949 - Automotive Quality Systems Standard 4
J FDA notification of address change US Food and Drug Administration (FDA) 2
N Competent Authority notification for non-EU manufacturer EU Medical Device Regulations 4
R Change Notification - Registrar vs Notified body ISO 13485:2016 - Medical Device Quality Management Systems 1
P 21 CFR 807.81 When a premarket notification submission is required Other US Medical Device Regulations 0
M Informational US FDA Final Guidance – Special Premarket Notification [510(k)] Pathway Medical Device and FDA Regulations and Standards News 0
D Customer and Company Specific Requirements for notification of Customers of a change in Management or Key Personnel Customer and Company Specific Requirements 3
M Informational US FDA Final guidance – Metal Expandable Biliary Stents – Premarket Notification (510(k)) Submissions Medical Device and FDA Regulations and Standards News 0
M Informational ANVISA – Notification for Class 1 devices – Resolução da Diretoria Colegiada – RDC nº 270 de 28/02/2019 Medical Device and FDA Regulations and Standards News 0
M FDA News USFDA Final Guidance – Intent to Exempt Certain Unclassified Medical Devices from Premarket Notification Requirements Medical Device and FDA Regulations and Standards News 0
supadrai Informational Japan Minor Change Notification Application Form - Found it? Japan Medical Device Regulations 0
C QR Code on Medical Device Packaging and Notification to Notified Body EU Medical Device Regulations 1
S Change Control Form vs. Document Change Notification ISO 13485:2016 - Medical Device Quality Management Systems 3
T External Standard Update Notification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
S Nemko AS & DQS - Concern over notification as a Medical Device NB Registrars and Notified Bodies 5
E Customer Letter/Notification - Is it a field action? Other US Medical Device Regulations 4
dubrizo IATF 16949 Clause 8.7.1.6 - Customer Notification - Your Inputs Requested IATF 16949 - Automotive Quality Systems Standard 4
N Notification of Changes to a Class I Medical Device - Reporting Requirements EU Medical Device Regulations 4
O Regulatory Notification for IVD IFU Instructions Revision ISO 13485:2016 - Medical Device Quality Management Systems 3
L Notification and submission requirements for medical device material changes Registrars and Notified Bodies 2
T Notification of affected parties of Updated Documented Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
J CRB (Certification Registration Body) Notification of Potential Escape AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
C Notification to Customers regarding Major Audit Finding IATF 16949 - Automotive Quality Systems Standard 25
GStough Template for Supplier Notification of Audit Supplier Quality Assurance and other Supplier Issues 5
P Acquisition of a company that manufactures a PMA device-FDA notification requriements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
F Notification Procedure for Reimbursement Implants and Invasive Devices in Belgium EU Medical Device Regulations 4
S Audit Notification - Is it a obligation to notify people or just good practice Internal Auditing 18
Stijloor GM (Supplier) and PPAP Requirement 3.1 Customer Notification APQP and PPAP 5
Ajit Basrur FDA: Industry Notification: Furlough Update (8 October 2013) US Food and Drug Administration (FDA) 8
J Process Changes - Customer Notification Requirements APQP and PPAP 12
N Notification Sample Regarding Record Retention ISO 13485:2016 - Medical Device Quality Management Systems 5
O Documenting Processes requiring Customer Notification Misc. Quality Assurance and Business Systems Related Topics 2
A Customer Notification of Change Procedure Quality Manager and Management Related Issues 1
L How to track the NCR (Quality Notification, Services Notification) Nonconformance and Corrective Action 2
A Temporary Change of Manufacturing Site - Notified Body Notification Requirements EU Medical Device Regulations 3
Hershal This morning I received notification that I have my third copyright Coffee Break and Water Cooler Discussions 11
B Control Plan Revision Requirements - Notification of and Approval by Customers FMEA and Control Plans 1
K Customer Notification Requirements - New Packaging Machine for Class 1 Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 1
A Do I need to send notification to Notified body and EC Rep? EU Medical Device Regulations 12
D Customer Notification: PCN - EOL ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A Material Grade Change Notification to Brazil ANVISA Other Medical Device Regulations World-Wide 2
M Class I Medical Device - 1st notification and change notification EU Medical Device Regulations 4
S Update on Change Notification for Registered Medical Devices in Singapore Other Medical Device Regulations World-Wide 0
