Is Oxygen a Drug per FDA?
tehuff
Hi Covers,
Is the supplemental oxygen produced by a portable oxygen concentrator (prescription required) considered a drug? I am trying to determine the software level of concern and one of the questions is whether or not the device is used with a drug. The device filters air and concentrates the oxygen for delivery to patient via a nasal cannula. It is not life supporting. Is the oxygen in this case considered a drug per FDA? The concentrator device is Class II (product code CAW) if that helps-
Anyone worked on something similar?
Thx!
Jason PCSwitches
Yes and NO, it depends on the context in which it is used. Great question though, should get a lot of responses. I'm interested to hear others viewpoints. Regardless, the FDA
's definition of a drug makes it clear, somewhat. Again, it's all about the purpose of usage. Breathing oxygen as we all do without assistance is not a drug, but when administered to treat, prevent, or cure a disease and/or aliment as a component of medicine...well it's gray but technically I believe it is then a drug.
BTW, just because or not because a doctor prescribes it does not determine the classification.
cclee
To give you some idea, oxygen compressed gas cylinders are labeled either with USP (drug gases) or non USP grade (medical device gases: e.g aerobic, lung diffusion, biological atm). The bulk O2 for packaging these gases are also from 2 sources, one USP grade other is industrial high purity grade.
Since oxygen concentrator is used as an alternative to a compressed gas oxygen cyclinder, it will be classified according to the same application I suppose.
Looks perfectly clear to me. ;)
Here's a link to the FDA drug directory.
Put in the word 'oxygen' and it will bring up a database of concentrations and mixes. http :// www. accessdata. fda. gov/scripts/cder/ndc/queryndcai.cfm - DEAD 404 LINK UNLINKED
Ajit Basrur
Hi Covers,
Thx!
Great question (as Jason mentioned).
Pls refer these FDA links and let us know your answer :)
Import Alert 66-37
CPG Sec. 435.100 Compressed Medical Gases - *Warning Letters for Specific Violations Covering Liquid and Gaseous Oxygen* - DEAD 404 LINK UNLINKED
Al Dyer
I use O2, and am on Medicare & Blue Care Advantage. They sure both consider it a drug. O2 at low levels will slowly kill you (<89) Long term use of O2 will also kill you, it rusts the body as it rusts anything it contacts. It's a scary stuff to deal with when needed to live balanced with the amount that will slowly have a detrimental affect on the same condition. I do have some knowledge as I suffer from COPD.
Fell free to contact me
Al..............
L
Laura Halper
Yes, the FDA regulates compressed oxygen as a prescription drug, and the production/processing is subject to 21CFR Parts 210 and 211. However, because the nature of oxygen is so "different" from other drugs, it's hard to apply some sections of Part 210/211. So the FDA has issued CGMP Guidance specific for compressed oxygen -- "Compressed Medical Gases Guideline".
Here's a link to the Guidance:
http://www.fda.gov/Drugs/GuidanceComplianceRegulatoryInformation/Guidances/ucm124716.htm
tehuff
Hi all,
Just wanted to close this thread with the final answer. Oxygen is NOT a drug per FDA in the context of a device that produces concentrated oxygen by filtering ambient air (see original post). The device itself is regulated as a medical device but the oxygen is not considered a drug in this instance. The software level of concern for this type of device is moderate. Thanks!
G
Gerry Quinn
This draft document goes a long way to defining the division between and device and a drug.
Guidance for Industry and FDA Staff:
Interpretation of the Term “Chemical Action” in the Definition of Device under Section 201(h) of the Federal Food, Drug, and Cosmetic Act
N Medical Devices in oxygen rich environment IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
P IEC 60601 11.2.2 - Oxygen Rich Environment sources of ignition IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Oxygen enriched environment applicability - Operating table used in general surgeries in hospital IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
C Requirements for dissolved oxygen and/or head space oxygen in Pharmaceuticals Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
S Oxygen mask and nebilzer mask Applied standards EU Medical Device Regulations 2
M Regulations for oxygen/air-tubing and connectors inside of ME equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
F Heat and Moisture Oxygen Port Changes Classification 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
T CFDA issues notice for Small Oxygen Respirators (9/16/2013) China Medical Device Regulations 0
B Defining Expected Oxygen Leakage for Safety Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Ronen E Nidek Medical Class I recall: Medical Mark5 Nuvo Lite Oxygen Concentrators Other US Medical Device Regulations 0
N Chemical Oxygen Demand (COD) Determination in Industrial Waste Water General Measurement Device and Calibration Topics 5
R Testing Medical Equipment used in conjunction with Oxygen Rich Environments IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
M Oxygen Data Logger that we can place with each shipment via aircraft ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A An Example of a Risk Analysis Report for a Class II Medical Device (Oxygen Mask) ISO 14971 - Medical Device Risk Management 29
A Recreational Oxygen Concentrator - FDA or other requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
H Oxygen Purity Requirements - Oxygen to use in electrical arc furnace ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
F Risk of fire in an Oxygen rich environment - Fire Prevention - IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
sonflowerinwales Oxygen gauge on Nitrogen supply ISO 13485:2016 - Medical Device Quality Management Systems 16
F Oxygen Concentrator Hazards ISO 13485:2016 - Medical Device Quality Management Systems 9
ScottK Oxygen Cleaning and Surfactants used for leak detection Various Other Specifications, Standards, and related Requirements 1
S Do we need to submit our memory foam oxygen mask gasket for FDA approval? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
C How about the classification under 93/42/EEC? Sterile oxygen mask ISO 13485:2016 - Medical Device Quality Management Systems 7
G Process monitoring of portable & stationary oxygen units: Can we use Cpk, Ppk, SPC ? Capability, Accuracy and Stability - Processes, Machines, etc. 3
G Process monitoring - Stationary and portable oxygen units ISO 13485:2016 - Medical Device Quality Management Systems 1
N Is this a single integral drug device combination product EU MDR CE Marking (Conformité Européene) / CB Scheme 1
D CFR Title 14: Aeronautics and Space PART 120—DRUG AND ALCOHOL TESTING PROGRAM Federal Aviation Administration (FAA) Standards and Requirements 3
Q Legal Manufacturer OTC Drug Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
D CE Marked product considered a Drug in India Other Medical Device Regulations World-Wide 0
M Workplace Drug Testing in 2020 Misc. Quality Assurance and Business Systems Related Topics 9
T Clinical trial - Medical device product not cleared (without FDA approval) in a drug trial Other US Medical Device Regulations 9
D Requirement of Pharmacovigilance (Drug Safety) Risk Based Strategic and Tactical Audit Plan General Auditing Discussions 0
V Informational EMA - Quality requirements for drug-device combinations EU Medical Device Regulations 0
M Informational Health Canada – Drug and medical device highlights 2018: Helping you maintain and improve your health Medical Device and FDA Regulations and Standards News 1
K Comparator drug with Japanese label use in Clinical trials? US Food and Drug Administration (FDA) 0
S Do we need to validate Software used in Drug discovery and development process? Qualification and Validation (including 21 CFR Part 11) 2
O Validation approach for a Photostability Chamber (used for fluid therapy and injectable drug products) Qualification and Validation (including 21 CFR Part 11) 1
M Informational MHRA Guidance – Recommendations from the independent Expert Advisory Group on the use of Paclitaxel Drug-Coated Balloons (DCBs) and Drug-Eluting Stent Medical Device and FDA Regulations and Standards News 0
K Release testing for Combination Drug-Medical Device Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
D FDA filing guidance to add sterilization step for approved drug Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 8
M FDA News USFDA Final Rule – Medical Device Classification Procedures: Incorporating Food and Drug Administration Safety and Innovation Act Procedures Medical Device and FDA Regulations and Standards News 0
S Should the primary drug containers be molded in ISO Class 7 clean room? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 6
P Drug packaging / filling operations Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 8
P China drug packaging DMF China Medical Device Regulations 0
H Korea DMF (Drug Master File) Fees Various Other Specifications, Standards, and related Requirements 5
Y What Clinical Data is required for Drug Delivery System EU Medical Device Regulations 1
P DMF (Drug Master File) type V for Sterilization Processes for USFDA Submission Other US Medical Device Regulations 3
V For a Drug-Device Combination Product, 'Design Control' Process is triggered at? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
A Russia- Medical device with drug registration Other Medical Device Regulations World-Wide 0
