Is positive recall acceptable under ISO/TS 16949 : 2002
rnsvasan
Hi friends,
Is positive recall acceptable in ISO/TS 16949 : 2002 QMS, I remember it is only addressed in QS9000 System. Can any one clear my doubt
Thanks in advance
Howard Atkins
Forum Administrator
Re: Posivitve recall
Hi friends,
Thanks in advance
Do you mean if you find a problem you tell the customer to send back to you?
If so then
ISO 9001:2000 said:
8.3 When nonconforming product is detected after delivery or use has started, the organization shall take action appropriate to the effects, or potential effects, of the nonconformity.
ISO/TS 16949 said:
8.3.3 Customer information
Customers shall be informed promptly in the event that nonconforming product has been shipped.
I think that this is clear cut
rnsvasan
I mean, can the material be used for production due to some urgency or special conditions before OK conformance and tracked separately till conformance gained from the inspection department.
Howard Atkins
Forum Administrator
In the old standards it was said that you can accept on condition that you segregate this.
Now you can do what you like as long as you do not supply non conforming material to the customer.
Keep the material segregated until you have approved the material. There is no need to have it in the standard
Have a look at 8.2.4 which says in part,
Product release and service delivery shall not proceed until all the planned arrangements (see 7.1)have been satisfactorily completed, unless otherwise approved by a relevant authority and where applicable by the customer.
A definition of "relevant authority" is nowhere to be found, but in general this means that if your documentation requires (for example) final inspection and and time constraints result in a "business decision" to skip it, the decision must have the approval of either an internal manager with sufficient authority or the customer, if the customer requires final inspection.
To directly answer your question, there is no explicit requirement for a positive recall procedure, but prudence would dictate that you have one.
Caster
An Early Cover
There is nothing in TS that prevents release for use under positive recall.
Just follow your old QS procedure.
For me if this becomes a way of life, it is a signal that something is wrong and would get me digging around to see what is happening.
T Is Positive Recall for in-process Product allowed in AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B Are Parts in a Positive Recall w/o Customer Complaint considered as External PPM? Quality Manager and Management Related Issues 6
K What does "positive-recall procedures" mean? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
H Positive Recall - How it should work in a small job shop - 7.4.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M Where did 4.10.2.3 - Positive Recall - At Risk - go? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
P Definition Positive (Immediate) Recall - The ability to trace items forward and backward Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 14
D ISO Urgent Release Issue - Positive Recall ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
V Is Positive Recall applicable in ISO 9000:2000? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
H Positive LAL while sterility and bio burden is confirming CE Marking (Conformité Européene) / CB Scheme 3
R Opportunity For Improvement vs Opportunity (Positive Risk) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
Sidney Vianna IAQG SCMH explains "positive risk"..........but does it? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Ed Panek User Feedback both negative and positive and acting upon those metrics 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
Ed Panek Requirement to track and trend positive feedback from customers ISO 13485:2016 - Medical Device Quality Management Systems 12
S Which non Salmonella organisms show positive in Wellcolex? Test kit ? US Food and Drug Administration (FDA) 1
G Positive Impacts in regards to ISO 14001 Quality Manager and Management Related Issues 4
K Customer Audit - Just a positive rant really General Auditing Discussions 2
D Attribute Agreement Analysis - MSA - False Negative/Positive IATF 16949 - Automotive Quality Systems Standard 3
K More Positive Internal Auditing - Would This Work? Internal Auditing 8
J Positive Control of Non Conforming Material at Machines AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
J Webinar: Positive Changes in Workplace Culture The Reading Room 0
P Tips on how to test air and improve air quality - What is a Positive Air? Food Safety Food Safety - ISO 22000, HACCP (21 CFR 120) 3
J Positive Corrective Action - 3 parts found out of 20,000 pcs 9 months after delivery Inspection, Prints (Drawings), Testing, Sampling and Related Topics 33
Wes Bucey How about something positive and uplifting? Career and Occupation Discussions 2
A Is the normal Cpk calculation applicable for data with positive & negative values? Capability, Accuracy and Stability - Processes, Machines, etc. 4
A Root Cause Analysis - Whether one can do RCA for Positive Findings Problem Solving, Root Cause Fault and Failure Analysis 19
A Positive Performance Indicator (PPI) for Energy/Utilities organization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Satisfaction scales - positive to negative or negative to positive Benchmarking 6
Marc Belkin is paying for positive Web reviews After Work and Weekend Discussion Topics 7
J Do you write positive comments in audit reports General Auditing Discussions 74
W I think there needs to be more emphasis on the positive value of controls General Auditing Discussions 0
A Positive Control of in-process nonconforming parts until rendered physically unusable Nonconformance and Corrective Action 3
S ISO 26000 standard on Social Responsibility reaches positive turning point World News 4
I ISO 9001:2000 Windfall - Yes, ISO 9001:2000 has had a very positive impact ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A I'm positive - Two atoms are walking down the sidewalk Funny Stuff - Jokes and Humour 1
Marc What has the ASQ done for you? ('Positive' posts ONLY) ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 16
A Positive Trend - Rejections and Customer Complaints - What to do? Customer Complaints 6
V Does preventive maintenance have any positive effect on smart transmitters? General Measurement Device and Calibration Topics 1
M Class Exempt Medical Device Recall Question US Food and Drug Administration (FDA) 3
Y MD Recall root cause Medical Device and FDA Regulations and Standards News 4
J Recall requirements for a distributor Medical Device and FDA Regulations and Standards News 2
C Mock recall template/procedure ISO 13485:2016 - Medical Device Quality Management Systems 1
R Calibration Recall/Reminders ISO 17025 related Discussions 2
R New website bfarm recall & adverse events? CE Marking (Conformité Européene) / CB Scheme 4
J Rework or Recall 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
D Shipping and recall questions ISO 13485:2016 - Medical Device Quality Management Systems 2
R Product Recall - medical devices in the hospital warehouse Canada Medical Device Regulations 2
J Mislabeling - Consider this an FDA notified recall? CFR 806.10 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
A Recall/Adverse event report procedures in Kuwait/Qatar/Kenya Other Medical Device and Orthopedic Related Topics 3
shimonv Recall - Is there a European regulation for recalls of products EU Medical Device Regulations 4
M Informational The FDA Takes Action to Protect Patients from Risk of Certain Textured Breast Implants; Requests Allergan Voluntarily Recall Certain Breast Implants a Medical Device and FDA Regulations and Standards News 0
