Is Prototyping Design Output or Design Verification?
dyeysi
Hi Covers!
I'd like to know your opinion about this..
Is prototyping a design output or design verification?
I understand that during the design output, R&D engrs do mechanical drawings, schematic diagrams, electrical diagrams, BOMs to meet the input requirements. Design verification checks if the output meets the input requirements. Where does protoyping included?
I am a little confused right now..
Please enlighten me..
thanks
:thanks:
In my experience a prototype is built and tested as a design verification activity. Once the test results were reviewed, then the next phase of design can be entered.
Yes, and design output generally consists of specifications and requirements.
markl368
Some of the definitions depend on the industry you're working in. For example, the FDA states the following in its small entity compliance guide:
"Design input includes determining customer needs, expectations and requirements plus determining regulatory, standards, and other appropriate requirements. These various requirements are documented by the manufacturer in a set of device requirements. A set of design input requirements, when converted to engineering terminology, finalized and accepted as part of the device master record is called a device or product specification."
The FDA lists a separate procedural requirement under "Design Transfer" for final specification development. So basically, FDA considers product specs (at least the initial ones) to be design inputs. But I know that's not how everyone defines it.
The whole process is a continuum. The key thing regardless of the industry is to: 1) Plan design activities, 2) Determine the requirements, 3) Execute the initial design, 4)Test the design to see if it met requirements, 5) Change the design if you have to until you can confirm you met the requirements, 6)Document the process, specs and changes, and 7) Get the customer to confirm it's what they wanted.
If you do these things, you should meet requirements for controlling designs regardless of what you want to call the different steps.
harry
....................... The whole process is a continuum. The key thing regardless of the industry is to: 1) Plan design activities, 2) Determine the requirements, 3) Execute the initial design, 4)Test the design to see if it met requirements, 5) Change the design if you have to until you can confirm you met the requirements, 6)Document the process, specs and changes, and 7) Get the customer to confirm it's what they wanted.
Good post and advice from Mark. Prototype is certainly verification if used to confirm design assumptions especially for those designs that are new and unconventional but again depending on what you are designing, it could be both verification and validation if used to check designs, buildability and aesthetics.
Paul Simpson
It depends!
How do you describe your design process?
  1. The initial BOM is an output of the design process
  2. The activity of building a prototype verifies the BOM and intial build spec
  3. The built prototype is an output of the initial build verification
  4. The built protype is then maybe verified against a test specification
  5. The tested prototype is an output of the test programme
  6. You get the idea ....
yodon
I would agree with all the above posts *IF* you intend to collect data using the prototype. If it's just going to be used in marketing shows, then no need to jump through unnecessary hoops. If you are going to use it to, say, verify some aspects of the design, then by all means, design controls should be met.
And I would consider it a design output - something that can be used in design verification.
Big Jim
Hi Covers!
thanks
:thanks:
I think by now you're beginning to get the picture. It is not a simple one or the other, rather it can touch on several aspects of design. When you stop and think about it, many of the elements of design overlap each other. Design review, for example, is a part of all of the rest.
dyeysi
Our company is doing design on signalling devices (e.g. beacons). I get the idea of the design output and verification.
For the design output, our R&D engineers prepare schematic diagrams, mechanical drawings, BOMs and software programs. To be able to verify these outputs against the input, we build prototype of these drawings and designs and see whether it meets the required specifications. Functional testing follows according to our test plans.
Thank you for all your help!
J Design Control & Rapid Prototyping - Medical Device Software 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
S Do suppliers of prototyping components need to undergo supplier qualification? ISO 13485:2016 - Medical Device Quality Management Systems 3
A Remote Support Location Audit - Engineering prototyping and process evaluation Internal Auditing 2
S Supplier Quality with Prototyping Parts with no Part Number or Drawings ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
S Product Development and Prototyping Company - Nonconforming material or not? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
F ISO 9001 implementation at a prototyping shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
DuncanGibbons Section 8.3 relevant for design organisations AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
P DFMEA - Machinery Design Best Practices FMEA and Control Plans 0
R Is a FAIR required on parts that we design? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
U API Spec Q1 - 5.6.1.2 C (3) - Design software Oil and Gas Industry Standards and Regulations 3
A 8.6 Release of products and services, 8.3 Design and development - evidence required ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
C Stress / Challenge Conditions for Design Verification Testing to Reduce Sample Size 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
J Significant change related to design and intended use EU Medical Device Regulations 3
S Traceability of requirements to design and risk Design and Development of Products and Processes 3
U NOC - What is considered a "design change" EU Medical Device Regulations 5
Q PPT used as Design Review ISO 13485:2016 - Medical Device Quality Management Systems 3
D Design Verification Sample Size vs Repeats Statistical Analysis Tools, Techniques and SPC 9
A Design and development procedure for API Spec Q2 Oil and Gas Industry Standards and Regulations 6
D Design controls - Inputs, outputs, V&V, DHF, DMR ISO 13485:2016 - Medical Device Quality Management Systems 10
LostLouie Manufacturer divorced from Design process, is he justified in design process deficiencies? ISO 13485:2016 - Medical Device Quality Management Systems 9
R DFA & DFM - Examples for Design for assembly and design for manufacturability Lean in Manufacturing and Service Industries 2
D Using Laboratory Notebooks in R&D and Design and Development ISO 13485:2016 - Medical Device Quality Management Systems 3
D ISO 13485 - 7.3.6 Design and development verification - Do most folks create a separate SOP? ISO 13485:2016 - Medical Device Quality Management Systems 5
K Joint approval between OEM and Manufacturer on Design Documents ISO 13485:2016 - Medical Device Quality Management Systems 4
M API 4F/7K/8C Design Package Validation Oil and Gas Industry Standards and Regulations 2
A Design History File - Not ready to share the design drawings or Bill of Material US Food and Drug Administration (FDA) 2
W Need for current design or process control FMEA and Control Plans 2
D Test summary report example for design validation wanted - ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 1
S Documenting Design Verification Test Results (ISO 9001) Design and Development of Products and Processes 1
DuncanGibbons Understanding the applicability of Design of Experiments to the IQ OQ PQ qualification approach Qualification and Validation (including 21 CFR Part 11) 5
S Requirement to Conduct New Shelf-life Testing? (re-do testing for design change) EU Medical Device Regulations 3
A Sample Agreement available for Outsourcing Medical Device Design activity? ISO 13485:2016 - Medical Device Quality Management Systems 1
DuncanGibbons How is the arrangement between Design and Production organisation envisaged? EASA and JAA Aviation Standards and Requirements 4
L Design & Development of a SERVICE Service Industry Specific Topics 13
P Design verification driven by new equipment. How is this different than process validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
A AS9102B - 3.6 Design Characteristics and form 3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
P Design FMEA - Detection Rating criteria ISO 14971 - Medical Device Risk Management 3
U Medical Device Design finalization testing ISO 13485:2016 - Medical Device Quality Management Systems 2
S MDR Delay - MDD design Change? (before new MDR DOA) EU Medical Device Regulations 8
J Iterative design and production for custom made products ISO 13485:2016 - Medical Device Quality Management Systems 3
T Design Input detail & specificity ISO 13485:2016 - Medical Device Quality Management Systems 4
J Design file for pre-existing products - Inputs and Outputs ISO 13485:2016 - Medical Device Quality Management Systems 5
D Design Transfer Template capturing Customer Specific Requirements Other Medical Device Related Standards 3
T Design Control Procedures later in the Development Process ISO 13485:2016 - Medical Device Quality Management Systems 6
M Looking for a Presentation on Design for Excellence (DfX) Manufacturing and Related Processes 2
K Old medical devices -> 7.3.7. Design and development validation ISO 13485:2016 - Medical Device Quality Management Systems 1
