Is Optical Parallel Set required calibration?
It depends on how you are using them.
If you are reporting flatness results in your calibrations then the set should be calibrated.
If you are just checking to see if your anvils are "good", then calibration isn't required.
Some labs will consider them "initial calibration only" status and use them until they show signs of wear or damage.
