Is Process Flowcharting every Procedure Necessary?
Peter Fraser
#11
Dirk,
What works well for one organization, may not work for another.
Stijloor.
It depends on (amongst other things) the author's understanding of a "process" / the level of skills and knowledge of those using the process definitions / the software used / the style of flowchart. I have seen many flowcharts which confuse rather than explain. But then I have seen many more narrative procedures which do a worse job.
The original question ("Is Process Flowcharting every Procedure Necessary?") implies that there is a 1-1 relationship between "procedure" and "process". In fact:
i) a process flowchart IS (or can be) a procedure (ie a description of how something should be done)
ii) a procedure does not always describe a (complete) process
iii) it is very possible to define a management system by means of process descriptions in flowchart form, with links to forms, checklists and (if necessary) detailed work instructions. We do it all the time.
Stijloor
#12
Peter,
Excellent explanation!
Stijloor.
V
vanputten
#13
Hello Stijloor:
When you write "Flowcharts do not always provide the necessary details for the process", then I repsond with a comment that in some organziations, flowcharts can always provide the necessary details. This is not true for all managment sytems. But for some, the flowchart technique can provide all of the necessary details.
E
egarry
#14
One friend told me that i should include a process flow chart for every procedure
describing the flow of the procedure is this true or it is not obligatory?:notme:
I am a big fan of flowcharting processes and procedures. It is not required. Your friend used the word "should" and that is the key. I have used a combined format that gets acclaims from clients and lead auditors. I attached a sample of a corrective action / preventive action procedure, in a different thread http://elsmar.com/Forums/attachment.php?attachmentid=7902&d=1197345002 , that uses a flowchart and narrative in the same sheet.
Tip: Using this helps with understanding the interaction of business processes, business objectives, audit trails, QMS responsibilities and sequence of events.:paint:
Stijloor
#15
Hello Stijloor:
Dirk,
I agree. It depends on the situation. I've seen complicated processes depicted using flowcharts, the (critical) details were contained as "tribal knowledge." You can imagine what type of variation that introduced in those processes. On the other hand, I have seen multi-page, long-winded written procedures that could easily be documented using flowcharts. I think that you and I agree that "one size does not fit all."
Stijloor.
cuadra - 2010
#16
Dear MDWEEK:
Stop listening you your friend … you don’t need to create a flowchart for procedures.
You have to be careful with the keywords within the ISO 9001:2000 standard (i.e. documented procedure, document, record, plan, etc).
The ISO 9001:2000 standard, clause 4.1 (a) and (b) do require that you determine the processes (i.e. not procedures) needed for your quality management system and determine their sequence and interaction. The “how you do it” and “how much level of detail” is up to you. This “stuff” it is typically place in your Quality Manual.
If you read clause 4.2.2 you will see that you have the option of placing this “stuff” outside your quality manual but you will need to reference to it inside the quality manual.
Good luck my friend.
Cuadra
I
irishquality
#17
I guess it all comes down to personal choice,
Its not necssary, in the beginning I did this because it was the only way I could do procedures, because I use process flowcharts in my daily life, but I have come away from this because its just time consuming.
However, i do them when i feel a third party needs to see an overview of them.
why not ask your friend why they suggest that and explain what you have learned here - maybe they have got it wrong.
HTH
Stijloor
#18
However, i do them when i feel a third party needs to see an overview of them. HTH
Whether a "Third Party" needs them or not, it is still your decision if your want to use flowcharts or not. Don't do things for "third parties." Do things that make sense for your business/organization and its customers.
Stijloor.
Ron Rompen Need help with Flowcharting the PPAP Process APQP and PPAP 6
A Complaint review as part of the complaint handling process? ISO 13485:2016 - Medical Device Quality Management Systems 2
mustomutlu Process Validation Final Report Other Medical Device and Orthopedic Related Topics 2
Q Process Matrix_Audit Matrix Quality Management System (QMS) Manuals 4
Q Process description for outsourced processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q Process matrix examples of ISO 9001 & 14001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A When someone refuses to follow a process.... Misc. Quality Assurance and Business Systems Related Topics 21
R MDEL Process Canada Medical Device Regulations 4
optomist1 Rates Daily or Hourly Process Improvement Training Consultants and Consulting 2
B Toyota PPAP Process - Three Questions APQP and PPAP 3
R Changes vs CMO - How can we simplify this process? Supplier Quality Assurance and other Supplier Issues 3
A Ethics Committee Review Process for IVD Products EU Medical Device Regulations 2
V Laser Welding Process - Impact on Electrical Properties Reliability Analysis - Predictions, Testing and Standards 4
R MRB (Material Review Board) Process using MS Sharepoint or MS Teams Manufacturing and Related Processes 2
M Clinical Benefit of device that only aids in a process for managing or treating disease EU Medical Device Regulations 2
C In-process inspection - Tooling and assembly lines for automotive companies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
M Efficacy of an IT process after a cyber attack ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
N Sterilization Protocol Change in Validation Process and further impacts ISO 13485:2016 - Medical Device Quality Management Systems 1
N Riveting - special process Manufacturing and Related Processes 11
M Material incoming to the production process reflected in PFMEA FMEA and Control Plans 9
A API Spec Q1 Purchasing Process - Supplier Reevaluation based on Supplier Risks 5.6.1.4 Oil and Gas Industry Standards and Regulations 17
D Measurables for Plastic Injection molding process Manufacturing and Related Processes 1
S Cleaning process center change ISO 13485:2016 - Medical Device Quality Management Systems 4
Z Rapid audit template for plastic parts manufacturing process Manufacturing and Related Processes 12
R Inspection and Work order process Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
T ISO 13485:2016 Clauses related to process matrix ISO 13485:2016 - Medical Device Quality Management Systems 3
A How to reduce the process SPC monitoring Capability, Accuracy and Stability - Processes, Machines, etc. 3
John Predmore Configuration Management as a process instead of a procedure AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
R PCBA process validation Qualification and Validation (including 21 CFR Part 11) 2
U Internal Auditor not trained but done Audit for some process Nonconformance and Corrective Action 5
B Two excellent examples of process capability analysis from Quality Magazine Capability, Accuracy and Stability - Processes, Machines, etc. 5
D ECO (Engineering Change Order) process questions ISO 13485:2016 - Medical Device Quality Management Systems 7
S Sterilization validation after changing sterilization process provider Qualification and Validation (including 21 CFR Part 11) 3
Pau Calvo Quality Management process is mandatory in ISO9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Tagin Template or Checklist for Process Change Document Control Systems, Procedures, Forms and Templates 5
